Sony HT-A3000 3.1 Channel Dolby Atmos Soundbar
Quicklinx: HWZ7WS00 Mfr#: HTA3000.CEK
13 In Stock
£415.84 ex VAT
£499.00 inc VAT
The HT-A3000 immerses you in authentic surround sound with a center speaker for clear dialog and a built-in dual subwoofer for impressive power.
  • Calibrate sound to your space
    There's no need to precisely place the speakers. The soundbar with built-in microphones does it all for you, intelligently measuring the position of each speaker and optimizing sound to your room. With sound field optimization, the HT-A3000 can be calibrated to your unique room environment. Even if you move the soundbar to another room, you can use the calibration to optimize sound to the space.
  • Immersive surround sound from a soundbar
    The HT-A3000 3.1ch soundbar has three front speakers including a center speaker designed for clear dialog, and a built-in dual subwoofer for deep bass. With vertical surround engine and S-Force PRO Front Surround technology, the sound comes from all around you, maximizing the effects of Dolby Atmos and DTS:X.
  • Experience sound from above
    Thanks to Sony's virtual surround technology, the soundbar can position sound in vertical space - so you can experience 3D audio without the need for in-ceiling or up-firing speakers. As well as Dolby Atmos and DTS:X, vertical surround engine lends a more realistic, multi-dimensional sound to other formats too.
  • Surround made simple
    Using front speakers only, Sony's unique digital sound field processing technology virtually reproduces the surround sound field, with audio coming at you from both sides. You can enjoy rich, cinematic surround sound without cluttering your living space.
  • So immersive, so real
    With the HT-A3000, music comes to life. 360 reality audio puts you in the middle of the concert, studio session, or whatever you're listening to, for a totally immersive experience.
  • Sound from advanced speakers and a subwoofer
    Powerful speakers - three front speakers for surround and a built-in dual subwoofer for rumbling bass - work together to deliver clear, wide-ranging sound throughout your room.
  • X-balanced speaker unit
    The built-in dual subwoofer and front speakers feature an X-balanced speaker unit. The unique rectangular shape of these speakers maximizes the diaphragm area for more punchy bass. It also reduces driver excursion while maintaining sound pressure, resulting in less distortion and greater vocal clarity.
  • Clearer voice
    Deeper bass produces more movement from the speaker diaphragm, and because a full-range diaphragm often needs to reproduce higher frequencies simultaneously, phase modulation distortion can occur. Sony has developed unique signal processing technology to compensate for this effect, resulting in crisp, localized dialog and vocals.
  • Extended bass
    It takes a lot of power to accurately reproduce low bass frequencies and there's often a risk of distortion. To combat this, the soundbar uses Sony's unique signal processing technology to deliver dynamic extended bass, at any volume level.
  • Upscale your digital music in real time
    Upscale your compressed digital music files in real time. Edge-AI (Artificial Intelligence) uses DSEE Extreme (Digital Sound Enhancement Engine) technology to dynamically recognize instrumentation, musical genres, and individual elements of songs - like vocals and interludes - and restores the high-end range that compression takes away. The result is a richer and more complete listening experience.
  • Omnidirectional block design
    The HT-A3000 has been designed under a common omnidirectional block concept. Its sophisticated rounded edges represent a single solid block providing wide-spreading sound. The combination of rich material textures emphasizes an affinity with any living room environment.
Sony HT-A3000 - wireless
Speaker Type
Active
Amplifier
Integrated
Speaker System
Speaker Type
Active
Amplifier
Integrated
Bluetooth Profiles
Advanced Audio Distribution Profile (A2DP)
App-Controlled
Brand: Sony
