For real cinema sound that fits your home, the HT-S40R has 600W of powerful and real 5.1 channel surround sound and wireless rear speakers that bring every movie to life.
Immerse yourself in powerful surround sound
For an exceptional audio experience, a combination of soundbar, subwoofer and wireless rear speakers deliver a dynamic surround sound that fills your room. And with 600W output and Dolby Digital you'll get powerful sound that puts you at the heart of the action. -
A wireless design
With a wireless amplifier to power the rear speakers, there are no wires between the front and the rear of your room to get in the way. The subwoofer and soundbar also share a single power connection, so the system can deliver cinema sound without clutter or complexity. -
TV wireless connection
For even fewer wires in your living room, you can send audio to your home theater system wirelessly with a Sony BRAVIA TV supporting TV wireless connection. -
Play your favorite music
It's not just movies that sound amazing, the HT-S40R is made for music too. -
Looks good in any living space
With a slim, compact soundbar, unobtrusive subwoofer and wireless rear speakers, the HT-S40R is designed to fit perfectly with BRAVIA TVs and complement your living room. -
Slim and elegant
The punched-metal grill and ability to be wall-mounted make the soundbar a great match for any TV. -
Stylish and unobtrusive
Compact, yet powerful wireless rear speakers effortlessly integrate with your room and can easily be wall mounted. -
Versatile 2-way design
Place the wireless amplifier however you like - flat on a surface like a table, or mount it on the wall. -
Set up in seconds
The HT-S40R is almost ready to go straight out of the box. Simply plug it in, wire up your main bar speaker using simple color-coded connections and connect rear speakers via the wireless amplifier. Then sit back and enjoy 5.1 channels of real surround sound.
- Sony HT-S40R - sound bar system - for home theatre - wireless
- Product Type
- Sound bar system - for home theatre - 5.1-channel
- Media Content Source
- USB-host
- System Components
- 2 speakers, subwoofer, sound bar, amplifier/wireless receiver
- Speaker Type
- Active
- Nominal Output Power (Total)
- 600 watt
- Amplifier
- Integrated
- Bluetooth
- Audio Formats
- WAV, WMA, MP3, LPCM
- Speaker System Details
- 1 x sound bar 270 watt , 2 x rear channel speaker 75 watt , 1 x subwoofer 180 watt
- Speaker Details
- Sound bar - front channel x 2 - 90 watt - at 1 kHz - 8 ohm - active , Sound bar - centre channel - 90 watt - at 1 kHz - 8 ohm - active , Speaker - rear channel x 2 - 75 watt - at 1 kHz - 4 ohm - active , Speaker - subwoofer - 180 watt - at 100 Hz - 4 ohm - active
- Built-in Decoders
- Dolby Digital
- Product Type
- USB-host
Speaker System
- System Components
- Speaker Type
- Active
- Audio System Continuous Power (Total)
- 600 watt
- Amplifier
- Integrated
- Audio Return Channel (ARC) Capability
- Bluetooth 5.0
- Bluetooth Profiles
- Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP)
- Bluetooth Audio Codec
- SBC
- Built-in Decoders
- Dolby Digital
- Audio Formats
- Speakers Included
- 1 x sound bar - 270 watt - wall-mountable / table-top , 2 x rear channel speaker - 75 watt - wireless , 1 x subwoofer - 180 watt - wired
- Speaker Details
- Sound bar - front channel x 2 - 90 watt - at 1 kHz CFR - 8 ohm - active , Sound bar - centre channel - 90 watt - at 1 kHz CFR - 8 ohm - active , Speaker - rear channel x 2 - 75 watt - at 1 kHz CFR - 4 ohm - active , Speaker - subwoofer - 180 watt - at 100 Hz CFR - 4 ohm - active
- Connector Type
- HDMI output (19 pin HDMI Type A) , USB (4 PIN USB Type A) , Audio line-in (mini-phone stereo 3.5 mm) , Digital audio input (optical) (TOS Link)
- Included Accessories
- Remote control
- Power Source
- Integrated power supply
- Dimensions (WxDxH) / Weight Details
- Sound bar: 90 cm x 7.45 cm x 5.2 cm / 2 kg , Rear channel speaker: 8.3 cm x 7.45 cm x 18 cm , Subwoofer: 19.2 cm x 36.2 cm x 38.5 cm / 7.8 kg , Receiver: 16 cm x 16 cm x 5.2 cm / 800 g
