Sony MEMORY STICK PRO DUO 4 GB
Quicklinx: 70QWWS00 Mfr#: MSMT4GN
Memory Stick PRO Duo Mark2, 4GB, is the ideal choice for HD recording with 1920 x 1080 AVCHD recording capability and a minimum write speed of 32Mbps. 1/3 the size of Memory Stick PRO is designed for use in ultra compact devices.
  • Enhanced compatibility
    Designed to seamlessly integrate with PC systems, this flash memory card offers a hassle-free experience for users looking to expand their device's storage capabilities.
  • Robust environmental resilience
    With an operating temperature range from -11°C to 85°C, this memory card ensures reliable performance in a wide variety of environmental conditions, making it an ideal choice for users on-the-go.
  • Efficient power consumption
    Operating on a supply voltage between 2.7 and 3.6 V, the memory card is engineered for efficient power usage, contributing to the extended battery life of your devices.
Sony - flash memory card - 4 GB - Memory Stick PRO Duo Mark2
Flash memory card
Storage Capacity
4 GB
Supply Voltage
2.7 - 3.6 V
Cyber-shot DSC-TX100, DSC-TX100V
Flash memory card
Storage Capacity
4 GB
Supply Voltage
2.7 - 3.6 V
MagicGate
31 mm
1.6 mm
20 mm
2 g
-11 °C
85 °C
Sony Cyber-shot DSC-TX100, DSC-TX100V
