Enjoy crisp, clear, Full HD picture quality with KDL-40R483B. Make a connection between your smartphone and TV via Wi-Fi Direct to see photos and videos on the big display for a brighter, clearer view.
Bring clarity to everything you watch
Enjoy crisp, clear, Full HD picture quality with KDL-40R483B. Make a connection between your smartphone and TV via Wi-Fi Direct to see photos and videos on the big display for a brighter, clearer view. -
Bring images to life
With white LEDs arranged behind the TV display, Direct LED backlight screen technology produces distinctive contrast by delivering light to where it's needed most on the screen. -
Smoother, more natural movement
With Motionflow XR 100 Hz, every image on screen refreshes at a higher rate than normal. So fast-moving action sequences appear noticeably smoother, sharper, and more natural. -
Effortless style
With sharp edges and a slim design the R4 looks at home in any living room.
- Sony Bravia KDL-40R483B R480B Series - 40" LED-backlit LCD TV - Full HD
- Product Type
- LED-backlit LCD TV
- Diagonal Class
- 40"
- Black
- Resolution
- 1920 x 1080
- Display Format
- 1080p
- Input Video Formats
- 1080/24p, 1080/60i, 480/60p, 720/60p, 1080/50i, 720/50p, 576/50p, 1080/50p, 1080/60p, 1080/30p, 480/60i, 576/50i
- Frame Rate & Enhancement Technology
- Motionflow XR 100 technology
- 24p Technology
- 24p True Cinema
- Video Interface
- Component, composite, HDMI, SCART
- HDMI Ports Qty
- 2 ports
- Connectivity
- Wi-Fi, LAN
- HDCP Compatible
- LCD Backlight Technology
- Direct-lit LED
- Image Aspect Ratio
- 16:9
- TV Tuner
- 1x analogue, 1x digital
- Digital TV Tuner
- DVB-C, DVB-T, DVB-T2
- Speaker System
- 2 speakers
- Stereo Reception System
- NICAM, A2
- USB
- Included Accessories
- Sony RM-ED062 remote control
- Energy Class
- Class A
- 84 Watt
- Power Consumption (On mode)
- 58 W
- Power Consumption Stand by
- 0.45 Watt
- Energy Consumption per Year
- 85 kWh
- Dimensions (WxDxH) - without stand
- 92.6 cm x 8.9 cm x 55.6 cm
- 7 kg
- Product Type
- Energy Class
- Class A
- 84 Watt
- 58 W
- 85 kWh
- Diagonal Class
- 40"
- Series
- R480B Series
- TV Tuner
- TV Tuner Presence
- Video Interface
- HDMI Ports Qty
- 2 ports
- HDCP Compatible
- Modes
- Backlight off mode, Photo Frame mode
- Timer Functions
- Sleep, wake
- Dimensions
- Without stand
- 92.6 cm
- 8.9 cm
- 55.6 cm
- 7 kg
- Enclosure Colour
- Black
Display
- Resolution
- 1920 x 1080
- Display Format
- 1080p
- 16:9
- 24p Technology
- 24p True Cinema
- Direct-lit LED
- Widescreen Modes
- Zoom 14:9, Auto Wide, Full, Wide Zoom, Zoom, Normal, Caption
- Viewing Angle
- 178 degrees
- Viewing Angle (Vertical)
- 178 degrees
- Advanced Contrast Enhancer circuit (ACE), Live Color, CineMotion, Cinema Drive, Dynamic Backlight Control
Stands & Mounts
- Stand
- Included
- Stand Design
- Tabletop
- Stand Colour
- Black
- Flat Panel Mount Interface
TV Tuner
- Conditional Access
- Common Interface Plus (CI+) slot
- NICAM, A2
Digital TV Tuner
- Digital TV Tuner
- HDTV Tuner
Video Features
- Electronic Programme Guide
- Digital EPG
- Parental Channel Lock
Media Player
- Supported Video Formats
- MPEG-1, MPEG-2, MPEG-4, Motion-JPEG, Xvid, WMV, AVI, MKV, AVCHD, TS, PS, WebM
- Supported Audio Formats
- MP3, WMA, WAV
- Supported Pictures Formats
- JPG
- USB Port
- USB Ports Qty
- 1
Remote Control
- Remote control
- Remote Control Model
- Sony RM-ED062
- Scene Select
Audio System
- Digital Audio Format
- Dolby Digital output, Dolby Digital Plus output
- Audio Controls
- Sound mode
- Speaker System
- 2 speakers
- Output Power / Total
- 16 Watt
- Speakers
- 2 x main channel speaker - 8 Watt
Network & Internet Multimedia
- Connectivity
- Wi-Fi, LAN
- LAN Protocol
- Ethernet
- Connect & Share
- Wi-Fi Direct, Screen Mirroring, Mobile High-Definition Link (MHL)
- Supported Consumer Electronics Control (CEC)
- BRAVIA Sync Function
- Connector Type
- 2 x HDMI input - side , 2 x SCART - rear , USB - side , LAN - rear , Composite video / component video / audio input - bottom , Audio input - bottom , Audio line-out / headphones - bottom
- Power Device
- Power supply
- 0.45 Watt
Dimensions & Weight Details
- Dimensions & Weight Details
- Panel without stand - 92.6 cm x 8.9 cm x 55.6 cm x 7 kg , Panel with stand - 92.6 cm x 16.2 cm x 58.4 cm x 7.5 kg
- Width (Shipping)
- 120.2 cm
- Depth (Shipping)
- 13.5 cm
- Height (Shipping)
- 64.4 cm
