Put Your PS5® in the Palm of Your Hand
PlayStation Portal™ Remote Player gives you access to the games on your PS5 over your home Wi-Fi,1 letting you jump right into gaming without needing to play on a TV.
Play Your Game Collection
PlayStation Portal™ Remote Player can play compatible games you have installed on your PS5® console, including your favorite games for PS5 and PS4.2
Experience Breathtaking Immersion with DualSense® Wireless Controller Features
Feel the immersive power of haptic feedback and adaptive triggers in supported games.4 Responsive vibrations react to your in-game choices and simulate environmental factors. Dynamic resistance mimics the tension of interactions with in-game gear and objects in select PS5® games.
Beautiful 8" LCD Screen
Take in every exquisite detail of your favorite games as they come alive on a brightly lit and gorgeous full HD screen.
60fps Capable at 1080p Resolution
PlayStation Portal™ Remote Player can deliver silky smooth gameplay at up to 60fps with high image clarity on its 1080p resolution screen.3
Get Gaming Fast
PlayStation Portal™ Remote Player is a purpose-built device dedicated to delivering an incredible remote play experience. That means you can turn it on, press a button to connect to your PS5® console and get right to playing with remarkable speed.
Wireless freedom
Experience the freedom of wireless gameplay with the PlayStation Portal's advanced Wi-Fi connectivity. No more tangled cords or being tethered close to the console, allowing for a seamless and comfortable gaming experience anywhere within range. -
Immersive gameplay
With features like adaptive triggers, haptic feedback, and vibration, the PlayStation Portal offers an immersive gaming experience. Each action in the game is met with a physical response, enhancing the realism of every moment. -
Crystal clear visuals
The 8" LCD screen delivers stunning 1080p resolution at 60 fps, ensuring that every game is displayed with crystal clear visuals and vibrant colors. This high-definition screen brings games to life, offering a deeply engaging visual experience. -
Comprehensive control
Equipped with a wide array of controls including action buttons, directional buttons, dual point touch pad, and more, the PlayStation Portal provides comprehensive control over gameplay. Whether it's navigating through complex environments or executing precise actions, players have everything they need at their fingertips. -
Enhanced audio
The built-in microphone allows for clear communication with teammates or opponents, while the mute button ensures privacy when needed. This feature enhances the social aspect of gaming, making it easier to strategize and enjoy multiplayer games.
- Sony PlayStation Portal - remote player - wireless - Wi-Fi
- Product Type
- Remote player
- Connectivity Technology
- Wireless - Wi-Fi
- Controls
- PS button, Create button, Options button, directional buttons, action buttons, R1 Button, L1 Button, R2 Button, L2 Trigger, Left stick / L3 Button, Right stick / R3 Button, dual point touch pad, Touch Pad button, Mute button
- 8" LCD screen, 1080p at 60 fps, built-in microphone, vibration, haptic feedback, adaptive triggers, built-in USB port
- Midnight black
- 1-year warranty
- Designed For
- Sony PlayStation 5
- Product Type
- Remote player
- Wireless - Wi-Fi
- Controls
- Interface
- USB
- Midnight black
- Battery
- Rechargeable - Lithium Ion
- Capacity
- 4370 mAh
- Included Accessories
- USB cable
- 529 g
- Limited warranty - 1 year
- 5 °C
- 35 °C
- Designed For
Used stock
What is used stock?
Accessories | Packaging | Functional | Software | Manuals | ||
Ref:
J0X7 051423 Condition: Customer return - item has been used and shows signs of use |
£130.34 |
Ref:
J0X7 051281 Condition: Customer return - item has been used and shows signs of use |
£102.29 |
Legend
This part of the stock item is present and in good condition
This part of the stock item is not present or functional
This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
This part of the stock item is not applicable e.g. it might not include accessories or software as standard
This item has not been tested.
