The VPL-MX25 is the ultimate personal projector for people on the move. This projector has been designed for the style conscious professionals in a contemporary metallic chassis. Furthermore, it has been developed for maximum mobility - it is lightweight and easy to carry. The projector's five step advanced intelligent auto set up feature means it is quick and simple to operate. In addition, the off-and-go function means it can be unplugged immediately after being switched off.
By combining an optical system that incorporates Sony's innovative BrightEra with Long Lasting Optics technology and a 3LCD projection system, the VPL-MX25 delivers high picture quality in XGA (1024 x 768) resolution and a high brightness of 2500 lumens. This allows professional presentations to be delivered in virtually any setting. Built-in wireless connectivity eliminates the need for computer cables.
This is a more advanced version of Sony's original BrightEra technology which was developed to deliver improved panel light resistance, higher brightness, higher resolution and increased panel reliability. This technology incorporates inorganic polarizers. -
Color light output - 2500 lumens
Color light output is a metric that measures a projector's ability to deliver color. Color light output provides users with a simple, accurate and easy to understand way to evaluate projector color performance to make better buying decisions. -
Video streaming
Seamlessly integrate video with your presentation. The embedded Windows Media Player means you can stream video files from your PC, network or USB storage device. -
USB file viewer
Save your content on almost any USB storage device, insert it into the projector and begin presenting. A Microsoft Office and PDF viewer is built-in for true PC-less presenting. -
Ultra-portable
With a magnesium ergonomic curved edge body design, it's simply the ultimate in mobility, durability and style. -
Dynamic Detail Enhancer (DDE)
Dynamic Detail Enhancer (DDE) generates high quality images through the Interlace/Progressive conversion processor, resulting in extremely accurate image reproduction.
- Sony VPL MX25 - LCD projector
- LCD projector
- Black, silver
- 27.3 cm x 20.6 cm x 4.5 cm
- 1.7 kg
- Image Brightness
- 2500 ANSI lumens
- Image Contrast Ratio
- 650:1
- Resolution
- XGA (1024 x 768)
- Native Aspect Ratio
- 4:3
- Bulb type
- UHP 200 Watt
- Bulb life cycle
- 2000 hour(s) / 3000 hour(s) (economic mode)
- Video Input
- RGB, composite video, component video ( SECAM, PAL, PAL-N, PAL-M, NTSC 4.43, PAL 60, NTSC 3.58 ) , IEEE 802.11a/g wireless
- Video Modes
- 575/50i, 575/50p, 1080/60i, 480/60p, 720/60p, 1080/50i, 720/50p, 480/60i
- Input Device
- Remote control
- Power
- AC 120/230 V ( 50/60 Hz )
- 290 Watt
- 3 years warranty
- LCD projector
- 27.3 cm
- 20.6 cm
- 4.5 cm
- 1.7 kg
- Enclosure Colour
- Black, silver
Projector / Panel
- Image Brightness
- 2500 ANSI lumens
- Image Brightness (Reduced)
- 2000 ANSI lumens
- 650:1
- Image Size
- 76 cm - 381 cm
- Resolution
- XGA - XGA (1024 x 768) (native) / 1400 x 1050 (resized)
- 4:3
- Max Sync Rate (V x H)
- 92 Hz x 80 kHz
- Bulb type
- UHP 200 Watt
- Bulb life cycle
- BrightEra
Projector Lens System
- Lens Aperture
- F/1.65-1.8
- Zoom Type
- Powered
- Zoom Factor
- 1.2x
- Keystone Correction Direction
- Vertical
- Vertical Keystone Correction
- -30 / +30
Video Input
- Analogue Video Format
- SECAM, PAL, PAL-N, PAL-M, NTSC 4.43, PAL 60, NTSC 3.58
- Analogue video Signal
- Video Modes
- LAN and Wireless Image Transferring Protocols
- IEEE 802.11b, IEEE 802.11g, IEEE 802.11a
Input Device
- Remote control
- 1 x composite video input - RCA , 1 x component video / RGB input - 15 pin HD D-Sub (HD-15) , 1 x USB - 4 PIN USB Type A
- Included Accessories
- Carrying case
- Cables Included
- 1 x VGA cable - 2 m
- FCC Class B certified, CE, IC Class B, CSA, VCCI, C-Tick, cUL, DEMKO, CB, EMC, EK, IEC 60950-1, EN 60950-1, JEITA
- Power Device
- Power supply - internal
- Voltage Required
- 290 Watt
- 3 years warranty
- Service & Support Details
- Limited warranty - 3 years - pick-up and return , Technical support - phone consulting - 3 years
- 0 °C
- 35 °C
- 35 - 85%
- Sound Emission
- 44 dB
- Sound Emission (Economic Mode)
- 38 dB
