Sonos One (Gen2) Smart Speaker - White
Quicklinx: FWZMWS00 Mfr#: ONEG2UK1
Colours:
Smart Sound
The powerful smart speaker with voice control built-in.
Sonos One gives you rich, room-filling sound and has the Google Assistant and Amazon Alexa built right in for simple voice control of your music and more. Ask for songs while you cook. Easily turn the volume up while you’re in the shower. You can even request a lullaby, out loud, when you’re putting the kids to bed.
Sonos One connects to the Google Assistant or Amazon Alexa over WiFi. Just plug in the speaker and follow step-by-step instructions in the app. In minutes you’re ready to play music, get news and answers, manage your smart devices, and enjoy all the conveniences of your voice assistant with nothing but your Sonos One.
Anyone in your home can take charge of the music. Kids can call out their favorite sing-alongs. Friends can skip or replay tracks and adjust audio settings. Guests can request their favorite songs in real time. No matter who says it, Sonos plays it.
Brilliant sound for every room
The compact design fits just about any space. Put it on your kitchen countertop or tuck it away on your office bookshelf. It's humidity resistant so you can even put it in the bathroom.
Voice control
The Google Assistant and Amazon Alexa are built right-in so you can play music, check news, set alarms, get your questions answered, and more, completely hands-free.
Stereo sound with two
Pair two Sonos Ones together in the same room for stereo separation and more detailed sound. Use a pair as rear home cinema surrounds with Playbar, Playbase, or Beam.
Build your system
Easily connect Sonos speakers in different rooms over WiFi to create a home sound system that brings every room and everyone together.
Brilliant sound
Enjoy clear, richly detailed sound that fills the room at any volume.
Easy to use
Setup takes minutes, and control is simple with the Sonos app, AirPlay 2, and your voice.
Listen your way
Customise your system and play what you want, where you want.
Introducing Sonos Radio
Enjoy thousands of stations, including live radio and exclusive programming, on your system through the Sonos app.
Sonos One (Gen2) - smart speaker
Smart speaker
United Kingdom
Speaker Type
2-way - active
Ethernet, Fast Ethernet, Wi-Fi
Intelligent Assistant
Alexa - direct
Audio Formats
WAV, WMA, AAC, AIFF, Ogg Vorbis, MP3, FLAC, Apple Lossless, AAC +
White
11.97 cm x 11.97 cm x 16.145 cm
1.76 kg
Smart speaker
Microphone
6 microphones array
Enclosure Colour
White
Grille Colour
Matt white
United Kingdom
Speaker System
Speaker Type
2-way - active
Connection Options
Bi-amping
Multiroom
Amplifier
Integrated
IEEE 802.3 (Ethernet), IEEE 802.3u (Fast Ethernet), IEEE 802.11b/g
Audio Formats
Controls
Volume, play/pause, next track, previous track, mute microphone
Internet of Things (IoT)
Alexa
Voice Control
Direct
Speaker System Details
Driver Details
Tweeter driver , Mid-range driver
Connector Type
LAN (RJ-45)
Ethernet cable
Power Source
Integrated power supply
11.97 cm
11.97 cm
16.145 cm
1.76 kg
Shipping Width
17.4 cm
Shipping Depth
17.4 cm
Shipping Height
24.7 cm
Shipping Weight
2.39 kg
