Treat yourself to some fantastic film nights with this massive Sony BRAVIA 7 75-inch TV. It has a 4K MiniLED display for an amazingly sharp picture, while colours look just like the real thing even at full brightness thanks to Quantum Dot tech. Combine that with its XR Backlight Master Drive that gives you stunning contrast and you’ve got action-packed scenes that leap off the screen. But it doesn’t just look good. Clever Acoustic Multi Audio turns the whole unit into a giant speaker, and 360 Spatial Sound Mapping fills the room, so you hear epic scores from all sides – it’ll feel like you’re inside the movie. On top of that, Acoustic Centre Sync works with your soundbar to deliver the best experience possible without the hassle.
Remarkable contrast
Experience a new era in contrast. With a unique local dimming algorithm, XR Backlight Master Drive precisely controls thousands of Mini LEDs for truly authentic contrast. -
Over a billion vivid, real-world colors
See the world's colors with all the vibrancy of real life. The XR Triluminos Pro reproduces over a billion of them with the subtle differences from saturation and hue that enables natural shades in every detail. -
Unmatched realism with XR Processor
Powered for precision. The XR Processor features a scene recognition system that detects and analyzes data with flawless accuracy, then optimizes the picture for ultimate realism. -
Crystal-clear pictures, refined and real
Rediscover detail. XR Clear Image uses a custom database to intelligently convert your favorites to near 4K. Noise is minimized by XR Clear Image through zone division and dynamic frame analysis. -
Even fast-moving action stays clear and blur-free
Forget about blur. XR Motion Clarity analyzes movement across several frames and precisely synchronizes the backlight with on-screen motion so you see clear, bright images, however fast the action. -
Theater-like sound, perfectly matching pictures
Hear sound from exactly the right place. Not from beneath the screen but seemingly straight from the screen itself. With Acoustic Multi-Audio, what you see and what you hear are perfectly matched. -
Crystal-clear voice, precise dialog
No more muffled voices. The Voice Zoom 3 recognizes human dialog through AI machine learning and amplifies or reduces its volume so even small dialog sounds loud and clear. -
Intelligent processing upscales ordinary stereo sound to extraordinary 3D surround
Be immersed. The 3D Surround Upscaling creates virtual surround from above and the sides using just the TV speakers. Even 2ch and 5.1ch audio is upscaled to immersive 5.1.2ch sound. What's more, Dolby Atmos and DTS:X support provides unforgettable spatial sound. -
All-round cinematic, go beyond conventional virtual surround sound
Paired with a compatible Sony soundbar, the 360 Spatial Sound Mapping technology creates phantom speakers beyond physical speakers for a cinema-like layout and true movie theater entertainment at home. -
Sound precisely matches what's on screen
Sound is adjusted as one integrated speaker system. Acoustic Center Sync enables the home theater equipment to use BRAVIA as a center speaker so that sound comes from the screen rather than just the soundbar. -
BRAVIA Connect app
With the BRAVIA Connect app, you can adjust volume and settings and even check your set up without using the remote or on screen menu. -
Single view, simultaneous sound
The TV with simultaneous sound output lets you listen to a show on your headphones while your partner listens to the same show through the TV speakers. You can also change the volume using Bluetooth devices separately. -
One Slate, sophisticated from everywhere
Totally unified. The One Slate concept fuses screen and bezel into a single slate, minimizing distractions and maximizing your experience. -
Vibration finish, harmonizes with your home
Designed with an almost invisible bezel. Its naturally warm, smudge-resistant texture blends seamlessly with interior decor and walls. -
Perfectly integrates TV and soundbar, almost no stand visible
Cleverly concealed. The Underlay Stand is a thin, flat steel plate. Stack a Sony soundbar on top and it virtually disappears. -
Multi-purpose stand fits your style
Absolute flexibility. The 4-way stand gives you the choice of an outside position, an inside position for smaller shelves or two soundbar positions to meet your viewing preference. -
Watch Netflix in studio quality, automatically optimized
See Netflix in a whole new light. The Netflix Adaptive Calibrated Mode, designed by Sony and Netflix, brings studio-quality mastering home with brightness automatically adjusted to your ambient room conditions. -
Sony and Prime Video bring studio pictures home
See movies, shows, and even live sports the way the filmmakers and broadcasters intended. With Prime Video Calibrated Mode, picture settings are auto calibrated to what you're watching including live sports for studio-quality Prime Video at home. -
Immersive movie experience
Experience truly unforgettable movies at home. The TV supports the rigorous standards of IMAX Enhanced, DTS:X, Dolby Vision and Dolby Atmos for an unbelievably atmospheric and immersive viewing experience. -
Just use your voice to control your TV with help from Google Assistant
Your TV is more helpful than ever. Ask Google Assistant to find movies, stream apps, play music and control the TV with your voice. Get answers, adjust room temperature and lighting, even check the front door. Just say "Hey Google" to get started. -
Chromecast built-in
Stream from your device. Easily cast movies, shows, photos, and more from your phone or tablet, right to your TV. -
Compatible with Apple AirPlay 2
Stream effortlessly to your TV from your iPhone, iPad or Mac. Watch movies from apps or Safari. Share photos with friends in the room. -
Connect with your Alexa
Connect your Alexa enabled devices for seamless hands-free control of BRAVIA. With Alexa, you can power up your TV, change channels, control volume and more. -
Ask Siri to control your TV with just your voice
Easily and securely control a Sony TV with the Apple Home app and Siri on your Apple device, using Home technology. Set up your TV in a few simple steps and control with a tap or by asking Siri. -
Auto HDR Tone Mapping
Auto HDR Tone Mapping instantly optimizes HDR settings during your PS5 initial setup. Even in dark shadow and bright highlights, you'll see fine details and true colors. -
Auto Genre Picture Mode
BRAVIA automatically switches into Game Mode with PS5 to minimize lag and maximize responsiveness. It switches back to Standard Mode when watching movies for more expressive scenes. -
Stream PlayStation games to your BRAVIA
Control your PlayStation remotely wherever you have a compatible BRAVIA connected to the Internet. The PS Remote Play app lets you control your PS5 or PS4 console from another room or location like a friend's house. -
One place for all your game settings
Never has it been easier to fine-tune your game status, settings and assist functions. All the essentials are at your fingertips for ease and comfort. -
Various features in HDMI 2.1
With 4K/120fps, a Variable Refresh Rate (VRR) and Auto Low Latency Mode (ALLM), TVs give you smooth and clear movement for responsive gameplay.
- Sony Bravia 7 K-75XR70 75" Class (74.5" viewable) LED-backlit LCD TV - QLED - 4K
- Product Type
- LED-backlit LCD TV - QLED - Smart TV
- Energy Label QR Code URL
- Https://eprel.ec.europa.eu/qr/1815023
- Diagonal Class
- 75"
- Diagonal Size
- 74.5"
- Dark silver, vibration finish
- Platform
- Google TV
- Resolution
- 3840 x 2160
- Display Format
- 4K UHD (2160p)
- HDR Format
- HDR10, Dolby Vision
- HDR Technology
- Hybrid Log-Gamma (HLG)
- Frame Rate & Enhancement Technology
- 120 Hz Refresh Rate, Variable Refresh Rate (VRR)
- Video Interface
- HDMI
- HDMI Ports Qty
- 4 ports
- Connectivity
- Wi-Fi, LAN, Bluetooth
- LCD Backlight Technology
- Mini-LED
- Image Aspect Ratio
- 16:9
- TV Tuner
- 1x analogue, 2x digital
- Digital TV Tuner
- DVB-C, DVB-S, DVB-S2, DVB-T, DVB-T2
- Internet Streaming Services
- Netflix, YouTube, Voice Search, Crunchyroll, Apple TV, Prime Video, Bravia Core
- Picture Enhancements
- Live Color, Crystal Clear, Dynamic Contrast Enhancer, Netflix Calibrated Mode, Image Enhancing, XR Motion Clarity, Auto HDR Tone Mapping, XR Backlight Master Drive, XR Contrast Booster 20, XR Clear Image
- Speaker System
- 2 speakers, 2 tweeters
- Sound Effects
- DTS Digital Surround, 3D Surround Upscaling, Headphone 3D surround ready
- Platform
- Apple HomeKit
- Intelligent Assistant
- Google Assistant, Alexa (not available for some languages and countries)
- Storage Capacity
- 32 GB
- USB
- 2 ports
- Included Accessories
- Remote control
- Voltage
- AC 220 - 240 V (50 Hz)
- Energy Class
- Class D
- Power Consumption Stand by
- 0.5 Watt
- Dimensions (WxDxH) - without stand
- 166.8 cm x 5.7 cm x 96 cm
- 38.3 kg
- Product Type
- Energy Class
- Class D
- Energy Class (HDR)
- Class F
- Power Consumption SDR (On mode)
- 79 kWh/1000h
- Power Consumption HDR (On mode)
- 124 kWh/1000h
- Diagonal Class
- 75"
- Diagonal Size
- 74.5"
- Model Year
- 2024
- Platform
- Google TV
- Operating System
- Android TV
- HDR Capable
- HDR Format
- HDR Technology
- Video Processor
- XR
- TV Tuner
- TV Tuner Presence
- Sensors
- Light sensor
- Video Interface
- HDMI
- HDMI Ports Qty
- 4 ports
- Modes
- Cinema mode, photo mode, professional mode, Standard mode, Vivid mode, Auto Low Latency Mode (ALLM), Dolby Vision bright mode, Dolby Vision dark mode, Dolby Vision vivid mode, Auto Genre Picture Mode, Dolby Vision Game, FPS Game mode, RTS Game mode, Calm mode, auto power save mode
- Design
- Seamless Edge
- Dimensions
- Without stand
- 166.8 cm
- 5.7 cm
- 96 cm
- 38.3 kg
- Enclosure Colour
Display
- Resolution
- 3840 x 2160
- Display Format
- 4K UHD (2160p)
- 16:9
- Mini-LED
- Display Menu Language
- Multilingual
- Audio Description (AD), Dynamic Backlight Control, Gesture Control, sleep timer, Chromecast built-in, CalMAN auto calibration support, Apple AirPlay 2 support, text magnification, Accessibility shortcut, XR Triluminos Pro Display, BRAVIA CAM support, ECO Dashboard, PlayStation Remote Play, Proximity alert
Stands & Mounts
- Stand
- Included
- Stand Design
- Tabletop
- Stand Colour
- Dark silver
- Stand Features
- 4-way position, underlay stand
- Flat Panel Mount Interface
- 300 x 300 mm
- VESA Compatibility
TV Tuner
- Conditional Access
- Common Interface Plus (CI+) slot
Digital TV Tuner
- Digital TV Tuner
- HDTV Tuner
Video Features
- Electronic Programme Guide
- Digital EPG
- Closed Caption Capability
Media Player
- Supported Video Formats
- MPEG-1, MPEG-2, MPEG-4, Motion-JPEG, WMV, ASF, AVC, 3GPP, HEVC, VP9, VP8, AVS, AV1
- Supported Audio Formats
- MP3, WAV, AAC, FLAC (Free Lossless Audio Codec), LPCM, OGG, AC4
- Supported Pictures Formats
- JPEG
- USB Port
- USB Ports Qty
- 2
- Configuration
- 32 GB
Remote Control
- Remote control
- Battery Included
- Voice control
Audio System
- Digital Audio Format
- DTS-HD Master Audio output, DTS-HD High-Resolution Audio digital output, Dolby Atmos, DTS:X, Dolby Audio, DTS Express
- Surround Mode
- Sound Effects
- Speaker System
- Output Power / Total
- 40 Watt
- Audio Return Channel (ARC), Crystal Clear, Bass Reflex Speaker System, Acoustic Multi-Audio, Enhanced Audio Return Channel (eARC), Sound Positioning Tweeter, Room Compensation, User Position Compensation, Acoustic Center Sync, built-in microphone switch, 360 Spatial Sound Mapping, Voice Zoom 3
- Speakers
- 2 x speaker - 10 Watt , 2 x tweeter - 10 Watt
- Driver Details
- Speaker: 2 x full-range driver , Tweeter: 2
Network & Internet Multimedia
- Functionality
- WEB browsing, Internet video playback
- Connectivity
- LAN Protocol
- Ethernet
- Wi-Fi Protocol
- 802.11b, 802.11g, 802.11n, 802.11a, 802.11ac, 802.11ax
- Bluetooth Version
- Bluetooth 5.3
- Connect & Share
- Bluetooth Human Interface Device (HID)
- Supported Consumer Electronics Control (CEC)
- BRAVIA Sync Function
- Application Store
- Google Play
- Connector Type
- 4 x HDMI input - side , 2 x USB - side , LAN - side , Digital audio output - side
Internet of Things (IoT)
- Internet of Things (IoT) Compatible
- Platform
- Apple HomeKit
- CEC, HDCP 2.3
- Power Device
- Power supply
- Input Voltage
- 0.5 Watt
- Auto On/Off
- On/off timer
Dimensions & Weight Details
- Dimensions & Weight Details
- Panel without stand - 166.8 cm x 5.7 cm x 96 cm x 38.3 kg , Panel with stand and soundbar - 166.8 cm x 40.5 cm x 103.8 cm x 40.1 kg , Panel with stand (narrow position) - 166.8 cm x 40.5 cm x 98.4 cm x 40.1 kg , Dimensions between support feet - 144.2 cm
- Width (Shipping)
- 178.8 cm
- Depth (Shipping)
- 18 cm
- Height (Shipping)
- 113 cm
- Weight (Shipping)
- 50 kg
