Sony ICD-SX712 Digital Dictation Device- With Dragon Software
Quicklinx: 7NH3WS00 Mfr#: ICDSX712DB.CE7
  • microSD
  • MP3
CD quality recording, with the software to transcribe recordings to a PC Two-way mic Linear PCM Format support Transfer MP3 recordings to your PC and let Dragon automatically transcribe the content Recording time Scene Select Intelligent Noise Cut Track mark LCD display Advanced recording Multi language support Supplied accessories
  • Versatile audio formats
    Supports a wide range of audio formats including LPCM, MP3, and WMA, ensuring compatibility with various types of audio content.
  • Ample storage options
    Comes with a 2 GB integrated flash memory and supports additional Memory Stick Micro M2 and microSD cards for extensive recording capacity.
  • High-quality recording
    Features a built-in stereo microphone with a microphone operation mode, capturing clear and detailed audio for all your recording needs.
  • Portable design
    Equipped with a lightweight pouch and a compact form factor, making it easy to carry and use on-the-go for any recording situation.
  • Easy connectivity
    Includes a USB cable for simple connection to a PC, allowing for easy file transfers and management of your recordings.
Sony ICD-SX712DB - voice recorder
Voice recorder flash based
Enclosure Colour
3.1 cm x 1.5 cm x 11.9 cm
70 g
Playback Digital Standards
WMA, AAC, MP3, LPCM
Digital Recording Time
750 hours - LP (Long Play)
Display
LCD
Supported Flash Memory Cards
microSD, Memory Stick Micro M2
Internal Memory
2 GB
Speakers
1 x speaker - built-in - 150 mW
Microphone
Microphone - built-in - stereo
USB
AAA type Nickel Metal Hydride
Voice recorder
Digital Player Type
Flash based
Enclosure Colour
Interface Supported
USB
Audio Formats
WMA, AAC, MP3, LPCM
Audio System
Internal Memory
2 GB
File System Supported
2 GB
Functions
Digital player, digital voice recorder
Voice operated recording, Digital Voice Up, Intelligent Noise Cut
Display
LCD
Speaker System
Speakers
Digital Player (Recorder)
ID3 Tags Support
Recording Time
Microphone
Microphone Operation Mode
Stereo
Connector Type
USB , Microphone , Headphones
Carrying case, USB cable, stand
1 x USB cable
Software
Sony Digital Voice Editor
3.1 cm
1.5 cm
11.9 cm
70 g
