Sony DCR-SX33 Blue Camcorder
Quicklinx: 6MYCWS00 Mfr#: DCRSX33EL.CEH
  • Memory Stick PRO Duo Mark2
  • SDHC Memory Card
Marketing description is not available.
  • 60x optical zoom with SteadyShot
    Vario-Tessar lens with ultra-powerful optical zoom range to pull distant objects closer.
  • Recording on memory card
    Up to 23 hours 55 mins standard definition video shooting time on removable memory card.
  • Face detection
    Enhanced face detection for clear, natural faces. Now recognizes up to 8 faces in scene.
  • 800k CCD sensor
    Increased sensitivity captures crisp, clear video with improved low-light image quality (min. illumination 3lux).
  • SteadyShot
    Electronic image stabilization reduces effects of camera shake during handheld shooting.
  • 6.7cm/2.7" wide clear photo LCD
    High quality 230k dot resolution wide touchscreen for viewing shots and controlling functions.
  • Power on by LCD
    Quick start-up from standby with ultra-low power consumption in sleep mode.
  • Video light
    Illuminate your subject for great results at parties, indoor shooting and night-time scenes.
  • Direct copy
    Transfer video footage direct to an external hard disk drive without PC: playback with fun camcorder features.
  • DVDirect express compatibility
    PC-free burning to AVCHD or Standard Definition DVD discs with compatible Sony DVDirect Express writer.
  • Stereo sound
    Crisp, clear digital stereo sound recording.
  • Face index and film roll index
    Find the right scene with quick, easy searches through camcorder footage.
  • Works with iMovie
    Connect Handycam directly to Macintosh computer via USB and import videos directly for editing with iMovie.
Sony Handycam DCR-SX33E - camcorder - Carl Zeiss - storage: flash card
Camcorder - widescreen
Lens Included
Carl Zeiss
Media Type
Flash card
Memory Card Slot
Memory Stick PRO Duo card, SD card
Sensor Resolution
800 KP
Effective Sensor Resolution
Video: 490 KP - Photo: 0.41 MP
Lens System
Zoom lens - 60x zoom - 1.8 - 108 mm - f/1.8-6.0
Focus Adjustment
Automatic, manual
Digital Zoom
2000x
Image Stabiliser
Electronic (Steady Shot)
Display
LCD display - 2.7"
Supported Battery
1 x Li-ion rechargeable battery (included)
Composite video/audio, S-Video, USB 2.0
Blue
5 cm x 10.3 cm x 5.5 cm
190 g
Camcorder
Lens Included
Carl Zeiss
Enclosure Colour
Blue
Camcorder Type
Consumer
Camcorder Sensor Resolution
800 KP
Sensor Qty
1 CCD
Effective Video Resolution
490 KP
Effective Photo Resolution
0.41 MP
Widescreen Video Capture
Camcorder Media Type
Flash card
Optical Sensor Type
Advanced HAD CCD
Optical Sensor Size
1/8"
Optical Zoom
60x
Digital Zoom
2000x
Video Recording Modes
SP, LP, HQ
Faders
White fader, black fader
Image Stabiliser
Face Detection
Surround Sound
Dolby Digital AC-3 (2 channel) recording
Print Standard
Direct print, PictBridge support
Digital Video Format
MPEG-2
Image Recording Format
JPEG
Exposure & White Balance
Min Illumination
3 lux
Exposure Modes
Programme, automatic
Shooting Programs
Spotlight, landscape, portrait mode, twilight portrait, fireworks, twilight mode, sunset, candle, beach, snow, sunrise
White Balance
Custom, automatic, presets
White Balance Presets
Indoor, outdoor
Max Shutter Speed
1/3500 sec
Min Shutter Speed
1/3 sec
Lens System
Carl Zeiss zoom lens - 60x zoom - 1.8 - 108 mm - f/1.8-6.0
Focus Adjustment
Automatic, manual
Zoom Adjustment
Motorised drive
Filter Size
30 mm
Built-in lens shield
Additional Features
Built-in Light
Low Lux / Night Mode
Additional Features
Built-in speaker, backlight compensation, digital noise reduction, face detection
Display
2.7" LCD display
Display Format
230,400 pixels
Display Form Factor
Rotating
Touch Screen
Microphone
Microphone Operation Mode
Stereo
Microphone Features
Zoom
Connector Type
Composite video/audio output , USB , S-Video output
Software
Software
Drivers & Utilities, Sony Picture Motion Browser
Power adapter, USB cable, audio / video cable
Battery Type
Sony NP-FV30 Lithium Ion - manufacturer-specific
Details
Memory / Storage
Memory Card Slot
Supported Memory Cards
Memory Stick Duo, SD Memory Card, Memory Stick PRO Duo, Memory Stick PRO Duo Mark2, SDHC Memory Card, Memory Stick PRO-HG Duo
Image Storage
JPEG 640 x 480
5 cm
10.3 cm
5.5 cm
190 g
