This compact 270 mm wide DVD player fits neatly into the smallest space but gives you multi-format playback of your discs. Plus, it connects simply to your Hi-Fi system, to quickly upgrade the sound of your movie. Its compact size makes this the perfect DVD player for kitchen or bedroom. It can play multi-format movies, music and photos. Now you can enjoy fast playback with recognizable sound to add to your viewing enjoyment. You can also playback slowly with sound to monitor sports action or listen to a language study program.
Great features in a compact package
This compact 270 mm wide DVD player fits neatly into the smallest space but gives you multi-format playback of your discs. Plus, it connects simply to your Hi-Fi system, to quickly upgrade the sound of your movie. -
Delivers quality DVD sound and pictures in a small, versatile package
Its compact size makes this the perfect DVD player for kitchen or bedroom. It can play multi-format movies, music and photos. -
Fast or slow playback of movies with sound
- Sony DVP-SR170 - DVD player
- Product Type
- DVD player
- 27 cm x 20.7 cm x 3.85 cm
- 950 g
- Media Type
- CD-R, CD-RW, SVCD, DVD-R, DVD+RW, DVD-RW, DVD+R, DVD+R DL, DVD-R DL, CD-DA
- Media Format
- NTSC, PAL
- Video D/A Converter
- 12bit / 108MHz
- Remote Control
- Remote control - infrared
- Sound Output Mode
- Stereo
- Power
- AC 230V (50/60 Hz)
- Form Factor
- Tabletop
- Product Type
- DVD player
- Form Factor
- Tabletop
- 27 cm
- 20.7 cm
- 3.85 cm
- 950 g
DVD
- Media Type
- Media Format
- NTSC, PAL
- 12bit / 108MHz
- Media Load Type
- Tray
- Video Formats
- MPEG-1, MPEG-4
- Audio Formats
- WMA, AAC, MP3, LPCM
- Photo Formats
- JPEG
Blu-ray & DVD Features
- Parental Lock
- Sharpness control, JPEG photo playback
Audio System
- Sound Output Mode
- Stereo
- Digital Audio Format
- Dolby Digital output, DTS digital output
- Screen saver, CD Text capable, DVD-Text capable, VCD playback
Remote Control
- Remote control
- Remote Control Technology
- Infrared
- Connector Type
- SCART (21 PIN SCART) - rear
- Power Device
- Power supply
- Voltage Required
- Power Consumption Stand by / Sleep
- 0.5 Watt
Sony DVP-SR170 Slim DVD Player - Black
