Sony MDR-V150 Headphone DJ-Series
Quicklinx: 79Q1WS00 Mfr#: MDRV150.CE7
Sony's MDR-V150 Studio Monitor Series Headphones feature Supra-Aural Design for excellent listening comfort. Also included are the 30 mm Diameter Drivers for deep bass, High-Energy Ferrite Magnets, Reversible Earcups for single-sided monitoring, a Wide Molded Headband for long-lasting comfort, and a Stereo UniMatch Plug. Indulge yourself in amazing sound - Sony will show you how.
  • Studio Monitor series headphones
    Incorporate high-end materials and advanced engineering; critically clean, exceptionally clear sound for professional and high fidelity applications.
  • Reversible earcups
    Enable single-sided monitoring flexibility.
  • 30 mm diameter drive units
    Are larger than many headphones for deeper bass, lower distortion and wider dynamic range; bass response extends down to a low 18 Hz.
  • 500 mW power handling
    Atands up to day-in, day-out use at high output levels.
  • Ferrite magnets
    For high energy and compact size; help produce ample sound output - 98 dB/mW sensitivity.
  • Oxygen-free copper cord
    For maximum conductivity, minimum noise; conducts electricity better than conventional copper.
  • Supra-aural design
    Rests lightly on the ear; creates a controlled environment for better sound; driver is positioned the correct distance from the ear canal.
  • Wide, molded headband
    Distributes the headphone's weight over a wide area; reduced pressure means comfortable listening for hours on end.
Sony MDR-V150 - headphones - 3.5 mm jack
Headphones - wired - 3.5 mm jack
Recommended Use
Home audio
Headphones Form Factor
Full size binaural
Wired
Headphones Technology
Dynamic
Sound Output Mode
Stereo
Audio Specifications
Frequency Response 16 - 22000 Hz - Sensitivity 98 dB
Impedance
24 Ohm
Diaphragm Type
PET
1-year warranty
120 g
Recommended Use
Home audio
Audio Output
Full size binaural
Dynamic
Wired
Sound Output Mode
Stereo
Frequency Response
16 - 22000 Hz
Sensitivity
98 dB
Impedance
24 Ohm
Diaphragm
PET - 30 mm
Magnet Material
Ferrite
Connector Type
Headphones (mini-phone stereo 3.5 mm)
6.3 mm (1/4") stereo adapter
Cable Details
Headphones cable - 2 m
Limited warranty - parts and labour - 1 year
