Enjoy cinema quality sound in the comfort of your own home. A slim speaker bar and subwoofer create room-filling surround sound for an immersive movie experience. Hear what your home theater system has always been missing.
Put yourself right at the center of your favorite movies with virtual surround sound. Two front speakers deliver sound that bends around the room and straight to your ears. You will hear the action unfurl from all around you.
Take your movies further
Enjoy cinema quality sound in the comfort of your own home. A slim speaker bar and subwoofer create room-filling surround sound for an immersive movie experience. Hear what your home theater system has always been missing. -
Cinematic surround sound
Put yourself right at the center of your favorite movies with virtual surround sound. Two front speakers deliver sound that bends around the room and straight to your ears. You will hear the action unfurl from all around you. -
Big sound, no distortion
Hear sound that will keep you right on the edge of your seat. A powerful sub-woofer delivers pure, dynamic bass that will inject new life into your favorite movies. You can enjoy those explosions and loud effects the way they were intended. -
Cool, minimalist look
Enhance your living room decoration with a slim speaker bar that not only fits in front of the TV but also on the wall, or on a shelf. Add a touch of style wherever you put it.
- Sony HT-CT60BT - sound bar system - wireless
- Product Type
- Sound bar system - 2.1-channel
- System Components
- Subwoofer, sound bar
- Enclosure Design
- Bass reflex
- Speaker Type
- Active
- Nominal Output Power (Total)
- 60 Watt
- Amplifier
- Integrated
- Bluetooth, NFC
- Speaker Details
- Sound bar - stereo x 2 - 15 Watt - 2-way - active , Speaker - subwoofer - 30 Watt - active
- Black
- Built-in Decoders
- Dolby Digital
- Product Type
- Enclosure Colour
- Black
- Enclosure Design
- Bass reflex
- Enclosure Material
- Wood
Speaker System
- System Components
- Speaker Type
- Active
- Audio System Continuous Power (Total)
- 60 Watt
- Amplifier
- Integrated
- Bluetooth, Near Field Communication (NFC)
- Built-in Decoders
- Dolby Digital
- Controls
- Volume, treble, bass, Virtual Surround
Speaker System Details
- Speaker Details
- Driver Details
- Sound bar: 2 x woofer driver - 0.98 x 4.72" , Sound bar: 2 x tweeter driver - 1.5"
- Driver Details (2nd speaker)
- Subwoofer: subwoofer driver - 5.12"
- Connector Type
- Audio line-in , Digital audio input (coaxial) (RCA) , Digital audio input (optical) (TOS Link)
- Included Accessories
- Remote control, audio (optical) cable
- Power Source
- AC power adapter
- 20 Watt
- Dimensions (WxDxH) / Weight Details
- Sound bar: 94 cm x 7 cm x 8.3 cm / 1.6 kg , Subwoofer: 17 cm x 30 cm x 24.5 cm / 2.7 kg
