Grade A Device
All our Grade A devices are items that have been returned to us within the standard 14 day cooling off period, simply because customers have changed their minds. The devices have never been in for a repair for a known fault and are subjected to rigorous cosmetic and functionality control tests before we re-sell them.
12 months warranty
Excellent condition, showing up to minimal signs of wear which includes, but not limited to, small/fine scratches and marks.
Secure packaging
The Handheld Gateway to Your PS5® Games
Play your PS5® console over your home Wi-Fi with console quality controls using PlayStation Portal™ Remote Player.
Put Your PS5® in the Palm of Your Hand
PlayStation Portal™ Remote Player gives you access to the games on your PS5 over your home Wi-Fi,(1) letting you jump right into gaming without needing to play on a TV.
Play Your Game Collection
PlayStation Portal™ Remote Player can play compatible games you have installed on your PS5® console, including your favorite games for PS5 and PS4.(2)
Experience Breathtaking Immersion with DualSense® Wireless Controller Features
Feel the immersive power of haptic feedback and adaptive triggers in supported games.(4) Responsive vibrations react to your in-game choices and simulate environmental factors. Dynamic resistance mimics the tension of interactions with in-game gear and objects in select PS5® games.
Beautiful 8" LCD Screen
Take in every exquisite detail of your favorite games as they come alive on a brightly lit and gorgeous full HD screen.
60fps Capable at 1080p Resolution
PlayStation Portal™ Remote Player can deliver silky smooth gameplay at up to 60fps with high image clarity on its 1080p resolution screen.(3)
Get Gaming Fast
PlayStation Portal™ Remote Player is a purpose-built device dedicated to delivering an incredible remote play experience. That means you can turn it on, press a button to connect to your PS5® console and get right to playing with remarkable speed.
No TV Needed to Play and No Living Room Required.
Since PlayStation Portal™ Remote Player lets you stream games over your home Wi-Fi,(1) you can play your PS5® console even when someone else is using the TV it’s connected to. Simply turn on PlayStation Portal™ Remote Player and you’re good to go. With PlayStation Portal™ Remote Player on your home Wi-Fi connection (1), you have more flexibility to play in any room where you live(1) with no TV required. Would you like to keep playing while you’re in the kitchen eating breakfast? Go for it!
- PlayStation Portal™ Remote Player can stream compatible games installed on your PS5 console. PlayStation Portal™ Remote Player requires broadband internet Wi-Fi with at least 5Mbps for use. For a better play experience, a high-speed connection of at least 15Mbps is recommended. The quality and connectivity of your play experience may vary depending on your network environment. A PS5 console and account for PlayStation Network is required. The PS5 console must be connected to a broadband internet connection, powered on fully or in Rest Mode, and it must be paired with your PlayStation Portal™ Remote Player.
- Games that require a VR headset (PlayStation VR or PlayStation VR2) or additional peripherals (other than a DUALSHOCK 4, DualSense, or DualSense Edge wireless controller) are not compatible. Games that must be streamed on PS5 using a PS Plus Premium membership are not compatible. Haptic feedback and adaptive trigger features available when supported by game.
- Individual game performance will vary based on the specific game being played, and the quality of connectivity in your network environment.
- Haptic feedback and adaptive trigger features are only available when those features are supported by the game being played.
- A PS5™ system (sold separately) is required to use PlayStation Portal™.
Used stock
What is used stock?
Accessories | Packaging | Functional | Software | Manuals | ||
Ref:
HLN7 051034 Condition: Customer return - item has been used and shows signs of use |
£95.70 |
Legend
This part of the stock item is present and in good condition
This part of the stock item is not present or functional
This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
This part of the stock item is not applicable e.g. it might not include accessories or software as standard
This item has not been tested.
