RF45 , LED , FULL HD
Supports High Dynamic Range (HDR) video
Full HD for the best HD experience
X-Reality™ PRO for enhanced HD quality
More clarity, more detail with Full HD
Experience the exquisite detail, contrast, and texture of Full HD 1080p. With an image resolution of 1920 x 1080 pixels, Full HD provides five times more detail than a standard definition picture. Everything you watch is sharper, more defined, and more real with minimal noise and maximum impact. -
Rediscover every detail with X-Reality Pro
X-Reality Pro picture processing upscales every pixel for exceptional Full HD clarity. As frames are analyzed, each scene is matched with our special image database to refine images and reduce noise. -
Enjoy HDR gaming
Immerse yourself in a responsive, fun-filled gaming experience with intensely vibrant colors. See your favorite games come to life with incredible picture quality. -
Made to listen: ClearAudio+
Make your listening as lifelike as your viewing. ClearAudio+ fine-tunes TV sound for an immersive experience that seems to surround you. Hear music, dialog and surround effects with greater clarity and separation, whatever you're watching. -
Narrow aluminum look frame
The screen is edged with a slim, narrow frame that maximizes the viewing area. Its aluminum effect makes the TV look elegant and refined. -
Motionflow XR keeps the action smooth
Enjoy smooth and sharp details even in fast-moving sequences with Motionflow XR. This technology creates and inserts extra frames between the original ones. It compares key visual factors on successive frames, then calculates the split second of missing action in the sequences. Some models also include black-frame insertion for a blur-free and truly cinematic look. -
DSEE restores detail to your digital music
Low-resolution Internet video, catch-up TV and other heavily compressed audio files don't always sound so great. A large amount of information gets thrown away when digital audio is compressed. With Digital Sound Enhancement Engine (DSEE) technology, lost frequency components (especially high frequencies) are restored for natural sound with a more spacious feel. -
Clear Phase for smooth, balanced frequencies
Bravia uses a powerful computer model to analyzes and compensate for inaccuracies in speaker response. It does this by 'sampling' the speaker frequency with higher precision. This information is fed back to cancel out any peaks or dips in the speaker's natural response - resulting in pure, natural audio with smooth, even reproduction of all frequencies. -
Cinematic S-force front surround
Enjoy an immersive soundstage that pulls you into the heart of the action. S-force front surround mimics the way the brain correlates sound sources to create proper volume, time lag, and sound wave spectrum - using only left and right speaker channels. By naturally emulating three-dimensional sound fields, you'll enjoy rich, high-fidelity audio across a wider listening area.
- Sony KDL-43RF453 RF453 Series - 43" Class (42.5" viewable) LED-backlit LCD TV - Full HD
- Product Type
- LED-backlit LCD TV
- Diagonal Class
- 43"
- Diagonal Size
- 42.5"
- Black
- Platform
- Linux
- Resolution
- 1920 x 1080
- Display Format
- 1080p
- Input Video Formats
- 480p, 480i, 576i, 576p, 1080/24p, 1080/60i, 720/60p, 1080/50i, 720/50p, 1080/50p, 1080/60p, 1080/30p, 720/24p, 720/30p
- HDR Format
- HDR10, HLG10
- Frame Rate & Enhancement Technology
- Motionflow XR 400 technology, 50 Hz Native Refresh Rate
- Video Interface
- Composite, HDMI
- HDMI Ports Qty
- 2 ports
- Connectivity
- LAN
- LCD Backlight Technology
- Direct-lit LED frame dimming
- Image Aspect Ratio
- 16:9
- TV Tuner
- 1x analogue, 1x digital
- Digital TV Tuner
- DVB-C, DVB-T, DVB-T2
- Picture Enhancements
- Live Color, X-Reality PRO Engine, Dynamic Contrast Enhancer
- Speaker System
- 2 speakers
- Sound Effects
- S-FORCE Front Surround Sound, DTS Digital Surround
- USB
- 2 ports
- Included Accessories
- Remote control, batteries
- Voltage
- AC 230V (50 Hz)
- Energy Class
- Class A+
- 60 Watt
- Power Consumption (On mode)
- 51 W
- Power Consumption Stand by
- 0.5 Watt
- Energy Consumption per Year
- 74 kWh
- Dimensions (WxDxH) - without stand
- 97.4 cm x 6.8 cm x 57.2 cm
- 7.8 kg
- Product Type
- Energy Class
- Class A+
- 60 Watt
- 51 W
- 74 kWh
- Diagonal Class
- 43"
- Diagonal Size
- 42.5"
- Series
- RF453 Series
- Model Year
- 2018
- Platform
- Linux
- Operating System
- Linux
- HDR Capable
- HDR Format
- HDR10, HLG10
- TV Tuner
- TV Tuner Presence
- Video Interface
- Composite, HDMI
- HDMI Ports Qty
- 2 ports
- Modes
- Backlight off mode
- Design
- Narrow Frame Design
- Dimensions
- Without stand
- 97.4 cm
- 6.8 cm
- 57.2 cm
- 7.8 kg
- Enclosure Colour
- Black
Display
- Resolution
- 1920 x 1080
- Display Format
- 1080p
- 16:9
- Direct-lit LED - frame dimming
- Display Menu Language
- Multilingual
- Dynamic Backlight Control, 10-bit support
Stands & Mounts
- Stand
- Included
- Stand Design
- Tabletop
- Stand Colour
- Matt black chevron
- Flat Panel Mount Interface
- 200 x 200 mm
TV Tuner
- Conditional Access
- Common Interface Plus (CI+) slot
Digital TV Tuner
- Digital TV Tuner
- HDTV Tuner
Video Features
- Teletext
- Electronic Programme Guide
- Digital EPG
Media Player
- Supported Video Formats
- MPEG-1, MPEG-2, MPEG-4, Motion-JPEG, Xvid, WMV, AVI, MKV, AVCHD, TS, PS, WebM, HEVC
- Supported Audio Formats
- MP3, WMA, WAV, AC4
- Supported Pictures Formats
- JPEG
- USB Port
- USB Ports Qty
- 2
Remote Control
- Remote control
Audio System
- Digital Audio Format
- Dolby Digital output, Dolby Digital Plus output, Dolby Pulse output
- Surround Mode
- Sound Effects
- Speaker System
- 2 speakers
- Output Power / Total
- 10 Watt
- Audio Return Channel (ARC), Clear Phase Speaker, Digital Sound Enhancement Engine (DSEE), Clear Audio+
- Speakers
- 2 x speaker - 5 Watt
Network & Internet Multimedia
- Connectivity
- LAN
- LAN Protocol
- Ethernet
- Connector Type
- LAN - rear , 2 x HDMI input - side , Digital audio output (optical) - rear , 2 x USB , Composite video input - rear , Audio line-out / headphones / subwoofer - side
- Batteries
- Plug and Play, HDCP 1.4
- Power Device
- Power adapter
- Input Voltage
- AC 230V (50 Hz)
- 0.5 Watt
Dimensions & Weight Details
- Dimensions & Weight Details
- Panel without stand - 97.4 cm x 6.8 cm x 57.2 cm x 7.8 kg , Panel with stand - 97.4 cm x 26.8 cm x 62.8 cm x 8.2 kg
- Width (Shipping)
- 107 cm
- Depth (Shipping)
- 14.8 cm
- Height (Shipping)
- 69.2 cm
- Weight (Shipping)
- 12 kg
