One chip, incredibly real
With Object-based HDR remaster and Super Bit Mapping™ HDR technology, our 4K HDR Processor X1™ reproduces enhanced depth, textures and natural colours. You’ll see pure colours at higher brightness levels for exceptionally realistic pictures.
Rediscover every detail in 4K
With 4K X-Reality™ PRO, images are upscaled closer to true 4K quality for remarkable clarity. The picture is sharpened and refined in real time, revealing extra detail in the books and architecture of the library.
Life's brilliance, revealed with extra colours
See vivid real world colours all around you. A TRILUMINOS Display maps colours from a wider palette, faithfully reproducing every shade and hue in the umbrellas.
Made to listen
Your listening is as lifelike as your viewing. ClearAudio+ fine tunes TV sound for an immersive, emotionally enriching experience that seems to surround you. Hear music and dialogue with greater clarity and separation, whatever you’re watching.
Android TV opens the door to unlimited entertainment
With BRAVIA's TV home screen, it's easy to find the content you want to watch. Simply ask the TV for your favourite movie, then sit back and enjoy. Customise the home screen as you like and expand your experience with easy connection to other devices.
Works with Alexa
Connect your Alexa enabled devices for seamless hands-free control of a Sony TV. With Alexa, you can power up your TV, change channels, control volume and more.
Connect with Google Home
Connect Google Home for seamless hands-free control of a Sony TV. With Google Home, you can find and cast your favourite videos to your Sony TV, without lifting a finger
With Object-based HDR remaster and Super Bit Mapping HDR technology, Sony's 4K HDR Processor X1 reproduces enhanced depth, textures and natural colors. You'll see pure colors at higher brightness levels for exceptionally realistic pictures. -
With 4K X-Reality PRO, images are upscaled closer to true 4K quality for remarkable clarity. The picture is sharpened and refined in real time, revealing extra detail in the books and architecture of the library. -
Life's brilliance, revealed with extra colors
See vivid real-world colors all around you. A TRILUMINOS Display maps colors from a wider palette, faithfully reproducing every shade and hue in the umbrellas. -
Get started with just one button
Sony TVs have a dedicated Netflix button, so you can start streaming with just one click. -
Made to listen
Your listening is as lifelike as your viewing. ClearAudio+ fine tunes TV sound for an immersive, emotionally enriching experience that seems to surround you. Hear music and dialog with greater clarity and separation, whatever you're watching. -
Make smart even smarter
You can ask your Google Assistant to find your favorites. It's truly effortless and offers the ultimate viewing experience. Control your Sony TV and other connected devices using your voice - there's no smarter way to run your life. -
Cables concealed, neat and tidy
Keep cables neatly hidden in the stand and held in place with the supplied cable holder.
- Sony Bravia KD-43XG8305 43" Class (42.5" viewable) LED-backlit LCD TV - 4K
- Product Type
- LED-backlit LCD TV - Smart TV
- Diagonal Class
- 43"
- Diagonal Size
- 42.5"
- Black
- Platform
- Android TV
- Resolution
- 3840 x 2160
- Display Format
- 4K UHD (2160p)
- Input Video Formats
- 480p, 480i, 576i, 576p, 1080/24p, 1080/60i, 720/60p, 1080/50i, 720/50p, 1080/50p, 1080/60p, 1080/30p, 720/24p, 720/30p, 3840/25p, 3840/50p, 3840/24p, 3840/30p, 3840/60p, 4096/24p, 4096/50p, 4096/60p
- HDR Format
- HDR10, HLG10
- HDR Technology
- Object-based HDR remaster, Super Bit Mapping HDR
- Frame Rate & Enhancement Technology
- Motionflow XR 800, 100 Hz Native Refresh Rate
- Video Interface
- Component, composite, HDMI
- HDMI Ports Qty
- 4 ports
- Connectivity
- Wi-Fi, LAN, Bluetooth
- LCD Backlight Technology
- Edge-lit LED frame dimming
- Image Aspect Ratio
- 16:9
- TV Tuner
- 1x analogue, 2x digital
- Digital TV Tuner
- DVB-C, DVB-S, DVB-S2, DVB-T, DVB-T2
- Internet Streaming Services
- Voice Search, Chromecast
- Picture Enhancements
- Live Color, 4K X-Reality PRO Engine, Dynamic Contrast Enhancer
- Speaker System
- 2 speakers
- Sound Effects
- S-FORCE Front Surround Sound, DTS Digital Surround
- Storage Drive Capacity
- 16 GB
- Storage Capacity
- 16 GB
- USB
- 3 ports
- Included Accessories
- Remote control, batteries, IR Blaster
- Voltage
- AC 230V (50 Hz)
- Energy Class
- Class B
- 143 Watt
- Power Consumption (On mode)
- 76 W
- Power Consumption Stand by
- 0.5 Watt
- Energy Consumption per Year
- 105 kWh
- Dimensions (WxDxH) - without stand
- 96.5 cm x 5.8 cm x 56.9 cm
- 10.8 kg
- Product Type
- Energy Class
- Class B
- 143 Watt
- 76 W
- 105 kWh
- Diagonal Class
- 43"
- Diagonal Size
- 42.5"
- Model Year
- 2019
- Platform
- Android TV
- Operating System
- Android OS
- HDR Capable
- HDR Format
- HDR10, HLG10
- HDR Technology
- Video Processor
- 4K HDR X1
- TV Tuner
- TV Tuner Presence
- Sensors
- Light sensor
- Video Interface
- HDMI Ports Qty
- 4 ports
- Modes
- Backlight off mode
- Dimensions
- Without stand
- 96.5 cm
- 5.8 cm
- 56.9 cm
- 10.8 kg
- Enclosure Colour
- Black
Display
- Resolution
- 3840 x 2160
- Display Format
- 4K UHD (2160p)
- 16:9
- Edge-lit LED - frame dimming
- Display Menu Language
- Multilingual
- Audio Description (AD), Tv SideView, Dynamic Backlight Control, Triluminos Display, 10-bit support
Stands & Mounts
- Stand
- Included
- Stand Design
- Tabletop
- Stand Colour
- Dark silver
- Flat Panel Mount Interface
- 100 x 200 mm
- VESA Compatibility
TV Tuner
- Conditional Access
- Common Interface Plus (CI+) slot
Digital TV Tuner
- Digital TV Tuner
- HDTV Tuner
Video Features
- Teletext
- Electronic Programme Guide
- Digital EPG
- Closed Caption Capability
Media Player
- Supported Video Formats
- MPEG-1, MPEG-2, MPEG-4, Motion-JPEG, Xvid, WMV, ASF, AVI, MKV, MOV, AVCHD, TS, AVC, 3GPP, PS, VC-1, WebM, HEVC, VP8, XAVCS, HDV
- Supported Audio Formats
- MP3, WMA, WAV, AAC, FLAC (Free Lossless Audio Codec), ASF
- Supported Pictures Formats
- JPEG
- USB Port
- USB Ports Qty
- 3
- Configuration
- 16 GB
- 16 GB
Remote Control
- Remote control
- Built-in microphone
Audio System
- Digital Audio Format
- Dolby Digital output, Dolby Digital Plus output, Dolby Pulse output
- Surround Mode
- Sound Effects
- Speaker System
- 2 speakers
- Output Power / Total
- 20 Watt
- Audio Return Channel (ARC), Clear Phase Speaker, Digital Sound Enhancement Engine (DSEE), Clear Audio+, Bass Reflex Speaker System
- Speakers
- 2 x speaker - 10 Watt
- Driver Details
- Speaker: 2 x full-range driver
Network & Internet Multimedia
- Functionality
- WEB browsing, Internet video playback
- Connectivity
- LAN Protocol
- Ethernet
- Wi-Fi Protocol
- 802.11b, 802.11g, 802.11n, 802.11a, 802.11ac
- Bluetooth Version
- Bluetooth 4.1
- Connect & Share
- Bluetooth Human Interface Device (HID)
- Application Store
- Google Play
- Connector Type
- 3 x HDMI - side , HDMI - rear , SPDIF output - rear , Headphone output - side , Audio line-out / headphones / subwoofer - side , Composite video / component video input - rear , 3 x USB - side , LAN - side
- Batteries, IR Blaster
- HDCP 2.3
- Power Device
- Power supply
- Input Voltage
- AC 230V (50 Hz)
- 0.5 Watt
Dimensions & Weight Details
- Dimensions & Weight Details
- Panel without stand - 96.5 cm x 5.8 cm x 56.9 cm x 10.8 kg , Panel with stand - 96.5 cm x 26 cm x 62.8 cm x 11.3 kg
- Width (Shipping)
- 107.2 cm
- Depth (Shipping)
- 15 cm
- Height (Shipping)
- 69.9 cm
- Weight (Shipping)
- 15 kg
