Sony HDR-PJ530 Camcorder Black with Built In Projector
Quicklinx: 99LVWS00 Mfr#: HDRPJ530EB.CEH
  • microSD Card
  • microSDHC Card
Throw a picture up to 100 inches onto any surface: the projector is bright to 25 lumens for vividly clear detail. Compensating for 13x more camera shake than traditional stabilization, a 'floating' lens unit and sensor keep a level position. Capture bright, clear images with striking Full HD detail, even when shooting in low light.
  • Put on a show anywhere with a built-in projector
  • Feel free to move with balanced optical SteadyShot
  • See the detail with an Exmor R CMOS sensor
  • Finer, faster shooting with BIONZ X processor
    Levels of noise are reduced with unparalleled speed for true detail in every frame.
  • See smartphone and tablet videos as large as life
    Connect your mobile through the HDMI input and project films, photos, YouTube clips, and more from your mobile.
  • Get closer to your subject
    30x optical/60x clear image zoom helps you pull a scene closer so you can capture it in perfect detail.
  • Fill the whole frame with a 26.8 mm wide-angle lens
    From group shots to stretching landscapes: never miss a thing, get everything in the shot.
  • Experience G lens quality
    Offering flawless image quality and refined handling, every G lens is made for the best possible performance with your camera.
  • Every pixel perfect
    Pixel Super Resolution technology analyzes every image pixel-by-pixel, improving the reproduction of textures and tones.
  • Instant sharing with one-touch connection via NFC
    Simply place your camera against an NFC-enabled smartphone or tablet to quickly share photos and MP4 videos.
  • No cables or hook-ups with built-in Wi-Fi
    Send pictures and videos to your smartphone or tablet to upload on Facebook or Twitter.
  • Two movies in one with dual video recording
    Record in two formats at the same time. Film in AVCHD for high-quality footage or MP4 for easy sharing online.
  • Target only the sound of your subject
    With my voice canceling; you can quieten your voice behind the camera while maintaining the volume of your subject and background.
  • Capture detailed 5.1-channel surround sound
    Give your movies audio with depth and detail using a high-quality built-in microphone.
  • Review and replay instantly
    See what you've captured on the 7.5 cm (3 inches) LCD screen with 460K resolution and a wide viewing angle.
  • Add even more to your shooting
    Attach camera accessories like external flashes and microphones to the multi interface shoe.
Sony Handycam HDR-PJ530E - camcorder - storage: flash card
Camcorder - 1080p with projector
Built-in Projector
nHD - 640 x 360 - 25 ANSI lumens
Media Type
Flash card
Memory Card Slot
Memory Stick Micro (M2) card, microSD card
Image Processor
BIONZ X
Wireless Interface
Wireless LAN, NFC
Sensor Resolution
2.51 MP
Effective Sensor Resolution
Video: 2.29 MP - Photo: 2.29 MP
Lens System
Zoom lens - 30x zoom - 1.9 - 57 mm - f/1.8-4.0 G
Focus Adjustment
Automatic, manual
Digital Zoom
350x
Image Stabiliser
Optical (Balanced Steady Shot with Active Mode)
Display
LCD display - 3"
Supported Battery
Sony NP-FV50 Li-ion rechargeable battery (included)
Composite video/audio, HDMI, USB 2.0
Microsoft Certification
Compatible with Windows 7
6.15 cm x 12.1 cm x 6.65 cm
325 g
Enclosure Colour
Camcorder Type
Consumer
Camcorder Sensor Resolution
2.51 MP
Sensor Qty
1 CMOS
Effective Video Resolution
2.29 MP
Effective Photo Resolution
2.29 MP
Camcorder Interpolated Photo Resolution
9.2 MP
Widescreen Video Capture
Camcorder Media Type
Flash card
Optical Sensor Type
Exmor R CMOS
Optical Sensor Size
1/5.8"
Optical Zoom
30x
Digital Zoom
350x
Video Recording Modes
LP, FH, HQ, FX, PS
Image Processor
BIONZ X
Image Stabiliser
Built-in Optical Image Stabiliser
Face Detection
Surround Sound
Dolby Digital 5.1 channel recording, Dolby Digital 5.1 Creator
Print Standard
Exif Print support
Auto Focus
TTL contrast detection
Face Detection
Face Detection AF/AE/FE/WB, Smile Shutter, Child Priority, Adult Priority
Digital Video Format
AVCHD, H.264
Image Recording Format
JPEG
Composite video/audio, HDMI, USB 2.0, Wireless LAN, NFC (Near Field Communication)
Connectivity Features
Remote control via mobile devices
Exposure & White Balance
Min Illumination
3 lux
Exposure Modes
Programme, automatic
Shooting Programs
Spotlight, landscape, portrait mode, fireworks, night scene, beach, snow, sunrise & sunset
White Balance
Custom, automatic, presets
White Balance Presets
Indoor, outdoor
Max Shutter Speed
1/10000 sec
Min Shutter Speed
1/6 sec
Lens System
Focal Length Equivalent to 35mm Camera
26.8 - 804mm
Focus Adjustment
Automatic, manual
Zoom Adjustment
Motorised drive
Filter Size
46 mm
Built-in lens shield
Additional Features
Low Lux / Night Mode
Additional Features
Built-in speaker, Backlight Compensation (BLC), digital noise reduction, date/time stamp, accessories hot shoe, takes photos while film recording, Dynamic Range Optimizer, USB charging, Intelligent AUTO (iAUTO), built-in USB plug, Clear Image Zoom, BRAVIA Sync function, simultaneous multi-format recording
Display
3" LCD display
Display Format
460,000 pixels
Display Form Factor
Rotating
Touch Screen
Display Features
Display brightness control
Built-in Projector
Max Image Brightness
25 ANSI lumens
Max Image Size
254 cm
Resolution
nHD - 640 x 360
Microphone
Microphone Operation Mode
Surround
Microphone Features
My Voice Cancelling
Connector Type
USB 2.0 , Composite video/audio output , HDMI output , Headphones , Microphone
Software
Software
Sony PlayMemories Home
AC power adaptor, HDMI cable, USB extension cable
Battery Type
Sony NP-FV50 Lithium Ion
Details
Battery Life Details
Projection - 1.6 hours
Memory / Storage
Memory Card Slot
Supported Memory Cards
microSD Card, microSDHC Card, Memory Stick Micro Mark2, microSDXC Card
Image Storage
JPEG 4032 x 2272 , JPEG 3024 x 2272
Video Capture
AVCHD - 1920 x 1080 - 50 fps - 28Mbps , AVCHD - 1920 x 1080 - 50 fps - 24Mbps , AVCHD - 1920 x 1080 - 50 fps - 17Mbps , AVCHD - 1440 x 1080 - 50 fps - 9Mbps , AVCHD - 1440 x 1080 - 50 fps - 5Mbps , H.264 - 1280 x 720 - 25 fps - 3Mbps
6.15 cm
12.1 cm
6.65 cm
325 g
