With advanced technologies to make everything you watch sharper, smoother and more lifelike, the BRAVIA difference is clear.
Share photos, videos and more wirelessly in an instant with NFC, and MHL connectivity.
Make your listening as lifelike as your viewing. ClearAudio+ fine-tunes TV sound for an immersive, emotionally enriching experience that seems to surround you. Hear music, dialog and surround effects with greater clarity and separation, whatever you're watching.
See how good TV can look
With advanced technologies to make everything you watch sharper, smoother and more lifelike, the BRAVIA difference is clear. -
See it all on your TV
Share photos, videos and more wirelessly in an instant with NFC, and MHL connectivity. -
Made to listen
Make your listening as lifelike as your viewing. ClearAudio+ fine-tunes TV sound for an immersive, emotionally enriching experience that seems to surround you. Hear music, dialog and surround effects with greater clarity and separation, whatever you're watching. -
Immerse yourself in 3D
Enjoy compatible Blu-ray movies, TV broadcasts, and web videos with finely detailed 3D images. See pictures with a more natural depth of field and immerse yourself in sport, movies, and games like never before. You can also connect to a 3D Blu-ray Disc player and enjoy 2D video upscaled to simulated 3D with enhanced depth and improved on-screen image detail. -
Turn your TV into a digital recorder: USB HDD REC
Store your favorite TV shows on an external USB hard disk drive to enjoy whenever you want. USB HDD REC allows one-touch and timer recording of a digital broadcast onto any USB HDD device up to 2TB in capacity. While viewing the show, simply press REC to start recording, which will automatically stop at the end of the program.
- Sony Bravia KDL-75W855C W855C Series - 75" LED-backlit LCD TV - Full HD
- Product Type
- LED-backlit LCD TV - Smart TV
- Diagonal Class
- 75"
- Black
- 3D
- 3D Technology
- Active
- Platform
- Android TV
- Resolution
- 1920 x 1080
- Display Format
- 1080p
- Input Video Formats
- 1080/24p, 1080/60i, 480/60p, 720/60p, 1080/50i, 576/50p, 1080/50p, 1080/60p, 1080/30p, 480/60i, 576/50i, 720/24p, 720/30p
- Frame Rate & Enhancement Technology
- Motionflow XR 800
- 24p Technology
- 24p True Cinema
- Video Interface
- Component, composite, HDMI, SCART
- HDMI Ports Qty
- 4 ports
- Connectivity
- Wi-Fi, LAN, Bluetooth
- PC Interface
- Mobile High-Definition Link (MHL)
- HDCP Compatible
- LCD Backlight Technology
- Direct-lit LED
- Image Aspect Ratio
- 16:9
- TV Tuner
- 1x analogue, 1x digital
- Digital TV Tuner
- DVB-C, DVB-S, DVB-S2, DVB-T, DVB-T2
- Internet Streaming Services
- Google Play
- Multi-channel Preview
- Picture-and-picture (PAP)
- Speaker System
- 2 speakers
- Sound Effects
- S-FORCE Front Surround Sound
- Stereo Reception System
- NICAM, A2
- USB
- 3 ports
- Included Accessories
- Sony RMT-TX100D remote control, batteries
- Energy Class
- Class A+
- 297 Watt
- Power Consumption (On mode)
- 163 W
- Power Consumption Stand by
- 0.5 Watt
- Energy Consumption per Year
- 226 kWh
- Dimensions (WxDxH) - without stand
- 167.7 cm x 7.9 cm x 96.9 cm
- 33.7 kg
- Product Type
- Energy Class
- Class A+
- 297 Watt
- 163 W
- 226 kWh
- Diagonal Class
- 75"
- Series
- W855C Series
- 3D
- 3D Technology
- Active
- Platform
- Android TV
- TV Tuner
- TV Tuner Presence
- Sensors
- Light sensor
- Video Interface
- HDMI Ports Qty
- 4 ports
- PC Interface
- HDCP Compatible
- Modes
- Film Mode, backlight off mode, Live Football Mode
- Timer Functions
- Sleep, wake
- Dimensions
- Without stand
- 167.7 cm
- 7.9 cm
- 96.9 cm
- 33.7 kg
- Enclosure Colour
- Black
Display
- Resolution
- 1920 x 1080
- Display Format
- 1080p
- 16:9
- Motionflow XR 800
- 24p Technology
- 24p True Cinema
- Direct-lit LED
- Widescreen Modes
- Zoom 14:9, Auto Wide, Full, Wide Zoom, Zoom, Normal
- Viewing Angle
- 178 degrees
- Viewing Angle (Vertical)
- 178 degrees
- Advanced Contrast Enhancer circuit (ACE), i-Manual, X-Reality PRO Engine, Tv SideView, CineMotion, Cinema Drive, Dynamic Backlight Control, One-Flick Entertainment
Stands & Mounts
- Stand
- Included
- Stand Design
- Tabletop
- Stand Colour
- Silver mirror
- Flat Panel Mount Interface
TV Tuner
- Conditional Access
- Common Interface Plus (CI+) slot
- NICAM, A2
Digital TV Tuner
- Digital TV Tuner
- HDTV Tuner
Video Features
- Electronic Programme Guide
- Digital EPG
- Parental Channel Lock
Media Player
- USB Port
- USB Ports Qty
- 3
Remote Control
- Remote control
- Remote Control Model
- Sony RMT-TX100D
- Scene Select
Audio System
- Digital Audio Format
- Dolby Digital output, Dolby Digital Plus output, Dolby Pulse output
- Surround Mode
- Sound Effects
- Audio Controls
- Sound mode
- Speaker System
- 2 speakers
- Output Power / Total
- 20 Watt
- S-Master Digital Amplifier, Clear Phase Speaker, Digital Sound Enhancement Engine (DSEE), Long Duct Speaker, Clear Audio+, Bass Reflex Speaker System, Google Cast support
- Speakers
- 2 x main channel speaker - 10 Watt
Network & Internet Multimedia
- Functionality
- Digital audio playback, digital photo playback, digital video playback, WEB browsing, Internet video playback
- Connectivity
- LAN Protocol
- Ethernet
- Connect & Share
- Wi-Fi Direct, Screen Mirroring
- Google Play
- Supported Consumer Electronics Control (CEC)
- BRAVIA Sync Function
- DLNA
- Connector Type
- 4 x HDMI input , SCART - rear , 3 x USB , LAN - rear , Composite video / component video input , Audio line-in , SPDIF output - rear , Audio line-out / headphones / subwoofer - side
- Batteries
- Power Device
- Power supply
- 0.5 Watt
Dimensions & Weight Details
- Dimensions & Weight Details
- Panel without stand - 167.7 cm x 7.9 cm x 96.9 cm x 33.7 kg , Panel with stand - 167.7 cm x 33 cm x 101.6 cm x 34.9 kg
- Width (Shipping)
- 177.5 cm
- Depth (Shipping)
- 22.4 cm
- Height (Shipping)
- 106.8 cm
