Sony 75" Bravia 7 K-75XR70 LED-backlit QLED 4K UHD Google TV
Quicklinx: HX1CWS00 Mfr#: K75XR70PU
Screen Size: 75in
Screen Resolution: 4K UHD (2160p)
Smart: Smart TV
Interface: HDMI
Energy Class: Class D
  • DVB-T
  • DVB-S
£1,874.17 ex VAT
£2,249.00 inc VAT
Treat yourself to some fantastic film nights with this massive Sony BRAVIA 7 75-inch TV. It has a 4K MiniLED display for an amazingly sharp picture, while colours look just like the real thing even at full brightness thanks to Quantum Dot tech. Combine that with its XR Backlight Master Drive that gives you stunning contrast and you’ve got action-packed scenes that leap off the screen. But it doesn’t just look good. Clever Acoustic Multi Audio turns the whole unit into a giant speaker, and 360 Spatial Sound Mapping fills the room, so you hear epic scores from all sides – it’ll feel like you’re inside the movie. On top of that, Acoustic Centre Sync works with your soundbar to deliver the best experience possible without the hassle.
  • Remarkable contrast
    Experience a new era in contrast. With a unique local dimming algorithm, XR Backlight Master Drive precisely controls thousands of Mini LEDs for truly authentic contrast.
  • Over a billion vivid, real-world colors
    See the world's colors with all the vibrancy of real life. The XR Triluminos Pro reproduces over a billion of them with the subtle differences from saturation and hue that enables natural shades in every detail.
  • Unmatched realism with XR Processor
    Powered for precision. The XR Processor features a scene recognition system that detects and analyzes data with flawless accuracy, then optimizes the picture for ultimate realism.
  • Crystal-clear pictures, refined and real
    Rediscover detail. XR Clear Image uses a custom database to intelligently convert your favorites to near 4K. Noise is minimized by XR Clear Image through zone division and dynamic frame analysis.
  • Even fast-moving action stays clear and blur-free
    Forget about blur. XR Motion Clarity analyzes movement across several frames and precisely synchronizes the backlight with on-screen motion so you see clear, bright images, however fast the action.
  • Theater-like sound, perfectly matching pictures
    Hear sound from exactly the right place. Not from beneath the screen but seemingly straight from the screen itself. With Acoustic Multi-Audio, what you see and what you hear are perfectly matched.
  • Crystal-clear voice, precise dialog
    No more muffled voices. The Voice Zoom 3 recognizes human dialog through AI machine learning and amplifies or reduces its volume so even small dialog sounds loud and clear.
  • Intelligent processing upscales ordinary stereo sound to extraordinary 3D surround
    Be immersed. The 3D Surround Upscaling creates virtual surround from above and the sides using just the TV speakers. Even 2ch and 5.1ch audio is upscaled to immersive 5.1.2ch sound. What's more, Dolby Atmos and DTS:X support provides unforgettable spatial sound.
  • All-round cinematic, go beyond conventional virtual surround sound
    Paired with a compatible Sony soundbar, the 360 Spatial Sound Mapping technology creates phantom speakers beyond physical speakers for a cinema-like layout and true movie theater entertainment at home.
  • Sound precisely matches what's on screen
    Sound is adjusted as one integrated speaker system. Acoustic Center Sync enables the home theater equipment to use BRAVIA as a center speaker so that sound comes from the screen rather than just the soundbar.
  • BRAVIA Connect app
    With the BRAVIA Connect app, you can adjust volume and settings and even check your set up without using the remote or on screen menu.
  • Single view, simultaneous sound
    The TV with simultaneous sound output lets you listen to a show on your headphones while your partner listens to the same show through the TV speakers. You can also change the volume using Bluetooth devices separately.
  • One Slate, sophisticated from everywhere
    Totally unified. The One Slate concept fuses screen and bezel into a single slate, minimizing distractions and maximizing your experience.
  • Vibration finish, harmonizes with your home
    Designed with an almost invisible bezel. Its naturally warm, smudge-resistant texture blends seamlessly with interior decor and walls.
  • Perfectly integrates TV and soundbar, almost no stand visible
    Cleverly concealed. The Underlay Stand is a thin, flat steel plate. Stack a Sony soundbar on top and it virtually disappears.
  • Multi-purpose stand fits your style
    Absolute flexibility. The 4-way stand gives you the choice of an outside position, an inside position for smaller shelves or two soundbar positions to meet your viewing preference.
  • Watch Netflix in studio quality, automatically optimized
    See Netflix in a whole new light. The Netflix Adaptive Calibrated Mode, designed by Sony and Netflix, brings studio-quality mastering home with brightness automatically adjusted to your ambient room conditions.
  • Sony and Prime Video bring studio pictures home
    See movies, shows, and even live sports the way the filmmakers and broadcasters intended. With Prime Video Calibrated Mode, picture settings are auto calibrated to what you're watching including live sports for studio-quality Prime Video at home.
  • Immersive movie experience
    Experience truly unforgettable movies at home. The TV supports the rigorous standards of IMAX Enhanced, DTS:X, Dolby Vision and Dolby Atmos for an unbelievably atmospheric and immersive viewing experience.
  • Just use your voice to control your TV with help from Google Assistant
    Your TV is more helpful than ever. Ask Google Assistant to find movies, stream apps, play music and control the TV with your voice. Get answers, adjust room temperature and lighting, even check the front door. Just say "Hey Google" to get started.
  • Chromecast built-in
    Stream from your device. Easily cast movies, shows, photos, and more from your phone or tablet, right to your TV.
  • Compatible with Apple AirPlay 2
    Stream effortlessly to your TV from your iPhone, iPad or Mac. Watch movies from apps or Safari. Share photos with friends in the room.
  • Connect with your Alexa
    Connect your Alexa enabled devices for seamless hands-free control of BRAVIA. With Alexa, you can power up your TV, change channels, control volume and more.
  • Ask Siri to control your TV with just your voice
    Easily and securely control a Sony TV with the Apple Home app and Siri on your Apple device, using Home technology. Set up your TV in a few simple steps and control with a tap or by asking Siri.
  • Auto HDR Tone Mapping
    Auto HDR Tone Mapping instantly optimizes HDR settings during your PS5 initial setup. Even in dark shadow and bright highlights, you'll see fine details and true colors.
  • Auto Genre Picture Mode
    BRAVIA automatically switches into Game Mode with PS5 to minimize lag and maximize responsiveness. It switches back to Standard Mode when watching movies for more expressive scenes.
  • Stream PlayStation games to your BRAVIA
    Control your PlayStation remotely wherever you have a compatible BRAVIA connected to the Internet. The PS Remote Play app lets you control your PS5 or PS4 console from another room or location like a friend's house.
  • One place for all your game settings
    Never has it been easier to fine-tune your game status, settings and assist functions. All the essentials are at your fingertips for ease and comfort.
  • Various features in HDMI 2.1
    With 4K/120fps, a Variable Refresh Rate (VRR) and Auto Low Latency Mode (ALLM), TVs give you smooth and clear movement for responsive gameplay.
Sony Bravia 7 K-75XR70 75" Class (74.5" viewable) LED-backlit LCD TV - QLED - 4K
LED-backlit LCD TV - QLED - Smart TV
Energy Label QR Code URL
Https://eprel.ec.europa.eu/qr/1815023
Diagonal Class
75"
Diagonal Size
74.5"
Dark silver, vibration finish
Platform
Google TV
Resolution
3840 x 2160
Display Format
4K UHD (2160p)
HDR Format
HDR10, Dolby Vision
HDR Technology
Hybrid Log-Gamma (HLG)
Frame Rate & Enhancement Technology
120 Hz Refresh Rate, Variable Refresh Rate (VRR)
Video Interface
HDMI
HDMI Ports Qty
4 ports
Wi-Fi, LAN, Bluetooth
LCD Backlight Technology
Mini-LED
Image Aspect Ratio
16:9
TV Tuner
1x analogue, 2x digital
Digital TV Tuner
DVB-C, DVB-S, DVB-S2, DVB-T, DVB-T2
Internet Streaming Services
Netflix, YouTube, Voice Search, Crunchyroll, Apple TV, Prime Video, Bravia Core
Picture Enhancements
Live Color, Crystal Clear, Dynamic Contrast Enhancer, Netflix Calibrated Mode, Image Enhancing, XR Motion Clarity, Auto HDR Tone Mapping, XR Backlight Master Drive, XR Contrast Booster 20, XR Clear Image
Speaker System
2 speakers, 2 tweeters
Sound Effects
DTS Digital Surround, 3D Surround Upscaling, Headphone 3D surround ready
Platform
Apple HomeKit
Intelligent Assistant
Google Assistant, Alexa (not available for some languages and countries)
Storage Capacity
32 GB
USB
2 ports
Remote control
Voltage
AC 220 - 240 V (50 Hz)
Energy Class
Class D
Power Consumption Stand by
0.5 Watt
166.8 cm x 5.7 cm x 96 cm
38.3 kg
Energy Class
Class D
Energy Class (HDR)
Class F
79 kWh/1000h
Power Consumption HDR (On mode)
124 kWh/1000h
Diagonal Class
75"
Diagonal Size
74.5"
Model Year
2024
Platform
Google TV
Operating System
Android TV
HDR Capable
HDR Format
HDR10, Dolby Vision
HDR Technology
Video Processor
XR
TV Tuner
TV Tuner Presence
Sensors
Light sensor
Video Interface
HDMI
HDMI Ports Qty
4 ports
Modes
Cinema mode, photo mode, professional mode, Standard mode, Vivid mode, Auto Low Latency Mode (ALLM), Dolby Vision bright mode, Dolby Vision dark mode, Dolby Vision vivid mode, Auto Genre Picture Mode, Dolby Vision Game, FPS Game mode, RTS Game mode, Calm mode, auto power save mode
Design
Seamless Edge
Dimensions
Without stand
166.8 cm
5.7 cm
96 cm
38.3 kg
Enclosure Colour
Display
Resolution
3840 x 2160
Display Format
4K UHD (2160p)
Image Aspect Ratio
16:9
Mini-LED
Display Menu Language
Multilingual
Audio Description (AD), Dynamic Backlight Control, Gesture Control, sleep timer, Chromecast built-in, CalMAN auto calibration support, Apple AirPlay 2 support, text magnification, Accessibility shortcut, XR Triluminos Pro Display, BRAVIA CAM support, ECO Dashboard, PlayStation Remote Play, Proximity alert
Stands & Mounts
Stand
Included
Stand Design
Tabletop
Stand Colour
Dark silver
Stand Features
4-way position, underlay stand
Flat Panel Mount Interface
300 x 300 mm
VESA Compatibility
TV Tuner
Conditional Access
Common Interface Plus (CI+) slot
Digital TV Tuner
Digital TV Tuner
HDTV Tuner
Video Features
Electronic Programme Guide
Digital EPG
Closed Caption Capability
Media Player
Supported Video Formats
MPEG-1, MPEG-2, MPEG-4, Motion-JPEG, WMV, ASF, AVC, 3GPP, HEVC, VP9, VP8, AVS, AV1
Supported Audio Formats
MP3, WAV, AAC, FLAC (Free Lossless Audio Codec), LPCM, OGG, AC4
Supported Pictures Formats
JPEG
USB Port
USB Ports Qty
2
Configuration
32 GB
Remote Control
Remote control
Battery Included
Voice control
Audio System
Digital Audio Format
DTS-HD Master Audio output, DTS-HD High-Resolution Audio digital output, Dolby Atmos, DTS:X, Dolby Audio, DTS Express
Surround Mode
Sound Effects
Speaker System
Output Power / Total
40 Watt
Audio Return Channel (ARC), Crystal Clear, Bass Reflex Speaker System, Acoustic Multi-Audio, Enhanced Audio Return Channel (eARC), Sound Positioning Tweeter, Room Compensation, User Position Compensation, Acoustic Center Sync, built-in microphone switch, 360 Spatial Sound Mapping, Voice Zoom 3
Speakers
2 x speaker - 10 Watt , 2 x tweeter - 10 Watt
Driver Details
Speaker: 2 x full-range driver , Tweeter: 2
Network & Internet Multimedia
Functionality
WEB browsing, Internet video playback
LAN Protocol
Ethernet
Wi-Fi Protocol
802.11b, 802.11g, 802.11n, 802.11a, 802.11ac, 802.11ax
Bluetooth Version
Bluetooth 5.3
Connect & Share
Bluetooth Human Interface Device (HID)
Supported Consumer Electronics Control (CEC)
BRAVIA Sync Function
Application Store
Google Play
Connector Type
4 x HDMI input - side , 2 x USB - side , LAN - side , Digital audio output - side
Internet of Things (IoT)
Platform
Apple HomeKit
CEC, HDCP 2.3
Power supply
Input Voltage
0.5 Watt
Auto On/Off
On/off timer
Dimensions & Weight Details
Panel without stand - 166.8 cm x 5.7 cm x 96 cm x 38.3 kg , Panel with stand and soundbar - 166.8 cm x 40.5 cm x 103.8 cm x 40.1 kg , Panel with stand (narrow position) - 166.8 cm x 40.5 cm x 98.4 cm x 40.1 kg , Dimensions between support feet - 144.2 cm
Width (Shipping)
178.8 cm
Depth (Shipping)
18 cm
Height (Shipping)
113 cm
Weight (Shipping)
50 kg
Screen Size: 75in
Smart: Smart TV
Interface: HDMI
Brand: Sony
Price Range Ex VAT: £1500+
