Sony Lamp module for VPL-VW500ES projectors.
Quicklinx: 9VS7WS00 Mfr#: LMP-H260
£288.84 ex VAT
£346.60 inc VAT
Serious cinema fans get through a lot of movies. When the time comes to replace the lamp, the LMP-H260 will ensure non-stop cinema-quality projection. Reliable, long-lasting and easy to fit, the LMP-260 UHP replacement lamp means you can enjoy even more outstanding 4K quality home cinema.
  • Enhanced brightness
    The UHP lamp technology in the Sony LMP H260 projector lamp ensures your presentations are vivid and brightly illuminated, making it ideal for both business and educational environments.
  • Seamless compatibility
    Designed specifically for PC use, this projector lamp integrates smoothly with your existing setup, offering a hassle-free upgrade or replacement solution.
Sony LMP-H260 - projector lamp
Projector lamp - UHP
VPL-VW500ES, VW600ES
Projector lamp
Lamp
UHP
Sony VPL-VW500ES, VW600ES
Type: Projector lamp
Brand: Sony
