Versatile zoom capability
Equipped with an optical zoom of 1.78, the Sony VPLL-Z4045 telephoto zoom lens offers flexibility in adjusting the projection size without moving the projector, making it ideal for various room sizes and distances. -
High-quality imaging
With a lens aperture range of f/2.2-3.6, this lens system ensures bright and clear images under different lighting conditions, enhancing the viewing experience. -
Extended throw ratio
The throw ratio of 4.5-8.0:1 allows for large images to be projected from a considerable distance, making this lens suitable for large venues such as auditoriums and conference halls.
- Sony VPLL-Z4045 - telephoto zoom lens - 119.3 mm - 217.1 mm
- Lens System
- Telephoto zoom lens
- Intended For
- Projector
- Lens Aperture
- F/2.2-3.6
- Focal Length
- Optical Zoom
- 1.78 x
- Special Functions
- Tele, zoom
- Length
- 23.5 cm
- 3 kg
- Designed For
- VPL-FH300L, FHZ131, FHZ91, FW300L
- Length
- 23.5 cm
- 14.8 cm
- 13.3 cm
- 3 kg
Lens System
- Special Functions
- Tele, zoom
- Intended For
- Projector
- Focal Length
- Lens Aperture
- F/2.2-3.6
- Optical Zoom
- 1.78 x
- Throw Ratio
- 4.5-8.0:1
- Designed For
- Sony VPL-FH300L, FHZ131, FHZ91, FW300L
