Sony Bravia 65" Smart 3D Full HD LED TV 1920 x 1080  HDMI 3 x USB
Quicklinx: BMDBWS00 Mfr#: KDL65W857CSU
  • 1080p
  • DVB-S
  • DVB-T
Marketing description is not available.
  • See how good TV can look
    With advanced technologies to make everything you watch sharper, smoother and more lifelike, the BRAVIA difference is clear.
  • Stunning detail from whatever you're watching
    Every single pixel is upscaled beautifully by Sony's powerful picture processing technology. Individual parts of each scene are analyzed and matched with a special image database. Noise reduction by X-Reality PRO cuts various types of noise in analog and digital TV signals, DVD and Blu-ray Disc, and even digital still photos.
  • Smoother, more natural movement
    Whatever you're watching, you'll enjoy a silk-smooth on-screen look in fast-moving action sequences with Motionflow XR technology.
  • See it all on your TV
    Share photos, videos and more wirelessly in an instant with NFC, and MHL connectivity.
  • Made to listen
    Make your listening as lifelike as your viewing. ClearAudio+ fine-tunes TV sound for an immersive, emotionally enriching experience that seems to surround you. Hear music, dialog and surround effects with greater clarity and separation, whatever you're watching.
  • DSEE technology
    Enjoy greater detail across everything you listen to. DSEE is a combination of audio technologies which work together to deliver consistently clear, rich sound.
  • S-Force Front Surround
    S-Force Front processes audio signals to create an immersive listening experience. Direct multichannel processing ensures realistically clear 360° surround sound.
  • Clear Phase
    Clear Phase fine-tunes TV speaker frequency response for smoother, more balanced reproduction of all frequencies - lows, mids and highs.
Sony Bravia KDL-65W857C W857C Series - 65" LED-backlit LCD TV - Full HD
LED-backlit LCD TV - Smart TV
Diagonal Class
65"
Silver
3D
3D Technology
Active
Platform
Android TV
Resolution
1920 x 1080
Display Format
1080p
Input Video Formats
1080/24p, 1080/60i, 480/60p, 720/60p, 1080/50i, 576/50p, 1080/50p, 1080/60p, 1080/30p, 480/60i, 576/50i, 720/24p, 720/30p
Frame Rate & Enhancement Technology
Motionflow XR 900
24p Technology
24p True Cinema
Video Interface
Component, composite, HDMI, SCART
HDMI Ports Qty
4 ports
Wi-Fi, LAN, Bluetooth
PC Interface
Mobile High-Definition Link (MHL)
HDCP Compatible
LCD Backlight Technology
Direct-lit LED
Image Aspect Ratio
16:9
TV Tuner
1x analogue, 1x digital
Digital TV Tuner
DVB-C, DVB-S, DVB-S2, DVB-T, DVB-T2
Internet Streaming Services
Google Play
Multi-channel Preview
Picture-and-picture (PAP)
Speaker System
2 speakers
Sound Effects
S-FORCE Front Surround Sound
Stereo Reception System
NICAM, A2
USB
3 ports
Sony RMT-TX100D remote control, batteries, IR Blaster
Energy Class
Class A+
230 Watt
Power Consumption (On mode)
123 W
Power Consumption Stand by
0.5 Watt
Energy Consumption per Year
171 kWh
145.5 cm x 7.8 cm x 84.3 cm
23.4 kg
Energy Class
Class A+
230 Watt
123 W
171 kWh
Diagonal Class
65"
Series
W857C Series
3D
3D Technology
Active
Platform
Android TV
TV Tuner
TV Tuner Presence
Sensors
Light sensor
Video Interface
HDMI Ports Qty
4 ports
PC Interface
HDCP Compatible
Modes
Film Mode, backlight off mode, Live Football Mode
Timer Functions
Sleep, wake
Dimensions
Without stand
145.5 cm
7.8 cm
84.3 cm
23.4 kg
Enclosure Colour
Silver
Display
Resolution
1920 x 1080
Display Format
1080p
Image Aspect Ratio
16:9
Motionflow XR 900
24p Technology
24p True Cinema
Direct-lit LED
Widescreen Modes
Zoom 14:9, Auto Wide, Full, Wide Zoom, Zoom, Normal
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Advanced Contrast Enhancer circuit (ACE), i-Manual, X-Reality PRO Engine, Tv SideView, CineMotion, Cinema Drive, Dynamic Backlight Control, One-Flick Entertainment
Stands & Mounts
Stand
Included
Stand Design
Tabletop
Stand Colour
Silver mirror
Flat Panel Mount Interface
TV Tuner
Conditional Access
Common Interface Plus (CI+) slot
NICAM, A2
Digital TV Tuner
Digital TV Tuner
HDTV Tuner
Video Features
Input Video Formats
Electronic Programme Guide
Digital EPG
Parental Channel Lock
Media Player
USB Port
USB Ports Qty
3
Operating System
Android OS 5.0
Remote Control
Remote control
Remote Control Model
Sony RMT-TX100D
Scene Select, One-Flick Remote
Audio System
Digital Audio Format
Dolby Digital output, Dolby Digital Plus output, Dolby Pulse output
Surround Mode
Sound Effects
Audio Controls
Sound mode
Speaker System
2 speakers
Output Power / Total
20 Watt
S-Master Digital Amplifier, Clear Phase Speaker, Digital Sound Enhancement Engine (DSEE), Long Duct Speaker, Clear Audio+, Bass Reflex Speaker System, Google Cast support
Speakers
2 x main channel speaker - 10 Watt
Network & Internet Multimedia
Functionality
Digital audio playback, digital photo playback, digital video playback, WEB browsing, Internet video playback
LAN Protocol
Ethernet
Connect & Share
Wi-Fi Direct, Screen Mirroring, Photo Sharing Plus
Google Play
Supported Consumer Electronics Control (CEC)
BRAVIA Sync Function
Connector Type
4 x MHL/HDMI input , SCART - rear , 3 x USB , LAN - rear , Composite video / component video input - rear , Audio line-in - rear , SPDIF output - rear , Audio line-out / headphones / subwoofer - side
Batteries, IR Blaster
Power supply
0.5 Watt
Dimensions & Weight Details
Panel without stand - 145.5 cm x 7.8 cm x 84.3 cm x 23.4 kg , Panel with stand - 145.5 cm x 26.5 cm x 89.1 cm x 24.5 kg
Width (Shipping)
155.3 cm
Depth (Shipping)
22.4 cm
Height (Shipping)
94.3 cm
