Sony DSC-WX350 18.2MP 20xZoom Camera - White
Quicklinx: 9V23WS00 Mfr#: DSCWX350W.CEH
  • Memory Stick PRO Duo
  • SDHC Memory Card
You can't do this with a smartphone. Snap pin-sharp, 18.2 MP photos from afar with the 20x zoom camera that fits in your pocket. There is also ultra-smooth recording that minimizes shake while shooting on the move, perfect for video lovers. Like taking shots in near darkness but hate disturbing the mood with a flash? The Exmor R CMOS image sensor harnesses lots of light to make candlelit moments really shine.
  • 20x optical/40x clear image zoom G lens
    Get amazingly close with 20x optical zoom plus 40x clear image digital zoom. Most digital zooms use electronic cropping to get closer to the subject, resulting in unsharp images. With clear image zoom the powerful processor compares patterns found in adjacent pixels and creates pixels to match selected patterns, resulting in more realistic, higher-quality images. Clear image zoom doubles optical zoom for closer photos.
  • Shoot incredibly smooth video and stills
    Shoot incredibly smooth video and still images with the BIONZ X processor and optical SteadyShot image stabilization with intelligent active mode. When the processor and image stabilization technology work together they deliver sharp image quality with low noise and minimal blur even while the user is strolling and the camera is zoomed in.
  • Keep your subject in focus with lock-on AF
    Lock-on AF gives you the ability to focus on multiple points with subject recognition to keep your subject in sharp focus even when in motion.
  • Simple connectivity to smartphones via Wi-Fi or NFC
    Connectivity with smartphones for one-touch sharing/one-touch remote has been simplified with Wi-Fi/NFC3 control. In addition to Wi-Fi support for connecting to smartphones, the camera also supports NFC (near field communication) providing "one touch connection" convenience when transferring images to Android smartphones and tablets. Users need only touch devices to connect; no complex set-up is required. Moreover, when using smart remote control - a feature that allows shutter release to be controlled by a smartphone - connection to the smartphone can be established by simply touching compatible devices.
  • Motion-shot video traces subject movement
    Motion-shot video traces subject movement on the camera's LCD for a unique visual effect. Use this playback function on the camera to study form and pathways of subjects.
  • 4k quality still image output via HDMI
    Enjoy the beauty of 4k quality still image (4x the resolution of Full HD) via simple HDMI connection to compatible 4k TVs. The camera can also be connected via HDMI to HDTVs for full HD 1080p resolution images.
  • Sweep panorama mode (up to 360°)
    Reach beyond the traditional wide angle lens, and capture more breathtaking shots with sweep panorama mode. Simply press the shutter button and sweep the camera in the desired direction and the camera continuously shoots at a high speed, then seamlessly stitches the images together with automatic position adjustment to create one stunning panoramic image. Available in wide and up to 360° full circle, the camera can take a variety of panoramic shots. Now capturing wide landscapes is as easy as press and sweep.
  • Picture effect for more expressive photos
    Picture effect adds a new level of expression to photos, making ordinary landscapes and portraits come to life by heightening mood and emphasizing certain attributes. Select camera models have up to nine different effects.
Sony Cyber-shot DSC-WX350 - digital camera
Digital camera - compact
Memory Card Slot
Memory Stick PRO Duo card, SD card
Image Processor
BIONZ X
Wireless Interface
Wi-Fi, NFC
Sensor Resolution
18.2 Megapixel
Max Video Resolution
1920 x 1080
Lens System
Zoom lens - 20x zoom - 4.3 - 86 mm - f/3.5-6.5 G
Focus Adjustment
Automatic
Min Focus Distance
5 cm
Image Stabiliser
Optical (Steady Shot with Intelligent Active Mode)
Camera Flash
Built-in flash
Display
LCD display - 3"
Supported Battery
Sony NP-BX1 Li-ion rechargeable battery - 1240 mAh (included)
HDMI, USB 2.0
Microsoft Certification
Compatible with Windows 7
White
9.6 cm x 2.57 cm x 5.49 cm
137 g
Enclosure Colour
White
Sensor Resolution
18.2 Megapixel
Optical Sensor Type
Exmor R CMOS
Total Pixels
21,100,000 pixels
Effective Sensor Resolution
18,200,000 pixels
Optical Sensor Size
1/2.3"
ISO (Max)
12800
Optical Zoom
20x
Image Processor
BIONZ X
Image Stabiliser
Built-in Optical Image Stabiliser
Face Detection
Print Standard
DPOF support, Exif Print support, PRINT Image Matching
Auto Focus
TTL contrast detection
Face Detection
Face-priority AF function, Smile Shutter
Digital Video Format
AVCHD, H.264
Image Recording Format
JPEG
1920 x 1080
HDMI, USB 2.0, IEEE 802.11b/g/n, NFC (Near Field Communication)
Exposure & White Balance
Light Sensitivity
ISO 100, ISO 800, ISO 400, ISO 200, ISO 80, ISO 1600, ISO 6400, ISO 3200, ISO auto (80-1600), ISO 12800
Exposure Metering
Multi-segment, centre-weighted, spot
Exposure Modes
Programme, automatic
Shooting Programs
Landscape, portrait mode, night portrait, PET, fireworks, night scene, beach, snow, high sensitivity, soft skin, handheld twilight, gourmet, anti-motion blur, backlight correction HDR
Special Effects
Soft focus, illustration, Water Colour, miniature, Retro, partial colour, Toy camera, Posterisation, High contrast monochrome, Pop Colour, HDR Painting, Rich-tone monochrome, Soft High-key
White Balance
Custom, automatic, presets
White Balance Presets
Incandescent, cloudy, Flash, daylight, fluorescent light (cool white), fluorescent light (daylight), fluorescent light (daylight white)
Max Shutter Speed
1/1600 sec
Min Shutter Speed
4 sec
Exposure Compensation
±2 EV range, in 1/3 EV steps
Lens System
Focal Length Equivalent to 35mm Camera
25 - 500mm
Focus Adjustment
Automatic
Min Focus Distance
5 cm
Macro Focus Range
5cm
Zoom Adjustment
Motorised drive
Lens Construction
10 groups / 11 elements
Built-in lens shield, aspherical lens
Camera Flash
Camera Flash
Built-in flash
Flash Modes
Fill-in mode, slow synchro, auto mode, flash OFF mode, red-eye reduction
Red-Eye Reduction
AF illuminator
Effective Flash Range
0.2 m - 4.3 m: ISO auto (wide lens) , 2 m - 2.4 m: ISO auto (tele lens) , 6.1 m: ISO 3200 (wide lens) , 3.4 m: ISO 3200 (tele lens)
Additional Features
Continuous Shooting Speed
10 frames per second for 10 frames
Self-Timer Delay
10 sec, 2sec
Additional Features
Histogram display, takes photos while film recording, USB charging, built-in help guide, Intelligent AUTO (iAUTO), Superior Auto mode, BRAVIA Sync function, Intelligent Sweep Panorama (360)
Display
3" LCD display
Display Format
460,800 pixels
Display Form Factor
Built-in
Display Features
Display brightness control
Microphone
Microphone Operation Mode
Stereo
Microphone Features
Wind noise reduction
Connector Type
USB 2.0 , HDMI output
AC power adaptor, wrist strap, micro-USB cable
Battery Type
Sony NP-BX1 Lithium Ion
Details
Battery Life Details
Photo shooting - 470 shots , Playback - 3.9 hours
Memory / Storage
Memory Card Slot
Supported Memory Cards
Memory Stick Duo, SD Memory Card, Memory Stick PRO Duo, SDXC Memory Card, Memory Stick PRO Duo Mark2, SDHC Memory Card, Memory Stick PRO-HG Duo, Memory Stick XC-HG Duo
Image Storage
JPEG 4896 x 3672 , JPEG 4896 x 3264 , JPEG 4896 x 2752 , JPEG 3648 x 2736 , JPEG 3648 x 2432 , JPEG 3648 x 2056 , JPEG 2592 x 1944 , JPEG 2592 x 1728 , JPEG 1920 x 1080 , JPEG 640 x 480 , JPEG 3664 x 3664 , JPEG 2736 x 2736 , JPEG 1920 x 1920
Video Capture
AVCHD - 1920 x 1080 - 50 fps - 28Mbps , AVCHD - 1920 x 1080 - 50 fps - 24Mbps , AVCHD - 1920 x 1080 - 50 fps - 17Mbps , H.264 - 1440 x 1080 - 25 fps - 12Mbps , H.264 - 640 x 480 - 25 fps - 3Mbps
9.6 cm
2.57 cm
5.49 cm
137 g
