Sonos Era 300 - White
Quicklinx: H8XXWS00 Mfr#: E30G1UK1
With next-level audio that hits from every direction, Era 300 doesn’t just surround you, it puts you inside your music.
  • Take your spatial audio experience above and beyond
    Featuring six optimally positioned drivers all around the front, sides, and top to support Dolby Atmos music, the breakthrough acoustic design projects sound from wall to wall and floor to ceiling, immersing you in every dimension of the song.
  • Make the whole room the sweets pot
    No matter where you are or what you play, the listening experience is nothing short of extraordinary. Custom waveguides accurately disperse sound right, left, forward, and above, creating a sensationally spacious stereo soundstage you can feel all around the room.
  • An acoustic and aesthetic masterpiece
    The first-of-its-kind design exquisitely balances sonic performance and visual appeal, precisely angling each driver while looking worthy of display.
  • Surround sound so real it's surreal
    Experience mind-bending surround sound when you pair two speakers with Arc or Beam (Gen 2). Supercharged by Dolby Atmos, the lateral and overhead channels in each product create an all-encompassing soundstage.
  • Bewilderingly easy to set up
    Go from unboxing to unbelievable sound in just a few minutes. Simply plug in the power cable, connect your phone or tablet to Wi-Fi, and open the Sonos app.
  • Tunes itself for you
    With a tap in the Sonos app, Trueplay tuning technology analyses the unique acoustics of your space and optimizes the speaker's EQ. So all your content sounds just the way it should.
  • Your voice, your choice
    Era 300 is designed for ease of listening and mind, with multiple ways to protect your privacy.
Sonos Era 300 - speaker - wireless
Speaker
2GB RAM
Integrated Memory
Flash - 8 GB
Protection
Moisture-proof
Speaker Type
Active
Amplifier Output Power
D
Amplifier
Integrated
Bluetooth, Wi-Fi 6
Intelligent Assistant
Alexa, Sonos - direct
AirPlay
Speaker Details
Speaker - stereo
White
Built-in Decoders
Dolby Atmos
AC 100-240 V (50/60 Hz)
26 cm x 18.5 cm x 16 cm
4.47 kg
Speaker
2GB RAM, Trueplay, Quad Core A53 1.4 GHz
Integrated Memory
Flash - 8 GB
Light
LED lights
Microphone
Protection
Moisture-proof
Enclosure Colour
White
Design Features
Matte finish
Speaker System
Speaker Type
Active
Amplifier
Integrated
Amplifier Class
D
Bluetooth 5.0, IEEE 802.11a/b/g/n/ac/ax
AirPlay
Recommended Placing
Indoor, wall/stand mountable
Built-in Decoders
Dolby Atmos
Controls
Mute, volume, play/pause, activate Bluetooth, mute microphone, repeat, skip
App-Controlled
Internet of Things (IoT)
Alexa, Sonos
Voice Control
Direct
Speaker System Details
Speaker Details
Speaker - stereo
Driver Details
Speaker: 4 x midrange/tweeter driver , Speaker: 2 x subwoofer driver
Connector Type
USB (USB Type-C)
Power cable (2 m), Apple Music (3 months subscription)
Power Source
Integrated power supply
26 cm
18.5 cm
16 cm
4.47 kg
