Sony Bravia FW-43BZ30L - 43"-4K-5MS-Android-Diagonal Class
Quicklinx: HFX0WS00 Mfr#: FW-43BZ30L
Screen Size: 43in
Screen Resolution: 4K UHD (2160p)
Interface: Composite, HDMI
Energy Class: Class F
More than 50 In Stock
£647.42 ex VAT
£776.90 inc VAT
Slim, easy-to-use the FW-43BZ30L professional displays add impact to all your visual communications in retail, corporate and educational environments. Superb 4K HDR picture quality is complemented by flexible customization options and pro-friendly features for easy integration, setup and content sharing in the connected AV environments.
The 43" FW-43BZ30L offers a generous high screen brightness. Advanced Sony picture processing technologies ensure your content looks its very best. The panel's extra-wide viewing angle ensures that everyone in the room can enjoy clear, bright images wherever they're positioned.
  • Richer, more natural color
    Sony's power-packed 4K HDR Processor X1 and TRILUMINOS Pro technology faithfully reproduces a phenomenal range of rich, true-to-life colors.
  • Finer detail
    4K X-Reality PRO processing upscales pictures closer to true 4K quality. Images are sharpened and refined in real time, revealing extra detail from lower-resolution picture sources.
  • Smoother movement
    Motionflow XR ensures smoother, more natural reproduction of rapidly-moving on-screen images.
  • Installation flexibility to suit every environment
    The sleek, minimal design of the FW-43BZ30L brings impeccable style to any business environment. The display's elegant lines are further enhanced by practical touches for seamless integration in retail stores, colleges and corporate workspaces.
  • Wall-mount adjuster
    BRAVIA comes supplied with a wall-mount adjuster, giving extra flexibility for mounting the display centrally in portrait or landscape orientation.
  • Side mounted interfaces
    Signal connections, networking and other interfaces are conveniently side mounted for easy installation and access when the display's in portrait position.
  • Discreet logo
    The Sony logo is discreetly positioned on the edge of the display's bezel - with nothing distracting your audience from immersive images.
  • Landscape, portrait and tilt
    Install BRAVIA in portrait or landscape orientation to suit any corporate or retail space. The display can also be tilted at an angle for even greater flexibility.
  • Round the clock reliability
    Business never sleeps: BRAVIA is engineered for dependable 24/7 operation in the most challenging corporate and commercial environments.
  • Special settings for professional use
    Pro Settings mode makes doing business even easier, allowing you to customize BRAVIA settings and operating modes to suit the demands of corporate or retail environments. Disable input or remote control functions, schedule on/off times, remove labels and block buttons to avoid tampering when the screen's being used in public spaces.
  • Get great pictures fast
    Forget fiddling with display settings. One Step Setting offers presets tuned to your environment including meeting room, vivid signage, natural signage and graphics. Just pick a preset: BRAVIA instantly configures picture mode, input, control settings and more.
  • Easy integration
    FW-43BZ30L is made for the connected world. There's seamless support for the leading automation and control platforms, while open APIs simplify integration with other vendor solutions.
  • Wireless screen mirroring
    Easily mirror content wirelessly from handheld device onto BRAVIA with in-built support for Apple AirPlay and Google Chromecast.
Sony Bravia Professional Displays FW-43BZ30L BZ30L Series - 43" LED-backlit LCD display - 4K - for digital signage
LED-backlit LCD flat panel display
Diagonal Class
43"
Commercial Use
Yes - digital signage
Platform
Android TV
Resolution
3840 x 2160
Display Format
4K UHD (2160p)
Input Video Formats
480p, 720p, 1080i, 1080p, 4K UHD (3840 x 2160), DCI 4K (4096 x 2160)
HDR Format
HDR10, Dolby Vision
HDR Technology
Hybrid Log-Gamma (HLG)
Frame Rate & Enhancement Technology
Motionflow XR 240 technology, 60 Hz Native Refresh Rate
Video Interface
Composite, HDMI
HDMI Ports Qty
4 ports
Wi-Fi, LAN
IPS
LCD Backlight Technology
Direct LED frame dimming
Image Aspect Ratio
16:9
TV Tuner
No tuner
Commercial Features
Software Clock, IPTV, HTML5 support, Multicast ready, HDMI auto wake-up, BRAVIA Signage Free (BSF), Multi Display Setting (MDS)
Picture Enhancements
4K X-Reality PRO Engine, 92% DCI-P3 colour gamut
Speaker System
2 speakers
Storage Capacity
16 GB
USB
2 ports
Energy Class
Class F
103 Watt
Power Consumption Stand by
0.5 Watt
97.2 cm x 7 cm x 56.7 cm
10 kg
Energy Class
Class F
Energy Class (HDR)
Class G
103 Watt
54 kWh/1000h
Power Consumption HDR (On mode)
67 kWh/1000h
Diagonal Class
43"
Commercial Use
Series
BZ30L Series
Platform
Android TV
Operating System
Android TV
HDR Capable
HDR Format
HDR10, Dolby Vision
HDR Technology
Video Processor
4K HDR X1
TV Tuner
No tuner
TV Tuner Presence
No
Video Interface
Composite, HDMI
HDMI Ports Qty
4 ports
Modes
Portrait mode, power saving mode, Pro Mode
Dimensions
Without stand
97.2 cm
7 cm
56.7 cm
10 kg
Display
LCD Display Technology
IPS
Resolution
3840 x 2160
Display Format
4K UHD (2160p)
Image Aspect Ratio
16:9
Direct LED - frame dimming
Coating
1% haze
Image Contrast Ratio
1200:1
Dynamic Contrast Ratio
400000:1
Brightness
440 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Response Time
8 ms
Commercial Features
Operation Hours / Days
24 / 7
Dynamic Backlight Control, sleep timer, Chromecast built-in, Apple AirPlay support, Triluminos Pro Display
Stands & Mounts
Stand
Optional
Stand Design
Tabletop
Flat Panel Mount Interface
200 x 200 mm
VESA Compatibility
Video Features
Input Video Formats
Media Player
Supported Video Formats
MPEG-1, MPEG-2, MPEG-4, Motion-JPEG, Xvid, WMV, ASF, AVI, MKV, MOV, AVCHD, TS, AVC, 3GPP, PS, VC-1, HEVC, VP8, XAVCS, HDV
Supported Audio Formats
MP3, WMA, WAV, AAC, FLAC (Free Lossless Audio Codec), LPCM, ASF
Supported Pictures Formats
JPEG
USB Port
USB Ports Qty
2
Configuration
16 GB
Audio System
Speaker System
2 speakers
Output Power / Total
20 Watt
Down-firing Speaker
Speakers
2 x speaker - 10 Watt
Network & Internet Multimedia
Wi-Fi, LAN
LAN Protocol
Ethernet
Connect & Share
Wi-Fi Direct, IP Control
Connector Type
RS-232C , 4 x HDMI - side , Composite video input - side , Audio input - side , 2 x USB - side , LAN - side , Digital audio output (optical) - side
CEC, HDCP 2.3
Power supply
0.5 Watt
On/off timer
Dimensions & Weight Details
Panel without stand - 97.2 cm x 7 cm x 56.7 cm x 10 kg , Panel with stand - 97.2 cm x 28.6 cm x 63.2 cm x 10.5 kg
Width (Shipping)
107 cm
Depth (Shipping)
14.1 cm
Height (Shipping)
69.5 cm
Weight (Shipping)
14 kg
Screen Size: 43in
Interface: HDMI
Brand: Sony
Price Range Ex VAT: £500 - £750
