Sony 2500 ANSI Lumens XGA Projector - 1.7kg -
Quicklinx: 7SB3WS00 Mfr#: VPL-MX25
The VPL-MX25 is the ultimate personal projector for people on the move. This projector has been designed for the style conscious professionals in a contemporary metallic chassis. Furthermore, it has been developed for maximum mobility - it is lightweight and easy to carry. The projector's five step advanced intelligent auto set up feature means it is quick and simple to operate. In addition, the off-and-go function means it can be unplugged immediately after being switched off.
By combining an optical system that incorporates Sony's innovative BrightEra with Long Lasting Optics technology and a 3LCD projection system, the VPL-MX25 delivers high picture quality in XGA (1024 x 768) resolution and a high brightness of 2500 lumens. This allows professional presentations to be delivered in virtually any setting. Built-in wireless connectivity eliminates the need for computer cables.
  • BrightEra with Long Lasting Optics technology
    This is a more advanced version of Sony's original BrightEra technology which was developed to deliver improved panel light resistance, higher brightness, higher resolution and increased panel reliability. This technology incorporates inorganic polarizers.
  • Color light output - 2500 lumens
    Color light output is a metric that measures a projector's ability to deliver color. Color light output provides users with a simple, accurate and easy to understand way to evaluate projector color performance to make better buying decisions.
  • Video streaming
    Seamlessly integrate video with your presentation. The embedded Windows Media Player means you can stream video files from your PC, network or USB storage device.
  • USB file viewer
    Save your content on almost any USB storage device, insert it into the projector and begin presenting. A Microsoft Office and PDF viewer is built-in for true PC-less presenting.
  • Ultra-portable
    With a magnesium ergonomic curved edge body design, it's simply the ultimate in mobility, durability and style.
  • Dynamic Detail Enhancer (DDE)
    Dynamic Detail Enhancer (DDE) generates high quality images through the Interlace/Progressive conversion processor, resulting in extremely accurate image reproduction.
Sony VPL MX25 - LCD projector
LCD projector
Black, silver
27.3 cm x 20.6 cm x 4.5 cm
1.7 kg
Image Brightness
2500 ANSI lumens
Image Contrast Ratio
650:1
Resolution
XGA (1024 x 768)
Native Aspect Ratio
4:3
Bulb type
UHP 200 Watt
Bulb life cycle
2000 hour(s) / 3000 hour(s) (economic mode)
Video Input
RGB, composite video, component video ( SECAM, PAL, PAL-N, PAL-M, NTSC 4.43, PAL 60, NTSC 3.58 ) , IEEE 802.11a/g wireless
Video Modes
575/50i, 575/50p, 1080/60i, 480/60p, 720/60p, 1080/50i, 720/50p, 480/60i
Input Device
Remote control
AC 120/230 V ( 50/60 Hz )
290 Watt
3 years warranty
LCD projector
27.3 cm
20.6 cm
4.5 cm
1.7 kg
Enclosure Colour
Black, silver
Projector / Panel
Image Brightness
2500 ANSI lumens
Image Brightness (Reduced)
2000 ANSI lumens
650:1
Image Size
76 cm - 381 cm
Resolution
XGA - XGA (1024 x 768) (native) / 1400 x 1050 (resized)
Native Aspect Ratio
4:3
Max Sync Rate (V x H)
92 Hz x 80 kHz
Bulb type
UHP 200 Watt
Bulb life cycle
BrightEra
Projector Lens System
Lens Aperture
F/1.65-1.8
Zoom Type
Powered
Zoom Factor
1.2x
Keystone Correction Direction
Vertical
Vertical Keystone Correction
-30 / +30
Video Input
Analogue Video Format
Analogue video Signal
Video Modes
LAN and Wireless Image Transferring Protocols
IEEE 802.11b, IEEE 802.11g, IEEE 802.11a
Input Device
Remote control
1 x composite video input - RCA , 1 x component video / RGB input - 15 pin HD D-Sub (HD-15) , 1 x USB - 4 PIN USB Type A
Carrying case
1 x VGA cable - 2 m
FCC Class B certified, CE, IC Class B, CSA, VCCI, C-Tick, cUL, DEMKO, CB, EMC, EK, IEC 60950-1, EN 60950-1, JEITA
Power supply - internal
290 Watt
3 years warranty
Service & Support Details
Limited warranty - 3 years - pick-up and return , Technical support - phone consulting - 3 years
35 °C
35 - 85%
Sound Emission
44 dB
38 dB
