Memory Stick PRO Duo Mark2, 4GB, is the ideal choice for HD recording with 1920 x 1080 AVCHD recording capability and a minimum write speed of 32Mbps. 1/3 the size of Memory Stick PRO is designed for use in ultra compact devices.
Enhanced compatibility
Designed to seamlessly integrate with PC systems, this flash memory card offers a hassle-free experience for users looking to expand their device's storage capabilities. -
Robust environmental resilience
With an operating temperature range from -11°C to 85°C, this memory card ensures reliable performance in a wide variety of environmental conditions, making it an ideal choice for users on-the-go. -
Efficient power consumption
Operating on a supply voltage between 2.7 and 3.6 V, the memory card is engineered for efficient power usage, contributing to the extended battery life of your devices.
- Sony - flash memory card - 4 GB - Memory Stick PRO Duo Mark2
- Product Type
- Flash memory card
- Form Factor
- Storage Capacity
- 4 GB
- Supply Voltage
- 2.7 - 3.6 V
- Designed For
- Cyber-shot DSC-TX100, DSC-TX100V
- Product Type
- Flash memory card
- Storage Capacity
- 4 GB
- Form Factor
- Supply Voltage
- 2.7 - 3.6 V
- MagicGate
- 31 mm
- 1.6 mm
- 20 mm
- 2 g
- -11 °C
- 85 °C
- Designed For
- Sony Cyber-shot DSC-TX100, DSC-TX100V
