Sony PS5 DualSense Edge Wireless Controller
Quicklinx: H5PZWS00 Mfr#: 9443995
Type: Game pad
Wired / Wireless: Wireless
Compatibility: Sony PlayStation 5
More than 50 In Stock
£165.84 ex VAT
£199.00 inc VAT
Express delivery Order within the next 16 hours for delivery on Monday
Built with high performance and personalization in mind, this controller invites you to craft your own unique gaming experience so you can play your way.
Perfect Your Gameplay™
Find your edge with customizable controls and swappable profiles that can help equip you for anything from pro level tournaments to epic single player adventures.
Ultra-customizable controls
Custom settings make your DualSense Edge wireless controller uniquely yours.
Changeable stick caps - Three types of changeable stick caps help you stay comfortable in-game without sacrificing grip or stability.
On-controller user interface - Quickly swap between your pre-set control profiles and adjust game volume and chat balance from the controller’s dedicated function button. (Analogue audio connection to headset required for full compatibility. Audio balance adjustable when in party chat.)
Replaceable stick modules - Play for longer with swappable replacement stick modules available to purchase separately.
Mappable back buttons - Two swappable sets of back buttons, configurable to many other button inputs, put essential controls at your fingertips.
Adjustable trigger lengths - Manually set the travel distance of your left and right triggers for an optimal experience with whatever you’re playing.
USB braided cable with lockable connector housing - Lock the included 9.1ft/2.8m USB cable in place so it's much less likely to slip out at a crucial moment.
DualSense™ wireless controller features built in
Experience all the immersive features of the DualSense wireless controller, including haptic feedback, adaptive triggers, a built-in microphone, motion controls and more in supported titles.
Signature comfort and slip-resistant inner grips
Enjoy the same signature comfort of the original DualSense wireless controller, now enhanced with slip-resistant inner grips. Ideal for long sessions in single player games and staying comfortable during intense competitive play.
Compatible with the DualSense charging station
Keep two controllers fully charged - including your DualSense Edge wireless controller - with the quick and easy click-in design of the DualSense charging station, available to buy now. (Sold separately).
  • Perfect Your Gameplay
  • Ultra-customizable controls
  • Quick access profile settings menu
    Simply press the Fn button and Options button while in game to open the customization menu, where you can quickly change your settings.
  • Remappable buttons
    Customize the control layout of your favorite games so the commands you need are always exactly where you want them to be. Save your button configurations to your player profile and switch between them without leaving your game.
  • Adjustable triggers, stick sensitivity and vibration intensity
    Configure your stick sensitivity, stick dead zones, and trigger dead zones for finely tuned inputs, and even set your vibration intensity for a completely customized play experience.
  • Quick-swap control profiles
    Once you've found your ideal control settings, you can save them to unique profiles and swap between them on-the-fly, so your favorite configurations are always ready when you are.
  • Signature comfort and slip-resistant inner grips
    Enjoy the same signature comfort of the original DualSense wireless controller, enhanced with slip-resistant inner grips. Ideal for long sessions in single player games and staying comfortable during intense competitive play.
Sony DualSense Edge - gamepad - wireless - Bluetooth
Gamepad
Wireless - Bluetooth
Controls
PS button, directional buttons, action buttons, dual point touch pad, Options button, L1 Button, R1 Button, R2 Button, L2 Trigger, Create button, Left stick / L3 Button, Right stick / R3 Button, Touch Pad button, Mute button
Built-in speaker, headset port, profile switch, vibration, built-in microphone, adjustable vibration, capacitive touch pad, Click Mechanism, SIXAXIS motion technology, Light Bar, three-axis gyroscope, three-axis accelerometer, built-in USB-C charging port, Trigger Effect, adjustable triggers, buttons remap, adjustable stick sensitivity
1-year warranty
Sony PlayStation 5
Gamepad
Controls
USB-C
Rechargeable - Lithium Ion
USB cable, carrying case, 2 high dome caps, 2 low dome caps, 2 half dome back buttons, 2 lever back buttons, connector housing
Limited warranty - 1 year
Sony PlayStation 5
Type: Game pad
Brand: Sony
Stock Status: Clearance
