Sony Alpha A57 SLR Camera 18-55mm, 55-200mm Lenses 16MP 3.0L
Quicklinx: 8B0LWS00 Mfr#: SLTA57YDI.YG
  • SDHC Memory Card
  • Memory Stick PRO Duo
Serious quality and powerful creative options have never been so accessible. The SLT-A57 shares many features found in range-topping cameras from Sony, including super-fast shooting with continuous autofocus. Explore the possibilities of flawless images and Full HD video.
  • It's all in the detail
    The high-resolution CMOS sensor assures detail-packed pictures with excellent contrast and gorgeous colors. Exmor technology cuts noise while signals are converted to digital form. The result? Flawlessly beautiful images.
  • Zoom in on the action
    Get close to fast-moving action with a continuous burst of sharply-focused images at up to 12 frames per second. It's a great way to grab that decisive moment, from dynamic sports to wildlife.
  • Discover the artist within you
    Create a range of artistic styles, with no PC needed. Picture effects offers a rich palette of options including posterise, partial colour, retro, high-key, mono and toy camera. Preview results in live view mode while shooting stills or movies.
  • Amazing HD movies
    Capture smooth, detailed Full HD videos with accurate phase-detection autofocus of moving subjects. Produce beautiful background defocus effects, and enjoy full manual control over focus and exposure modes. Create a cinematic mood with progressive shooting.
  • Compose shots with confidence
    Frame still photos and movies through the bright, detail-packed TruFinder. With excellent contrast and a wide field of view, this precision electronic viewfinder helps you compose with confidence, even in direct sunlight.
Sony a SLT-A57Y - digital camera DT 18-55mm and 55-200mm lenses
Digital camera - SLR with Live View mode, movie recording
Lens Included
Memory Card Slot
Memory Stick PRO Duo card, SD card
Image Processor
BIONZ
Sensors
Digital level metre
Sensor Resolution
16.1 Megapixel
Max Video Resolution
1920 x 1080
Lens System
Zoom lens - 3x zoom - 18 - 55 mm - f/3.5-5.6 DT SAM
Lens System (2nd)
Zoom lens - 3.6x zoom - 55 - 200 mm - f/4.0-5.6 DT SAM
Focus Adjustment
Automatic, manual
Min Focus Distance
25 cm
Image Stabiliser
Optical (SteadyShot INSIDE)
Camera Flash
Pop-up flash
Viewfinder
Built-in - 0.46" - colour - electronic
Display
LCD display - 3"
Supported Battery
Li-ion rechargeable battery (included)
HDMI, USB 2.0
13.2 cm x 8.1 cm x 9.8 cm
0.54 kg
Lens Included
Sensor Resolution
16.1 Megapixel
Optical Sensor Type
Exmor APS HD CMOS
Total Pixels
16,700,000 pixels
Effective Sensor Resolution
16,100,000 pixels
Optical Sensor Size
APS-C (23.5 x 15.6 mm)
Field of View Crop Factor
1.5
ISO (Max)
25600
Sensor Features
Dust Reduction (image sensor vibration), Anti-Dust coating
Optical Zoom
3x
Image Processor
BIONZ
Image Stabiliser
Built-in Optical Image Stabiliser
Face Detection
HDR Mode
Auto HDR mode
Surround Sound
Dolby Digital AC-3 (2 channel) recording
Sensors
Digital level metre
Print Standard
DPOF support, Exif Print support, PRINT Image Matching
Auto Focus
TTL phase detection
Auto Focus Points (Zones) Qty
15
AE/AF Control
Subject-tracking AF, Predictive AI Servo AF
Face Detection
Smile Shutter, Child Priority, Adult Priority
Digital Video Format
AVCHD, H.264
Image Recording Format
JPEG, RAW, RAW + JPEG, MPO
1920 x 1080
HDMI, USB 2.0
Exposure & White Balance
Light Sensitivity
ISO auto (100-3200), ISO 25600, ISO 100-16000
Exposure Metering
Multi-segment, centre-weighted, spot
Exposure Metering Zones
1200
Exposure Modes
Programme, bulb, automatic, manual, aperture-priority, shutter-priority
Shooting Programs
Landscape, portrait mode, macro, night portrait, sports mode, sunset, handheld twilight, Night View
Special Effects
Black & White, Vivid, sunset, soft focus, landscape, portrait, miniature, Retro, partial colour, Toy camera, Posterisation, High contrast monochrome, Pop Colour, HDR Painting, Rich-tone monochrome, Soft High-key
White Balance
Custom, automatic, presets
White Balance Presets
Incandescent, fluorescent, cloudy, Flash, daylight, shade, fluorescent light (cool white), fluorescent light (warm white), 2500K - 9900K, fluorescent light (daylight white)
Max Shutter Speed
1/4000 sec
Min Shutter Speed
30 sec
Exposure Compensation
±3 EV range, in 1/3 EV steps
Auto Exposure Bracketing
3 steps in 1/3 or 2/3 EV steps
X-sync Speed
1/160 sec
Exposure Range
EV -2-17 (ISO 100)
Lens System
Focal Length Equivalent to 35mm Camera
27 - 82.5mm
Focus Adjustment
Automatic, manual
Min Focus Distance
25 cm
Max View Angle
76 degree(s)
Zoom Adjustment
Manual
Lens Construction
7 groups / 8 elements
Filter Size
55 mm
Aspherical lens, Smooth Autofocus Motor (SAM)
Lens System (2nd)
82.5 - 300mm
Min Focus Distance
95 cm
Focus Adjustment
Automatic, manual
Lens Construction
9 groups / 13 elements
Filter Size
55 mm
ED glass
Camera Flash
Camera Flash
Pop-up flash
Guide Number (m / ISO 100)
10
Flash Modes
Fill-in mode, rear curtain sync, slow synchro, auto mode, flash OFF mode, red-eye reduction
Red-Eye Reduction
AF illuminator, flash +/- compensation, wireless off-camera control, flash exposure bracketing
Additional Features
Continuous Shooting Speed
8 frames per second, 3 frames per second, 10 frames per second, 12 frames per second
Self-Timer Delay
10 sec, 2sec
Flash Terminal
Hot shoe
Additional Features
RGB primary colour filter, digital noise reduction, depth-of-field preview button, digital image rotation, camera orientation detection, histogram display, Sweep Panorama technology, LCD live view mode, Dynamic Range Optimizer, built-in help guide, automatic display brightness adjustment, Anti-motion Blur Mode, 3D Sweep Panorama technology, Multi-Frame Noise Reduction, Intelligent AUTO (iAUTO), Quick AF Full HD movie recording, AUTO+ (Advanced AUTO) mode, Translucent Mirror technology
Viewfinder
Viewfinder Type
Built-in - electronic
Viewfinder Colour Support
Viewfinder Diagonal Size
0.46"
Viewfinder Resolution
1,440,000 pixels
Optical Viewfinder Field Coverage
100%
Optical Viewfinder Magnification
1.04x
Optical Viewfinder Dioptric Correction Range
-4 to +3
Display
3" LCD display
Display Format
921,600 pixels
Display Form Factor
Folding
Display Features
Display brightness control
Microphone
Microphone Operation Mode
Stereo
Connector Type
HDMI output , USB 2.0 , Microphone
Software
Software
Sony Image Data Converter SR, Sony PlayMemories Home
Battery charger, dust cap, body cap, lens cap, shoulder strap, USB cable
Battery Type
Sony NP-FM500H Lithium Ion
Details
Battery Life Details
Photo shooting - 550 shots (EVF on) , Photo shooting - 590 shots (LCD Monitor on)
Memory / Storage
Memory Card Slot
Supported Memory Cards
SD Memory Card, Memory Stick PRO Duo, SDXC Memory Card, SDHC Memory Card, Memory Stick PRO-HG Duo
Image Storage
4912 x 3264 , 3568 x 2368 , 2448 x 1624 , 4912 x 2760 , 3568 x 2000 , 2448 x 1376
Video Capture
AVCHD - 1920 x 1080 - 50 fps - 28Mbps , AVCHD - 1920 x 1080 - 50 fps - 24Mbps , AVCHD - 1920 x 1080 - 50 fps - 17Mbps , AVCHD - 1920 x 1080 - 25 fps - 24Mbps , AVCHD - 1920 x 1080 - 25 fps - 17Mbps , AVCHD - 1920 x 1080 - 25 fps - 12Mbps , H.264 - 1440 x 1080 - 25 fps - 12Mbps , H.264 - 640 x 480 - 3Mbps
13.2 cm
8.1 cm
9.8 cm
0.54 kg
