Sony 27" INZONE M3 Full HD 240Hz 1ms HDR IPS Gaming Monitor
Quicklinx: HP0KWS00 Mfr#: SDMF27M30AEP
Diagonal Size: 27in
Max Resolution: 1920 x 1080
Response Time: 1ms
Speakers: Built-in Stereo Speakers
Interfaces: HDMI, DisplayPort, USB
More than 50 In Stock
£165.84 ex VAT
£199.00 inc VAT
Express delivery Order within the next 11 hours for delivery on Monday
Fractions of a second matter. The incredibly fast refresh rate of the INZONE M3 puts you a step ahead of your competitors and lets you speed through scenes without lag, delay or judder.
React faster than your opponents. With a refresh rate of up to 240 Hz, you'll gain that vital split-second advantage that helps you track rivals precisely and shoot first. Action is super smooth in Full HD so you see what's happening the moment it happens.
  • 240 Hz and IPS 1 ms GtG, unbelievably fast
  • Aim precisely, shoot first with 240 Hz refresh rate
  • Enjoy rapid action with IPS 1 ms GtG
    Perform good on an IPS display with ultra fast 1 ms GtG response speed. Less ghosting and blur allows you to see what's happening with absolute clarity so you can make lightning fast decisions and react immediately.
  • DisplayHDR 400 certified, immersive viewing
    See a broader range of colors, darker shadows and brighter highlights. With DisplayHDR 400, INZONE M3 reproduces scenes in vivid shades with rich accurate contrast and high peak brightness of 400 nits for more immersive and atmospheric gaming.
  • A wide range of vibrant colors for gaming realism
    With over 99% coverage of the sRGB spectrum, the INZONE M3 monitor fills your game with a wide range of rich, vibrant colors. More shades and hues make scenes extremely realistic for dramatic, immersive gaming.
  • Designed to fit the way you play
    Game your way with a versatile design that adapts to your play style. The unique, low depth tripod stand provides total gaming comfort while optimizing desk space for peripherals.
  • Easily connect and control your gaming system
    Power up your gaming rig and connect all your peripherals in no time. A variety of options including HDMI port, DisplayPort 1.4 and USB Type-C (DisplayPort alternate mode) gives you the connectivity you need.
Sony INZONE M3 - LED monitor - Full HD (1080p) - 27" - HDR
LED-backlit LCD monitor - 27"
Energy Class
Class E
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080 at 240 Hz
Brightness
400 cd/m²
Contrast Ratio
1000:1 / 1000:1 (dynamic)
HDR Capable
HDR10 / DisplayHDR 400
Response Time
1 ms
Colour Support
1.07 billion colours
Input Connectors
2xHDMI, DisplayPort
Display Position Adjustments
Height, tilt
Screen Coating
Anti-glare
Voltage
AC 100-240 V (50 - 60 Hz)
61.5 cm x 7.3 cm x 36.3 cm
4.1 kg
1-year warranty
Display Type
Energy Class
Class E
Energy Class (HDR)
Class G
Diagonal Size
27"
Built-in Devices
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Brightness
400 cd/m²
Contrast Ratio
HDR Format
HDR10
HDR Certification
DisplayHDR 400
Colour Support
Response Time
1 ms
Vertical Refresh Rate
24 - 240 Hz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
LED backlight
OSD Languages
Chinese (traditional), Chinese (simplified), English, German, French, Italian, Polish, Russian, Spanish, Turkish, Japanese, Korean
Eco-Mode, game mode, Cinema Mode, Black eQualizer, FPS Mode, Flicker Free technology, Crosshair Display, Low Blue Light technology
61.5 cm x 7.3 cm x 36.3 cm - without stand
4.1 kg
Audio
Speakers - stereo
Output Power / Channel
4 Watt
2 x HDMI (HDCP) , DisplayPort 1.4 (HDCP) , USB upstream (Type B) , USB upstream (Type A) , 3 x USB downstream (Type A) , Headphones (mini-jack)
Mechanical
Height, tilt
Tilt Angle
0/+20
Height Adjustment
70 mm
VESA Mounting Interface
100 x 100 mm
Security Slot Type
Kensington security slot
Input Voltage
21.6 kWh/1000h
Power Consumption HDR (On mode)
31.1 kWh/1000h
Dimensions & Weight Details
Without stand - width: 61.5 cm - depth: 7.3 cm - height: 36.3 cm , With stand - width: 61.5 cm - depth: 24.8 mm - height: 47.9 cm - weight: 6.2 kg
Shipping Width
69 cm
Shipping Depth
22.8 cm
Shipping Height
46.2 cm
Limited warranty - 1 year
Used stock
What is used stock?
Accessories Packaging Functional Software Manuals
Ref: HP0K 051128
Condition: Customer return - item has been opened but is in excellent condition
This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is not present or functional  This part of the stock item is present and in good condition  £143.39
Legend
  • This part of the stock item is present and in good conditionThis part of the stock item is present and in good condition
  • This part of the stock item is not present or functionalThis part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standardThis part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.This item has not been tested.
Diagonal Size: 27in
Response Time: 1ms
Interfaces: HDMI
Interfaces: DisplayPort
Interfaces: USB
Brand: Sony
Stock Status: Used Stock
Stock Status: Clearance
