Discover Games and Movies on Blu-ray™ Disc
Add a disc drive to your PlayStation®5 Digital Edition console.
So Many Games
Play PS5® games and a vast back catalog of supported PS4® titles on Blu-ray™ Disc.
Amazing Entertainment
Enjoy watching movies and shows on 4K Ultra HD Blu-ray™ Discs, Blu-ray™ Discs, and DVDs.
This product is only for PS5 Digital Edition consoles (CFI-2000 model group – slim). Drive will play 4K Ultra HD Blu-ray™ discs, Blu-ray discs, and DVDs. Internet connection required to pair Disc Drive and PS5 console upon setup.
Includes
Disc Drive
O Cover (for Disc Drive)
2 Horizontal stand feet (long)
Instruction Manual
How to attach the disc drive to PS5 consoles (CFI-2000 model group - slim)
Place your console on a soft cloth spread over a flat surface before attaching your disc drive.
Step 1
Go to the control centre and select Power > Turn Off PS5. The screen goes blank, the power indicator flashes white, and then turns off.
Step 2
Remove the AC power cord and cables, and then wait for the PS5 console to cool down. The main unit of your console is hot immediately after use.
Step 3
Place the console with the bottom facing up and the front side facing you, and then remove the horizontal stand feet (short).
Step 4
Slightly lift the circle cover away from the console to detach its clips and remove it.
Step 5
Align the disc drive’s clips with the 2 holes (marked with an upside-down triangle), then firmly push in until you hear a "click".
Step 6
Attach the circle cover and horizontal stand feet (long) included with your disc drive. Align the cover’s clips with the corresponding holes on the console and push in until you hear a "click".
Step 7
Connect the AC power cord and cables, and then turn on the power.
Keep the feet and cover you removed in steps 3 and 4 somewhere safe. They are needed to use the PS5 console without the disc drive attached.
Internet connection required to pair disc drive and PS5 console upon set up.
So many games
Play PS5 games and a vast back catalog of supported PS4 titles on Blu-ray Disc. -
Amazing entertainment
Enjoy watching movies and shows on 4K Ultra HD Blu-ray Discs, Blu-ray Discs, and DVDs.
- Sony PlayStation BD-ROM drive - plug-in module
- BD-ROM drive - plug-in module
- White
- Optical Storage
- DVD±RW / BD-ROM
- Media Load Type
- Slot-load
- 1-year warranty
- Designed For
- PlayStation 5 Slim Digital Edition
- White
Optical Storage
- DVD±RW / BD-ROM
- Supported Media Types
- DVD-ROM, BD-ROM, BD-ROM UHD
- Media Load Type
- Slot-load
- Included Accessories
- Cover, stand feet
- Limited warranty - 1 year
- Designed For
- Sony PlayStation 5 Slim Digital Edition
