Excellent value, easy to use camera with high 10.1 megapixel resolution. Features 3x optical zoom lens, 2.4-inch screen, face detection and SteadyShot.
- Sony Cyber-shot DSC-S930 - digital camera
- Product Type
- Digital camera - compact
- Memory Card Slot
- Memory Stick PRO Duo card
- Sensor Resolution
- 10.1 Megapixel
- Lens System
- Zoom lens - 3x zoom - 6.4 - 19.2 mm - f/2.9-5.4
- Focus Adjustment
- Automatic, manual
- Digital Zoom
- 2x
- Image Stabiliser
- Electronic (Steady Shot)
- Camera Flash
- Built-in flash
- Display
- LCD display - 2.4"
- Supported Battery
- 2 x AA alkaline battery (included)
- Interface
- Composite video/audio, USB 2.0
- Pink
- 9 cm x 2.6 cm x 6.1 cm
- 118 g
- Product Type
- Enclosure Colour
- Pink
- Sensor Resolution
- 10.1 Megapixel
- Optical Sensor Type
- Super HAD CCD
- Effective Sensor Resolution
- 10,100,000 pixels
- Optical Sensor Size
- 1/2.3"
- ISO (Max)
- 3200
- Optical Zoom
- 3x
- Digital Zoom
- 2x
- Image Stabiliser
- Face Detection
- Print Standard
- Direct print, DPOF support, PictBridge support, PRINT Image Matching
- Auto Focus
- TTL contrast detection
- Digital Video Format
- MJPEG
- Image Recording Format
- JPEG
- Interface
Exposure & White Balance
- Light Sensitivity
- ISO 100, ISO 800, ISO 400, ISO 200, ISO 1600, ISO 3200, ISO auto
- Exposure Metering
- Multi-segment, centre-weighted, spot
- Exposure Modes
- Programme, automatic
- Shooting Programs
- Landscape, portrait mode, twilight portrait, backlight, soft snap, twilight mode, beach, backlight portrait, snow
- Special Effects
- Black & White, Sepia
- White Balance
- Automatic, presets
- White Balance Presets
- Incandescent, cloudy, Flash, daylight, fluorescent light (cool white), fluorescent light (daylight), fluorescent light (warm white)
- Max Shutter Speed
- 1/2000 sec
- Min Shutter Speed
- 1/8 sec
- Exposure Compensation
- ±2 EV range, in 1/3 EV steps
Lens System
- Focal Length Equivalent to 35mm Camera
- 36 - 108mm
- Focus Adjustment
- Automatic, manual
- Macro Focus Range
- 5cm
- Zoom Adjustment
- Motorised drive
- Built-in lens shield
Camera Flash
- Camera Flash
- Built-in flash
- Flash Modes
- Fill-in mode, slow synchro, auto mode, flash OFF mode, red-eye reduction
- Red-Eye Reduction
- Effective Flash Range
- 0.5 m - 3 m
Additional Features
- Additional Features
- Audio recording, built-in speaker, auto power save, digital image rotation, camera orientation detection, histogram display, in-camera red-eye removal, cropping an image
Display
- 2.4" LCD display
- Display Format
- 112,320 pixels
- Display Form Factor
- Built-in
Microphone
- Microphone Operation Mode
- Mono
- Connector Type
- USB , Composite video/audio output
Software
- Software
- Drivers & Utilities, Sony Picture Motion Browser
- Included Accessories
- USB cable, wrist strap, audio / video cable
- Battery Type
- AA - Alkaline - standard form factor
- Details
Memory / Storage
- RAM Installed
- 12 MB
- Memory Card Slot
- Supported Memory Cards
- Memory Stick Duo, Memory Stick PRO Duo, Memory Stick PRO-HG Duo
- Image Storage
- JPEG 3648 x 2736 , JPEG 3648 x 2432 , JPEG 3648 x 2056 , JPEG 2592 x 1944 , JPEG 2048 x 1536 , JPEG 1920 x 1080 , JPEG 640 x 480
- Video Capture
- MPEG - 320 x 240 - 30 fps
- 9 cm
- 2.6 cm
- 6.1 cm
- 118 g
- 0 °C
- 40 °C
