Listen Anywhere
The durable, battery-powered smart speaker for outdoor and indoor listening.
Get brilliant sound anywhere with the weatherproof and drop-resistant Move. Control with your voice, the Sonos app, and Apple AirPlay 2 at home, and stream via Bluetooth when WiFi isn't available.
Finely tuned to your surroundings
Enjoy surprisingly rich bass, a wide soundstage, and automatic Trueplay™ tuning, which continually adapts the sound for where you are and what you’re listening to.
Voice Control
The Google Assistant and Amazon Alexa are built right in so on WiFi you can play music, check news, set alarms, get your questions answered, and more, completely hands free.
WiFi and Bluetooth
Stream over WiFi and connect Move to the rest of your Sonos system at home. Switch to Bluetooth when you're offline.
Weather-resistant
With an IP56 rating, Move stands up to humidity, rain, snow, dust, salt spray, UV rays, and extreme heat and cold.
Simple recharging
Get up to 11 hours of battery life. Set the speaker on the included indoor charging base for quick power whilst you listen, and get power wherever you need it with an additional charging base.
Introducing Sonos Radio
Enjoy thousands of stations, including live radio and exclusive programming, on your system through the Sonos app.
- Sonos Move - smart speaker - for portable use
- Product Type
- Smart speaker - for portable use
- Protection
- Weatherproof, drop-proof
- Localisation
- United Kingdom
- Speaker Type
- 2-way - active
- Bluetooth, Wi-Fi, Wi-Fi
- Intelligent Assistant
- Alexa - direct
- AirPlay
- Speaker Details
- Speaker - mono - 2-way - active
- Black
- Power
- AC 120/230 V (50/60 Hz)
- Battery
- Speaker battery rechargeable - Lithium Ion
- 2-year warranty
- Product Type
- Microphone
- Protection
- Enclosure Colour
- Black
- Grille Colour
- Black
- Localisation
- United Kingdom
Speaker System
- Speaker Type
- 2-way - active
- Connection Options
- Bi-amping
- Amplifier
- Integrated
- Bluetooth, IEEE 802.11b/g/n, Wi-Fi
- AirPlay
- Recommended Placing
- Indoor / Outdoor
- App-Controlled
Internet of Things (IoT)
- Internet of Things (IoT) Compatible
- Communications Type
- Cloud
- Alexa
- Voice Control
- Direct
Speaker System Details
- Speaker Details
- Driver Details
- Tweeter driver , Mid/woofer driver
- Included Accessories
- Charging base
- IP56
- Power Source
- AC power adapter, battery
- Voltage Required
- Rechargeable - Lithium Ion
- Run Time (Up To)
- 10 hour(s)
- Limited warranty - 2 years
