Sony KDL46R473ABU 46" Full HD LED Backlit TV 1920 x 1080
NEW LOWER PRICE - WAS £697.98!
Quicklinx: 8Z42WS00 Mfr#: KDL46R473ABU
  • 1080p
All the emotion of Full HD entertainment
From a tear rolling down the hero's face to the blades of grass on a sports field, the R47 reveals new levels of detail. Experience a Full HD resolution picture enhanced by a suite of technologies to produce sharper images, smoother action and sumptuous colour contrast.
Heighten the detail, heighten the drama
Take Full HD detail a step further with Clear Resolution Enhancer - a noise reduction and image enhancement technology that delivers a clear difference from standard LED TV. Images are crisp, textures are defined, and heightened contrast boosts on-screen depth perception.
Movement looks smoother and more natural
At the height of the drama, when you're at the edge of your seat, Motionflow XR 100Hz ensures fast-moving action sequences appear smooth, natural and lifelike. It even offers a choice of viewing modes to suit different content - from movies to sport or live entertainment.
Vivid, true-to-life colour and contrast
Rich, natural colour makes the images you see more compelling and believable. With Direct LED backlight screen technology you'll enjoy pure colours, high contrast and deep blacks. It ensures an altogether more vivid viewing experience - and it's energy efficient too.
Mirror your mobile content on your TV
Super-size your pictures, videos, apps, games and more with wired mirroring. Just connect your smartphone to the TV through the MHL and view your mobile content on your TV. Use your smartphone to swipe, enlarge, move and select content on the big screen for all to see.
  • Heighten the detail, heighten the drama
  • Movement looks smoother and more natural
    At the height of the drama, when you're at the edge of your seat, Motionflow XR 100 Hz ensures fast-moving action sequences appear smooth, natural and lifelike. It even offers a choice of viewing modes to suit different content - from movies to sport or live entertainment.
  • Vivid, true-to-life color and contrast
    Rich, natural color makes the images you see more compelling and believable. With Direct LED backlight screen technology, you'll enjoy pure colors, high contrast and deep blacks. It ensures an altogether more vivid viewing experience - and its energy efficient too.
  • Mirror your mobile content on your TV
    Super-size your pictures, videos, apps, games and more with wired mirroring. Just connect your smartphone to the TV through the USB port and view your mobile content on your TV. Use your smartphone to swipe, enlarge, move and select content on the big screen for all to see.
Sony Bravia KDL-46R473A R47 Series - 46" LED-backlit LCD TV - Full HD
LED-backlit LCD TV
Diagonal Class
46"
Resolution
1920 x 1080
Display Format
1080p
Input Video Formats
1080/24p, 1080/60i, 480/60p, 720/60p, 1080/50i, 720/50p, 576/50p, 1080/50p, 1080/60p, 480/60i, 576/50i
Frame Rate & Enhancement Technology
Motionflow XR 100 technology
24p Technology
24p True Cinema
Video Interface
Component, composite, HDMI, SCART
HDMI Ports Qty
2 ports
HDCP Compatible
LCD Backlight Technology
WLED backlight - direct-lit LED
Image Aspect Ratio
16:9
TV Tuner
1x analogue, 1x digital
Digital TV Tuner
DVB-C, DVB-T2
Speaker System
2 speakers
Stereo Reception System
NICAM, A2
USB
Sony RM-ED054 remote control
Energy Class
Class A
107 Watt
Power Consumption (On mode)
75 W
Power Consumption Stand by
0.3 Watt
Energy Consumption per Year
110 kWh
105.3 cm x 20.4 cm x 65 cm
10 kg
LED-backlit LCD TV
Energy Class
Class A
107 Watt
75 W
110 kWh
Diagonal Class
46"
Series
R47 Series
TV Tuner
TV Tuner Presence
Video Interface
HDMI Ports Qty
2 ports
HDCP Compatible
Modes
Backlight off mode, Photo Frame mode
Timer Functions
Sleep, wake
Dimensions
With stand
105.3 cm
20.4 cm
65 cm
10 kg
Display
Resolution
1920 x 1080
Display Format
1080p
Image Aspect Ratio
16:9
24p Technology
24p True Cinema
Widescreen Modes
Zoom 14:9, Full, Wide Zoom, Zoom, Normal, Caption
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Advanced Contrast Enhancer circuit (ACE), Live Color, Clear Resolution Enhancer, CineMotion, Cinema Drive, Dynamic Backlight Control
Stands & Mounts
Stand
Included
Stand Design
Tabletop
Stand Colour
Aluminium
TV Tuner
Conditional Access
Common Interface Plus (CI+) slot
NICAM, A2
Digital TV Tuner
Digital TV Tuner
DVB-C, DVB-T2
HDTV Tuner
Video Features
Input Video Formats
Electronic Programme Guide
Digital EPG
Parental Channel Lock
Media Player
USB Port
USB Ports Qty
1
Remote Control
Remote control
Remote Control Model
Sony RM-ED054
Scene Select
Audio System
Digital Audio Format
Dolby Digital Plus output, Dolby Pulse output
Audio Controls
Sound mode
Speaker System
2 speakers
Output Power / Total
16 Watt
Speakers
2 x main channel speaker - 8 Watt
Network & Internet Multimedia
Connect & Share
Mobile High-Definition Link (MHL)
Supported Consumer Electronics Control (CEC)
BRAVIA Sync Function
Connector Type
HDMI input - rear , HDMI input - side , 2 x SCART - rear , USB - side , Composite video / component video input - rear , Audio line-in - rear , Digital audio output (optical) - rear , Audio line-out / headphones - rear
Power supply
0.3 Watt
Dimensions & Weight Details
Panel without stand - 105.3 cm x 7.6 cm x 62.2 cm x 9.7 kg , Panel with stand - 105.3 cm x 20.4 cm x 65 cm x 10 kg
Width (Shipping)
121.3 cm
Depth (Shipping)
15.9 cm
Height (Shipping)
70.9 cm
