Sony PS5 Access™ Controller
Quicklinx: HJ4LWS00 Mfr#: 1000038368
Type: Game pad
Wired / Wireless: Wired
Compatibility: Sony PlayStation 5
More than 50 In Stock
£52.49 ex VAT
£62.98 inc VAT
Express delivery Order within the next 21 hours for delivery on Friday
Empowered Play™
A highly customizable PlayStation 5 controller kit designed to make gaming more accessible. Introducing the Access controller, a versatile controller kit that can be customized to meet players' diverse needs, designed in close collaboration with the accessibility community to help players with disabilities play more comfortably for longer.
Swappable button and stick caps
Configure the Access controller's button layout to suit your range of mobility and switch between the included stick caps to find the shape and texture that works best for you.
Adjustable stick length
Lengthen or shorten the control stick’s extension arm, then lock it down at your ideal length for comfort and convenience.
Built for easy access
Place the controller wherever play is most comfortable for you: from any 360° orientation, on different flat surfaces, a wheelchair tray, or attached to an AMPS pattern mount.
Join forces with other controllers
Use up to two Access controllers together as a single virtual controller, or combine one or two Access controllers with a DualSense™ or DualSense Edge™ wireless controller to add features like haptic feedback, adaptive triggers, motion sensor, and touch pad swipe to your setup.
Add extra control devices
Connect additional buttons, speciality trigger switches and other compatible accessories via the Access controller's four industry standard 3.5mm expansion ports, and configure their inputs via your PS5® console settings.
Custom profiles
Configure up to 30 individual control profiles from your PS5 console settings, store three profiles on the Access controller and quickly switch between them with a dedicated button, enabling you to use the most suitable control layout and button functions for what’s happening in-game.
Configurable buttons
Map button inputs so the commands you need are exactly where you want them, set button presses to toggle commands on/off or to serve as a single-press input, or disable buttons altogether to stop accidental pressing. You can even map two commands to a single button for more user-friendly play.
Adjustable stick settings
Calibrate the "north" direction for flexible positioning of the controller. Tailor stick sensitivity and deadzone to better suit your personal control needs.
  • Swappable button and stick caps
  • Adjustable stick length
    Lengthen or shorten the control stick's extension arm, then lock it down at your ideal length for comfort and convenience.
  • Built for easy access
  • Join forces with other controllers
    Use up to two Access controllers together as a single virtual controller, or combine one or two Access controllers with a DualSense or DualSense Edge wireless controller to add features like haptic feedback, adaptive triggers, motion sensor, and touch pad swipe to your setup.
  • Add extra control devices
    Connect additional buttons, specialty trigger switches and other compatible accessories via the Access controller's four industry standard 3.5mm expansion ports, and configure their inputs via your PS5 console settings.
  • Custom profiles
    Configure up to 30 individual control profiles from your PS5 console settings, store three profiles on the Access controller and quickly switch between them with a dedicated button, enabling you to use the most suitable control layout and button functions for what's happening in-game.
  • Configurable buttons
  • Adjustable stick settings
    Calibrate the "north" direction for flexible positioning of the controller. Tailor stick sensitivity and dead zone to better suit your personal control needs.
Sony Access - accessibility controller - wired
Accessibility controller
Wired
Controls
Triangle key, Square key, X button, joystick, Options button, L1 Button, R1 Button, R3 Button, R2 Button
4 x AUX ports
Sony PlayStation 5
Wired
Controls
USB-C
4 x AUX ports
Game Controller (1st) Details
Swappable button, adjustable stick length
USB-C cable, wide flat button cap, stick cap, 8 x pillow button caps, 4 x flat button caps, 4 x curve button caps, 2 x overhang button caps, dome stick cap, ball stick cap, 23 x tags
14.1 cm
19.1 cm
3.9 cm
322 g
Cable Length
1.5 m
Plug and Play
Sony PlayStation 5
Type: Game pad
Brand: Sony
Stock Status: Clearance
