Feel a New Real™
Escape into worlds that feel, look and sound truly real as virtual reality gaming takes a huge generational leap forward with PlayStation®VR2
CUTTING-EDGE PERFORMANCE
Enjoy stunningly vibrant 4K HDR visuals4 in compatible games, a vast 110º field of view and state-of-the-art graphical rendering, all made possible by the power of PS5™.
HEIGHTENED SENSORY AND EMOTIONAL EXPERIENCES
Experience revolutionary PlayStation VR2 Sense™ technology with eye tracking, headset feedback and 3D Audio, which combines with the new intuitive controllers to create deeply realistic sensations and emotions in compatible games.
QUICK SETUP
Jump straight into the action with a quick and simple one-cable connection to your PS5 console.
THRILLING NEW WORLDS
Surround yourself in the next generation of genre-defining virtual reality games as you connect to new worlds in uniquely immersive ways.
Legal Information
PlayStation®5 console required to play PlayStation VR2.
PlayStation VR2 is not compatible with the PlayStation®4 console and cannot play content that requires PS VR.
PlayStation VR2 is not for use by children under age 12.
Great performance
Enjoy stunningly vibrant 4K HDR visuals in compatible games, a vast 110° field of view and state-of-the-art graphical rendering, all made possible by the power of PS. -
Heightened sensory and emotional experiences
Experience revolutionary PlayStation VR sense technology with eye tracking, headset feedback and 3D audio, which combines with the intuitive controllers to create deeply realistic sensations and emotions in compatible games. -
Quick setup
Jump straight into the action with a quick and simple one-cable connection to your PS5 console. -
Thrilling worlds
Surround yourself in the next generation of genre-defining virtual reality games as you connect to worlds in uniquely immersive ways.
- Sony PlayStation VR2 virtual reality system - 4K - HDR
- Virtual reality system
- Sensors
- 3-axis gyro sensor, capacitive sensor, infrared eye tracking system, 3-axis accelerometer, infrared proximity sensor
- Native Resolution
- 4K at 120 Hz
- Resolution per Eye
- 2000 x 2040
- Field of View
- 110°
- Input Connectors
- USB-C
- Audio Input
- Microphone
- 1-year warranty
- Display Type
- Virtual reality system / OLED
- Native Resolution
- 4K 120 Hz
VR Headset
- 2000 x 2040
- Field of View
- 110°
- Sensors
- Vibration Feedback
- Tempest 3D AudioTech
Audio Input
- Microphone
- USB-C , Headphones
- Trigger, Fresnel lens, haptic feedback, Bluetooth pairing, built-in rechargeable lithium-ion battery, 4 cameras
- Included Accessories
- Headphones, 2 PlayStation VR2 Sense controllers, 3 pairs of earpieces (S, M, L)
- Cables Included
- 1 x USB cable
- Limited warranty - 1 year
Used stock
What is used stock?
Accessories | Packaging | Functional | Software | Manuals | ||
Ref:
H8CS 050658 Condition: Customer return - item has been used and shows signs of use |
£270.59 |
Ref:
H8CS 050574 Condition: Customer return - item has been used and shows signs of use |
£230.99 |
Ref:
H8CS 050582 Condition: Customer return - item has been used and shows signs of use |
£234.29 |
Legend
This part of the stock item is present and in good condition
This part of the stock item is not present or functional
This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
This part of the stock item is not applicable e.g. it might not include accessories or software as standard
This item has not been tested.
