Sony HT-CT60BT 2.1ch Soundbar with Bluetooth
Quicklinx: 9V0TWS00 Mfr#: HTCT60BT.CEK
Enjoy cinema quality sound in the comfort of your own home. A slim speaker bar and subwoofer create room-filling surround sound for an immersive movie experience. Hear what your home theater system has always been missing.
Put yourself right at the center of your favorite movies with virtual surround sound. Two front speakers deliver sound that bends around the room and straight to your ears. You will hear the action unfurl from all around you.
  • Take your movies further
  • Cinematic surround sound
  • Big sound, no distortion
    Hear sound that will keep you right on the edge of your seat. A powerful sub-woofer delivers pure, dynamic bass that will inject new life into your favorite movies. You can enjoy those explosions and loud effects the way they were intended.
  • Cool, minimalist look
    Enhance your living room decoration with a slim speaker bar that not only fits in front of the TV but also on the wall, or on a shelf. Add a touch of style wherever you put it.
Sony HT-CT60BT - sound bar system - wireless
Sound bar system - 2.1-channel
System Components
Subwoofer, sound bar
Enclosure Design
Bass reflex
Speaker Type
Active
Nominal Output Power (Total)
60 Watt
Amplifier
Integrated
Bluetooth, NFC
Speaker Details
Sound bar - stereo x 2 - 15 Watt - 2-way - active , Speaker - subwoofer - 30 Watt - active
Built-in Decoders
Dolby Digital
Enclosure Colour
Enclosure Design
Bass reflex
Enclosure Material
Wood
Speaker System
System Components
Speaker Type
Active
Audio System Continuous Power (Total)
60 Watt
Amplifier
Integrated
Bluetooth, Near Field Communication (NFC)
Built-in Decoders
Dolby Digital
Controls
Volume, treble, bass, Virtual Surround
Speaker System Details
Speaker Details
Driver Details
Sound bar: 2 x woofer driver - 0.98 x 4.72" , Sound bar: 2 x tweeter driver - 1.5"
Driver Details (2nd speaker)
Subwoofer: subwoofer driver - 5.12"
Connector Type
Audio line-in , Digital audio input (coaxial) (RCA) , Digital audio input (optical) (TOS Link)
Remote control, audio (optical) cable
Power Source
AC power adapter
20 Watt
Dimensions (WxDxH) / Weight Details
Sound bar: 94 cm x 7 cm x 8.3 cm / 1.6 kg , Subwoofer: 17 cm x 30 cm x 24.5 cm / 2.7 kg
