Sonos Ray Soundbar - Black
Quicklinx: H8XSWS00 Mfr#: RAYG1UK1BLK
Experience precisely balanced sound, including crisp dialog and solid bass, plus streamlined control with your TV remote, the Sonos app, Apple AirPlay 2, and more. And the forward-facing acoustics make Ray ideal for an enclosed space, like a shelf in your TV stand. Enjoy the flexibility to create the Sonos system you want over time when you add speakers for surround sound and multiroom listening.
  • All about balance
    Enjoy stereo sound that's just right. The custom acoustics precisely harmonize high and mid-range frequencies while proprietary anti-distortion technology produces perfectly weighted bass.
  • Crisp dialog
    Never miss a word. Fine-tuned with help from award-winning Hollywood sound engineers, Ray ensures you can always follow the story.
  • Brings the drama
    Feel like you're at the center of it all. Split waveguides project sound from wall to wall, and advanced processing accurately positions elements in the room.
  • Tuned to perfection
    Trueplay tuning technology adapts the sound for the unique acoustics of your space so content always sounds just the way it should.
  • Designed to be tucked away
    All the acoustic elements face forward to minimize interference from nearby surfaces so, even if you place it in your TV stand, Ray always sounds phenomenal.
  • Nothing gets in the way of your entertainment
    The compact and understated design seamlessly blends into your home and won't pull focus from what's happening on screen.
  • No strings attached
    Make game days, film nights, and music more immersive when you add a pair of rear speakers for wireless surround sound.
  • Listen here, there, everywhere
    Play your way with speakers in every room. Enjoy TV in the living room while you stream music in the bedroom, and group your system for whole-home listening.
Sonos Ray - sound bar - wireless
Sound bar
Enclosure Design
Bass reflex
Speaker Type
2-way - active
Amplifier Output Power
D
Amplifier
Integrated
Ethernet, Fast Ethernet, Wi-Fi
AirPlay
Streaming Services
Spotify Connect
Speaker Details
Sound bar - stereo x 2 - 2-way - active
AC 100-240 V (50/60 Hz)
55.9 cm x 9.5 cm x 7.1 cm
1.95 kg
Sound bar
Enclosure Colour
Enclosure Design
Bass reflex
Design Features
Matte finish, touch control
Speaker System
Speaker Type
2-way - active
Amplifier
Integrated
Amplifier Class
D
IEEE 802.3 (Ethernet), IEEE 802.3u (Fast Ethernet), IEEE 802.11b/g/n
AirPlay
Internet Streaming Services
Spotify Connect
App-Controlled
Speaker System Details
Speaker Details
Driver Details
Sound bar: 2 x tweeter driver , Sound bar: 2 x mid/woofer driver
Connector Type
Digital audio input (optical) (TOS Link) , LAN (RJ-45)
Digital audio cable (optical) (1.5 m)
Power Source
Integrated power supply
55.9 cm
9.5 cm
7.1 cm
1.95 kg
