Sony DualSense Edge Wireless Controller – Midnight Black
Quicklinx: J0X6WS00 Mfr#: 1000045047
Wired / Wireless: Wireless
Compatibility: Sony PlayStation 5
42 In Stock
£157.50 ex VAT
£189.00 inc VAT
Express delivery Order within the next 14 hours for delivery tomorrow
DualSense Edge Midnight Black
Get an edge in gameplay by creating your own custom controls to fit your playstyle. Built with high performance and personalization in mind, the DualSense Edge® wireless controller invites you to craft your own unique gaming experience so you can play your way.
Changeable stick modules and stick caps
Aim and move with precision by swapping in fresh stick modules* so you’re always playing with equipment that’s in great shape. Plus, three types of changeable stick caps help you stay comfortable in-game without sacrificing grip or stability.
Mappable back buttons
The DualSense Edge® wireless controller’s two swappable sets of back buttons can be configured to any other button input, so you’ve always got game-changing actions and essential controls at your fingertips.
Adjustable trigger lengths
Manually set the travel distance of your left and right triggers for an optimal experience with whatever you’re playing. Fast- paced FPS? Set a shorter travel distance to shoot faster on the field. Competitive racer? Set a longer travel distance for precise throttle control on the track.
Remappable buttons
Remap or even deactivate specific button inputs, so you can create a completely personalized control setup that’s ideal for the game at hand. Adjustable stick sensitivity, trigger dead zones, and vibration intensity Configure your stick sensitivity, stick dead zones, and trigger dead zones for finely tuned inputs, and even set your vibration intensity for a completely customized play experience.
Quick-swap control profiles
Once you’ve found your ideal control settings, you can save them to unique profiles and swap between them on-the-fly, so your favourite configurations are always ready when you are.
On-controller user interface
Quickly swap between your pre-set control profiles and adjust game volume and chat balance** all from the DualSense Edge® wireless controller’s dedicated function button, allowing you to easily adjust your setup while staying focused on the in-game action. Using the Fn button, you can also instantly access the controller settings menu to easily setup and test new control iterations.
DualSense® wireless controller features built in
Enjoy all the immersive features of the DualSense® wireless controller, including haptic feedback, adaptive triggers*, a built- in microphone, motion controls and more in supported titles.
Signature comfort and slip-resistant inner grips
Enjoy the same signature comfort of the original DualSense® wireless controller, now enhanced with slip-resistant inner grips. Ideal for long sessions in single player games and staying comfortable during intense competitive play.
Ready for high-stakes play
Play with confidence in your connection using the included USB Type-C® braided cable featuring a connector housing that locks your USB in place so it's much less likely to slip out at a crucial moment.
Made with input from developers and pro players
Designed in collaboration with pro gamers and game developers, the DualSense Edge® wireless controller leverages powerful insights to offer new tactical options and enhancements for your favourite games.
Carrying Case
Keep your DualSense Edge® wireless controller and its components together and organized in one spot with an included Carrying Case. You can even charge the controller via USB connection while it's stored in the case to make sure you're always ready for your next play session.
Quick access profile settings menu
Simply press the Fn button and Options button while in game to open the customization menu, where you can quickly change your settings.
DualSense® charging station
Conveniently charge your DualSense Edge® wireless controller with the official DualSense® charging station. Easily dock your new controller with the charging station’s click-in design which supports both the DualSense® and DualSense Edge® wireless controller.
*Sold separately. Analog audio connection to headset required for full compatibility. *Haptic feedback and adaptive trigger features available when supported by game. Legal Information
  • Perfect Your Gameplay
    Find your edge with customizable controls and swappable profiles that can help equip you for anything from pro level tournaments to epic single player adventures.
  • Ultra-customizable controls
    Custom settings make your DualSense Edge wireless controller uniquely yours.
  • Quick access profile settings menu
  • Remappable buttons
    Customize the control layout of your favorite games so the commands you need are always exactly where you want them to be. Save your button configurations to your player profile and switch between them without leaving your game.
  • Adjustable triggers, stick sensitivity and vibration intensity
  • Quick-swap control profiles
    Once you've found your ideal control settings, you can save them to unique profiles and swap between them on-the-fly, so your favorite configurations are always ready when you are.
  • Signature comfort and slip-resistant inner grips
    Enjoy the same signature comfort of the original DualSense wireless controller, enhanced with slip-resistant inner grips. Ideal for long sessions in single player games and staying comfortable during intense competitive play.
Sony DualSense Edge - gamepad - wireless - Bluetooth
Gamepad
Wireless - Bluetooth
Controls
Directional buttons, Create button, Options button, action buttons, D-pad, Right stick / R3 Button, Left stick / L3 Button, PS button, Mute button, R1 Button, L1 Button, R2 Trigger, L2 Trigger, RB button, LB button
Adjustable triggers, adjustable vibration, adjustable stick sensitivity, buttons remap, profile switch, built-in microphone, built-in speaker, headset port, Trigger Effect, Light Bar, built-in USB-C charging port, haptic feedback, Click Mechanism, motion sensor
Midnight black
1-year warranty
Sony PlayStation 5
Gamepad
Controls
USB-C
Midnight black
Rechargeable - Lithium Ion
1500 mAh
Carrying case, USB cable, 2 high dome caps, 2 low dome caps, 2 half dome back buttons, 2 lever back buttons, connector housing, 2 standard caps
325 g
Limited warranty - 1 year
5 °C
35 °C
Sony PlayStation 5
J0X6 Sony Stick Module for DualSense Edge Wireless Controller In Stock £16.66
Used stock
What is used stock?
Accessories Packaging Functional Software Manuals
Ref: J0X6 050967
Condition: Customer return - item has been opened but is in excellent condition
This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is not present or functional  This part of the stock item is present and in good condition  £105.88
Legend
  • This part of the stock item is present and in good conditionThis part of the stock item is present and in good condition
  • This part of the stock item is not present or functionalThis part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standardThis part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.This item has not been tested.
Brand: Sony
Stock Status: Used Stock
