By widening the color spectrum, this Sony TV reproduces more colors than a conventional television. It analyzes and processes data in every image to make colors even more natural and precise so pictures are closer than ever to real life.
Reproduces a wider, more precise range of colors
By widening the color spectrum, TRILUMINOS powered by Sony's X1 processors reproduces more colors than a conventional television. It analyzes and processes data in every image to make colors even more natural and precise so pictures are closer than ever to real life. -
Super resolution, whatever you're watching
See glorious 4K pictures, rich with real world detail and texture, exclusively powered by Sony's 4K HDR processor X1. Images filmed in 2K and even Full HD are upscaled close to 4K resolution by 4K X-Reality PRO using a unique 4K database. -
Less blur, even in fast scenes
On some screens, sports and fast action scenes go by in a blur. Sony's Motionflow technology keeps movement smooth and clear by creating extra images between images and black segments between scenes. The result Less blur and afterimage, more flowing motion. -
Object-based HDR remaster
With Object-based HDR remaster, the color in individual objects on screen is analyzed and the contrast adjusted, unlike most TVs where contrast is only adjusted along one black-to-white contrast curve. Because objects are remastered individually, this TV can reproduce greater depth, textures and more realistic pictures. -
No more waiting
Apps start fast and there's no more waiting when you switch between apps - Netflix starts 3x faster than before. -
Beautifully designed
Sony's premium design remote in brushed aluminum with hairline finish feels good in the hand and harmonizes with your living room. Control your TV even if there are objects in the way with Bluetooth connectivity and use a variety of simple one push buttons to easily manage key functions. -
Easy control with smart remote
Connect set top boxes and other devices via HDMI to your TV and control them all using one smart commander. A slimmer, more rounded design with built-in voice control microphone and enhanced button layout makes it really easy to use too. -
Clear Phase for smooth, balanced frequencies
BRAVIA uses a powerful computer model to analyze and compensate for inaccuracies in speaker response. It does this by "sampling" the speaker frequency with higher precision. This information is fed back to cancel out any peaks or dips in the speaker's natural response - resulting in pure, natural audio with smooth, even reproduction of all frequencies. -
Embrace the thrills of the cinema
Enjoy cinematic thrills at home. Dolby Vision brings scenes vividly to life for authentic viewing, while Dolby Atmos fills the room with immersive surround sound.
- Sony Bravia KD-43XH8196 43" Class (42.5" viewable) LED-backlit LCD TV - 4K
- Product Type
- LED-backlit LCD TV - Smart TV
- Diagonal Class
- 43"
- Diagonal Size
- 42.5"
- Black
- Platform
- Android TV
- Resolution
- 3840 x 2160
- Display Format
- 4K UHD (2160p)
- Input Video Formats
- 480p, 576p, 1080/24p, 1080/60i, 720/60p, 1080/50i, 720/50p, 1080/50p, 1080/60p, 1080/30p, 720/24p, 720/30p, 3840/25p, 3840/50p, 3840/24p, 3840/30p, 3840/60p, 4096/24p, 4096/50p, 4096/60p
- HDR Format
- HDR10, Dolby Vision, HLG10
- HDR Technology
- Object-based HDR remaster
- Frame Rate & Enhancement Technology
- Motionflow XR 400 technology, 50 Hz Native Refresh Rate
- Video Interface
- Composite, HDMI
- HDMI Ports Qty
- 4 ports
- Connectivity
- Wi-Fi, LAN, Bluetooth
- LCD Backlight Technology
- Edge-lit LED frame dimming
- Image Aspect Ratio
- 16:9
- TV Tuner
- 1x analogue, 1x digital
- Digital TV Tuner
- DVB-C, DVB-S, DVB-S2, DVB-T, DVB-T2
- Internet Streaming Services
- Netflix, YouTube, Voice Search, Chromecast, Google Play Movies & TV, Prime Video
- Picture Enhancements
- Live Color, 4K X-Reality PRO Engine, Dynamic Contrast Enhancer, dynamic backlight control
- Speaker System
- 2 speakers
- Sound Effects
- DTS Digital Surround
- Platform
- Google Home
- Intelligent Assistant
- Google Assistant, Alexa (not available for some languages and countries)
- Storage Capacity
- 16 GB
- USB
- 2 ports
- Included Accessories
- Remote control, batteries
- Voltage
- AC 230V (50 Hz)
- Energy Class
- Class G
- 108 Watt
- Power Consumption (On mode)
- 66 W
- Power Consumption Stand by
- 0.5 Watt
- Energy Consumption per Year
- 92 kWh
- Dimensions (WxDxH) - without stand
- 97 cm x 5.7 cm x 57 cm
- 9.4 kg
- Product Type
- Energy Class
- Class G
- Energy Class (HDR)
- Class G
- 108 Watt
- 66 W
- Power Consumption SDR (On mode)
- 66 kWh/1000h
- Power Consumption HDR (On mode)
- 84 kWh/1000h
- 92 kWh
- Diagonal Class
- 43"
- Diagonal Size
- 42.5"
- Model Year
- 2020
- Platform
- Android TV
- Operating System
- Android OS
- HDR Capable
- HDR Format
- HDR Technology
- Video Processor
- 4K HDR X1
- TV Tuner
- TV Tuner Presence
- Sensors
- Light sensor
- Video Interface
- Composite, HDMI
- HDMI Ports Qty
- 4 ports
- Modes
- Backlight off mode
- Design
- Narrow Bezel Design
- Dimensions
- Without stand
- 97 cm
- 5.7 cm
- 57 cm
- 9.4 kg
- Enclosure Colour
- Black
Display
- Resolution
- 3840 x 2160
- Display Format
- 4K UHD (2160p)
- 16:9
- Edge-lit LED - frame dimming
- Display Menu Language
- Multilingual
- Triluminos Display, CalMAN auto calibration support, text magnification
Stands & Mounts
- Stand
- Included
- Stand Design
- Tabletop
- Stand Colour
- Dark silver
- Stand Features
- Metal Blade Stand
- Flat Panel Mount Interface
- 100 x 200 mm
- VESA Compatibility
TV Tuner
- Conditional Access
- Common Interface Plus (CI+) slot
Digital TV Tuner
- Digital TV Tuner
- HDTV Tuner
Video Features
- Teletext
- Electronic Programme Guide
- Digital EPG
Media Player
- Supported Video Formats
- MPEG-1, MPEG-2, MPEG-4, Motion-JPEG, Xvid, WMV, ASF, AVI, MKV, MOV, AVCHD, TS, AVC, 3GPP, PS, VC-1, WebM, HEVC, VP8, XAVCS, HDV
- Supported Audio Formats
- MP3, WMA, WAV, AAC, FLAC (Free Lossless Audio Codec), ASF
- Supported Pictures Formats
- JPEG
- USB Port
- USB Ports Qty
- 2
- Configuration
- 16 GB
Remote Control
- Remote control
- Voice control
Audio System
- Digital Audio Format
- Dolby Atmos, Dolby Audio
- Surround Mode
- Sound Effects
- Speaker System
- 2 speakers
- Output Power / Total
- 20 Watt
- Audio Return Channel (ARC), Clear Phase Speaker, Bass Reflex Speaker System
- Speakers
- 2 x speaker - 10 Watt
- Driver Details
- Speaker: 1 x full-range driver
Network & Internet Multimedia
- Functionality
- WEB browsing, Internet video playback
- Connectivity
- LAN Protocol
- Ethernet
- Wi-Fi Protocol
- 802.11b, 802.11g, 802.11n, 802.11a, 802.11ac
- Bluetooth Version
- Bluetooth 4.2
- Connect & Share
- Bluetooth Human Interface Device (HID)
- Application Store
- Google Play
- Connector Type
- LAN - bottom , Composite video input - bottom , 3 x HDMI - side , HDMI - bottom , SPDIF output - bottom , Headphones - bottom , 2 x USB
Internet of Things (IoT)
- Internet of Things (IoT) Compatible
- Platform
- Google Home
- Batteries
- HDCP 2.3
- Power Device
- Power adapter
- Input Voltage
- AC 230V (50 Hz)
- 0.5 Watt
- Auto On/Off
Dimensions & Weight Details
- Dimensions & Weight Details
- Panel without stand - 97 cm x 5.7 cm x 57 cm x 9.4 kg , Panel with stand - 97 cm x 28.6 cm x 63 cm x 9.8 kg
- Width (Shipping)
- 107 cm
- Depth (Shipping)
- 14.1 cm
- Height (Shipping)
- 69.5 cm
- Weight (Shipping)
- 14 kg
