Sony Cybershot DSC-S930 Pink
Quicklinx: 5H4RWS00 Mfr#: DSCS930P.CEH
  • Memory Stick Duo
Excellent value, easy to use camera with high 10.1 megapixel resolution. Features 3x optical zoom lens, 2.4-inch screen, face detection and SteadyShot.
Sony Cyber-shot DSC-S930 - digital camera
Digital camera - compact
Memory Card Slot
Memory Stick PRO Duo card
Sensor Resolution
10.1 Megapixel
Lens System
Zoom lens - 3x zoom - 6.4 - 19.2 mm - f/2.9-5.4
Focus Adjustment
Automatic, manual
Digital Zoom
2x
Image Stabiliser
Electronic (Steady Shot)
Camera Flash
Built-in flash
Display
LCD display - 2.4"
Supported Battery
2 x AA alkaline battery (included)
Composite video/audio, USB 2.0
Pink
9 cm x 2.6 cm x 6.1 cm
118 g
Enclosure Colour
Pink
Sensor Resolution
10.1 Megapixel
Optical Sensor Type
Super HAD CCD
Effective Sensor Resolution
10,100,000 pixels
Optical Sensor Size
1/2.3"
ISO (Max)
3200
Optical Zoom
3x
Digital Zoom
2x
Image Stabiliser
Face Detection
Print Standard
Direct print, DPOF support, PictBridge support, PRINT Image Matching
Auto Focus
TTL contrast detection
Digital Video Format
MJPEG
Image Recording Format
JPEG
Exposure & White Balance
Light Sensitivity
ISO 100, ISO 800, ISO 400, ISO 200, ISO 1600, ISO 3200, ISO auto
Exposure Metering
Multi-segment, centre-weighted, spot
Exposure Modes
Programme, automatic
Shooting Programs
Landscape, portrait mode, twilight portrait, backlight, soft snap, twilight mode, beach, backlight portrait, snow
Special Effects
Black & White, Sepia
White Balance
Automatic, presets
White Balance Presets
Incandescent, cloudy, Flash, daylight, fluorescent light (cool white), fluorescent light (daylight), fluorescent light (warm white)
Max Shutter Speed
1/2000 sec
Min Shutter Speed
1/8 sec
Exposure Compensation
±2 EV range, in 1/3 EV steps
Lens System
Focal Length Equivalent to 35mm Camera
36 - 108mm
Focus Adjustment
Automatic, manual
Macro Focus Range
5cm
Zoom Adjustment
Motorised drive
Built-in lens shield
Camera Flash
Camera Flash
Built-in flash
Flash Modes
Fill-in mode, slow synchro, auto mode, flash OFF mode, red-eye reduction
Red-Eye Reduction
Effective Flash Range
0.5 m - 3 m
Additional Features
Additional Features
Audio recording, built-in speaker, auto power save, digital image rotation, camera orientation detection, histogram display, in-camera red-eye removal, cropping an image
Display
2.4" LCD display
Display Format
112,320 pixels
Display Form Factor
Built-in
Microphone
Microphone Operation Mode
Mono
Connector Type
USB , Composite video/audio output
Software
Software
Drivers & Utilities, Sony Picture Motion Browser
USB cable, wrist strap, audio / video cable
Battery Type
AA - Alkaline - standard form factor
Details
Memory / Storage
RAM Installed
12 MB
Memory Card Slot
Supported Memory Cards
Memory Stick Duo, Memory Stick PRO Duo, Memory Stick PRO-HG Duo
Image Storage
JPEG 3648 x 2736 , JPEG 3648 x 2432 , JPEG 3648 x 2056 , JPEG 2592 x 1944 , JPEG 2048 x 1536 , JPEG 1920 x 1080 , JPEG 640 x 480
Video Capture
MPEG - 320 x 240 - 30 fps
9 cm
2.6 cm
6.1 cm
118 g
Resources
The following resources are available for the Sony Cybershot DSC-S930 Pink
