Slim, easy-to-use the FW-43BZ30L professional displays add impact to all your visual communications in retail, corporate and educational environments. Superb 4K HDR picture quality is complemented by flexible customization options and pro-friendly features for easy integration, setup and content sharing in the connected AV environments.
The 43" FW-43BZ30L offers a generous high screen brightness. Advanced Sony picture processing technologies ensure your content looks its very best. The panel's extra-wide viewing angle ensures that everyone in the room can enjoy clear, bright images wherever they're positioned.
Richer, more natural color
Sony's power-packed 4K HDR Processor X1 and TRILUMINOS Pro technology faithfully reproduces a phenomenal range of rich, true-to-life colors. -
Finer detail
4K X-Reality PRO processing upscales pictures closer to true 4K quality. Images are sharpened and refined in real time, revealing extra detail from lower-resolution picture sources. -
Smoother movement
Motionflow XR ensures smoother, more natural reproduction of rapidly-moving on-screen images. -
Installation flexibility to suit every environment
The sleek, minimal design of the FW-43BZ30L brings impeccable style to any business environment. The display's elegant lines are further enhanced by practical touches for seamless integration in retail stores, colleges and corporate workspaces. -
Wall-mount adjuster
BRAVIA comes supplied with a wall-mount adjuster, giving extra flexibility for mounting the display centrally in portrait or landscape orientation. -
Side mounted interfaces
Signal connections, networking and other interfaces are conveniently side mounted for easy installation and access when the display's in portrait position. -
Discreet logo
The Sony logo is discreetly positioned on the edge of the display's bezel - with nothing distracting your audience from immersive images. -
Landscape, portrait and tilt
Install BRAVIA in portrait or landscape orientation to suit any corporate or retail space. The display can also be tilted at an angle for even greater flexibility. -
Round the clock reliability
Business never sleeps: BRAVIA is engineered for dependable 24/7 operation in the most challenging corporate and commercial environments. -
Special settings for professional use
Pro Settings mode makes doing business even easier, allowing you to customize BRAVIA settings and operating modes to suit the demands of corporate or retail environments. Disable input or remote control functions, schedule on/off times, remove labels and block buttons to avoid tampering when the screen's being used in public spaces. -
Get great pictures fast
Forget fiddling with display settings. One Step Setting offers presets tuned to your environment including meeting room, vivid signage, natural signage and graphics. Just pick a preset: BRAVIA instantly configures picture mode, input, control settings and more. -
Easy integration
FW-43BZ30L is made for the connected world. There's seamless support for the leading automation and control platforms, while open APIs simplify integration with other vendor solutions. -
Wireless screen mirroring
Easily mirror content wirelessly from handheld device onto BRAVIA with in-built support for Apple AirPlay and Google Chromecast.
 - Sony Bravia Professional Displays FW-43BZ30L BZ30L Series - 43" LED-backlit LCD display - 4K - for digital signage
- Product Type
 - LED-backlit LCD flat panel display
- Diagonal Class
 - 43"
- Commercial Use
 - Yes - digital signage
- Platform
 - Android TV
- Resolution
 - 3840 x 2160
- Display Format
 - 4K UHD (2160p)
- Input Video Formats
 - 480p, 720p, 1080i, 1080p, 4K UHD (3840 x 2160), DCI 4K (4096 x 2160)
- HDR Format
 - HDR10, Dolby Vision
- HDR Technology
 - Hybrid Log-Gamma (HLG)
- Frame Rate & Enhancement Technology
 - Motionflow XR 240 technology, 60 Hz Native Refresh Rate
- Video Interface
 - Composite, HDMI
- HDMI Ports Qty
 - 4 ports
- Connectivity
 - Wi-Fi, LAN
- Technology
 - IPS
- LCD Backlight Technology
 - Direct LED frame dimming
- Image Aspect Ratio
 - 16:9
- TV Tuner
 - No tuner
- Commercial Features
 - Software Clock, IPTV, HTML5 support, Multicast ready, HDMI auto wake-up, BRAVIA Signage Free (BSF), Multi Display Setting (MDS)
- Picture Enhancements
 - 4K X-Reality PRO Engine, 92% DCI-P3 colour gamut
- Speaker System
 - 2 speakers
- Storage Capacity
 - 16 GB
- USB
 - 2 ports
- Energy Class
 - Class F
 - 103 Watt
- Power Consumption Stand by
 - 0.5 Watt
- Dimensions (WxDxH) - without stand
 - 97.2 cm x 7 cm x 56.7 cm
 - 10 kg
- Product Type
- Energy Class
 - Class F
- Energy Class (HDR)
 - Class G
 - 103 Watt
- Power Consumption SDR (On mode)
 - 54 kWh/1000h
- Power Consumption HDR (On mode)
 - 67 kWh/1000h
- Diagonal Class
 - 43"
- Commercial Use
- Series
 - BZ30L Series
- Platform
 - Android TV
- Operating System
 - Android TV
- HDR Capable
- HDR Format
- HDR Technology
- Video Processor
 - 4K HDR X1
- TV Tuner
 - No tuner
- TV Tuner Presence
 - No
- Video Interface
 - Composite, HDMI
- HDMI Ports Qty
 - 4 ports
- Modes
 - Portrait mode, power saving mode, Pro Mode
- Dimensions
 - Without stand
 - 97.2 cm
 - 7 cm
 - 56.7 cm
 - 10 kg
Display
- LCD Display Technology
 - IPS
- Resolution
 - 3840 x 2160
- Display Format
 - 4K UHD (2160p)
 - 16:9
 - Direct LED - frame dimming
- Coating
 - 1% haze
- Image Contrast Ratio
 - 1200:1
- Dynamic Contrast Ratio
 - 400000:1
- Brightness
 - 440 cd/m²
- Viewing Angle
 - 178 degrees
- Viewing Angle (Vertical)
 - 178 degrees
- Response Time
 - 8 ms
- Operation Hours / Days
 - 24 / 7
 - Dynamic Backlight Control, sleep timer, Chromecast built-in, Apple AirPlay support, Triluminos Pro Display
Stands & Mounts
- Stand
 - Optional
- Stand Design
 - Tabletop
- Flat Panel Mount Interface
 - 200 x 200 mm
- VESA Compatibility
Video Features
Media Player
- Supported Video Formats
 - MPEG-1, MPEG-2, MPEG-4, Motion-JPEG, Xvid, WMV, ASF, AVI, MKV, MOV, AVCHD, TS, AVC, 3GPP, PS, VC-1, HEVC, VP8, XAVCS, HDV
- Supported Audio Formats
 - MP3, WMA, WAV, AAC, FLAC (Free Lossless Audio Codec), LPCM, ASF
- Supported Pictures Formats
 - JPEG
- USB Port
- USB Ports Qty
 - 2
- Configuration
 - 16 GB
Audio System
- Speaker System
 - 2 speakers
- Output Power / Total
 - 20 Watt
 - Down-firing Speaker
- Speakers
 - 2 x speaker - 10 Watt
Network & Internet Multimedia
- Connectivity
 - Wi-Fi, LAN
- LAN Protocol
 - Ethernet
- Connect & Share
 - Wi-Fi Direct, IP Control
- Connector Type
 - RS-232C , 4 x HDMI - side , Composite video input - side , Audio input - side , 2 x USB - side , LAN - side , Digital audio output (optical) - side
 - CEC, HDCP 2.3
- Power Device
 - Power supply
 - 0.5 Watt
 - On/off timer
Dimensions & Weight Details
- Dimensions & Weight Details
 - Panel without stand - 97.2 cm x 7 cm x 56.7 cm x 10 kg , Panel with stand - 97.2 cm x 28.6 cm x 63.2 cm x 10.5 kg
- Width (Shipping)
 - 107 cm
- Depth (Shipping)
 - 14.1 cm
- Height (Shipping)
 - 69.5 cm
- Weight (Shipping)
 - 14 kg
