For an amazing picture quality, this TV pairs the brilliance of Ultra HD clarity with the brightness, color and detail of High Dynamic Range. Hidden areas of dark shadow and sunlight become full of clarity and detail.
Uncover the detail with 4K HDR
For the ultimate in picture quality, this TV pairs the brilliance of 4K clarity with the brightness, color and detail of High Dynamic Range (HDR). Previously hidden areas of dark shadow and sunlight are full of clarity and detail. -
Adding 4K magic into every scene
The advanced image processing engine performs thousands of adjustments every second to dynamically enhance resolution, color and brightness, taking every scene to the vividness of 4K and beyond. -
Introducing the perfect curve
The curved screen is expertly crafted for a gentle, natural curve, creating the perfect blend of immersion and viewing comfort. -
A world of possibilities
Find all the entertainment you can dream of, faster than ever.
- Sony Bravia KD-65SD8505 SD8505 Series - 65" LED-backlit LCD TV - 4K
- Product Type
- LED-backlit LCD TV - Smart TV
- Diagonal Class
- 65"
- Platform
- Android TV
- Resolution
- 3840 x 2160
- Display Format
- 4K UHD (2160p)
- Input Video Formats
- 1080/24p, 1080/60i, 480/60p, 720/60p, 1080/50i, 720/50p, 576/50p, 1080/50p, 1080/60p, 1080/30p, 480/60i, 576/50i, 2160/24p, 2160/25p, 2160/30p, 720/24p, 2160/50p, 2160/60p
- Frame Rate & Enhancement Technology
- Motionflow XR 1000 technology
- 24p Technology
- 24p True Cinema
- Video Interface
- Component, composite, HDMI, SCART
- HDMI Ports Qty
- 4 ports
- Connectivity
- Wi-Fi, LAN, Bluetooth
- LCD Backlight Technology
- Edge-lit LED
- Image Aspect Ratio
- 16:9
- TV Tuner
- 1x analogue, 1x digital
- Digital TV Tuner
- DVB-C, DVB-S, DVB-S2, DVB-T, DVB-T2
- Internet Streaming Services
- Google Play
- Speaker System
- 2 speakers
- Sound Effects
- S-FORCE Front Surround 3D
- USB
- 3 ports
- Included Accessories
- Sony RMF-TX200E remote control, batteries, IR Blaster
- Energy Class
- Class A+
- 223 Watt
- Power Consumption (On mode)
- 123 W
- Power Consumption Stand by
- 0.5 Watt
- Energy Consumption per Year
- 171 kWh
- Dimensions (WxDxH) - without stand
- 145.6 cm x 9.3 cm x 84.1 cm
- 29.4 kg
- Product Type
- Energy Class
- Class A+
- 223 Watt
- 123 W
- 171 kWh
- Diagonal Class
- 65"
- Series
- SD8505 Series
- Platform
- Android TV
- Video Processor
- 4K X1
- TV Tuner
- TV Tuner Presence
- Sensors
- Light sensor
- Video Interface
- HDMI Ports Qty
- 4 ports
- Modes
- Film Mode, backlight off mode
- Dimensions
- Without stand
- 145.6 cm
- 9.3 cm
- 84.1 cm
- 29.4 kg
Display
- Resolution
- 3840 x 2160
- Display Format
- 4K UHD (2160p)
- 16:9
- 24p Technology
- 24p True Cinema
- Edge-lit LED
- Viewing Angle
- 170 degrees
- Viewing Angle (Vertical)
- 178 degrees
- Advanced Contrast Enhancer circuit (ACE), i-Manual, Face Area Detection, 4K X-Reality PRO Engine, Tv SideView, CineMotion, Cinema Drive, Dynamic Backlight Control, Triluminos Display
Stands & Mounts
- Stand
- Included
- Stand Design
- Tabletop
- Stand Colour
- Silver
- Flat Panel Mount Interface
TV Tuner
- Conditional Access
- Common Interface Plus (CI+) slot
Digital TV Tuner
- Digital TV Tuner
- HDTV Tuner
Video Features
- Electronic Programme Guide
- Digital EPG
- Parental Channel Lock
Media Player
- USB Port
- USB Ports Qty
- 3
Remote Control
- Remote control
- Remote Control Model
- Sony RMF-TX200E
Audio System
- Digital Audio Format
- Dolby Digital output, Dolby Digital Plus output, Dolby Pulse output
- Surround Mode
- Sound Effects
- Speaker System
- 2 speakers
- Output Power / Total
- 20 Watt
- S-Master Digital Amplifier, Clear Phase Speaker, Digital Sound Enhancement Engine (DSEE), Clear Audio+, Google Cast support
- Speakers
- 2 x main channel speaker - 10 Watt
Network & Internet Multimedia
- Functionality
- Digital audio playback, digital photo playback, digital video playback, WEB browsing, Internet video playback
- Connectivity
- Connect & Share
- Wi-Fi Direct, Screen Mirroring
- Google Play
- Supported Consumer Electronics Control (CEC)
- BRAVIA Sync Function
- Connector Type
- 3 x USB - side , 3 x HDMI input - side , Audio line-out / headphones / subwoofer - side , Composite video / component video input - rear , Audio line-in - rear , SPDIF output - rear , LAN - side , SCART - rear , HDMI input - rear
- Batteries, IR Blaster
- Power Device
- Power supply
- 0.5 Watt
- On/off timer
Dimensions & Weight Details
- Dimensions & Weight Details
- Panel without stand - 145.6 cm x 9.3 cm x 84.1 cm x 29.4 kg , Panel with stand - 145.6 cm x 28.7 cm x 89.5 cm x 32.9 kg
- Width (Shipping)
- 177.9 cm
- Depth (Shipping)
- 21.1 cm
- Height (Shipping)
- 98.8 cm
