Featuring next-gen acoustics and new levels of connectivity, Era 100 transforms any room with the finely tuned stereo sound and rich bass your music deserves.
Superb sonic power
Next-gen acoustics bring your music to life with detailed stereo separation and deep bass at any volume. -
Minor scale for major versatility
Place this speaker anywhere and everywhere you want to listen. The compact design fits beautifully on your bookshelf, kitchen counter, desk, or nightstand. -
Breeze through setup
Go from unboxing to unbelievable sound in just a few minutes. Simply plug in the power cable, connect your phone or tablet to Wi-Fi, and open the Sonos app. -
Tunes itself for you
With a tap in the Sonos app, Trueplay tuning technology analyzes the unique acoustics of your space and optimizes the speaker's EQ. So all your content sounds just the way it should.
- Sonos Era 100 - speaker - wireless
- Product Type
- Speaker
- 2GB RAM
- Integrated Memory
- Flash - 8 GB
- Speaker Type
- Active
- Amplifier Output Power
- D
- Amplifier
- Integrated
- Bluetooth, Wi-Fi 6
- Intelligent Assistant
- Google Assistant, Alexa, Sonos - direct
- AirPlay
- White
- Power
- AC 100-240 V (50/60 Hz)
- 12 cm x 13.05 cm x 18.25 cm
- 2.02 kg
- Product Type
- Speaker
- 2GB RAM, stereo pairing, Trueplay, Quad Core A53 1.4 GHz
- Integrated Memory
- Flash - 8 GB
- Light
- LED lights
- Microphone
- Far field microphone array
- Sensors
- Touch control
- Enclosure Colour
- White
- Design Features
- Matte finish
Speaker System
- Speaker Type
- Active
- Amplifier
- Integrated
- Amplifier Class
- D
- Bluetooth 5.0, IEEE 802.11a/b/g/n/ac/ax
- AirPlay
- Recommended Placing
- Wall/stand mountable
- Controls
- Volume, play/pause, activate Bluetooth, mute microphone, repeat, skip
- App-Controlled
Internet of Things (IoT)
- Internet of Things (IoT) Compatible
- Voice Control
- Direct
Speaker System Details
- Driver Details
- Speaker: 2 x tweeter driver , Speaker: mid/woofer driver
- Connector Type
- USB (USB Type-C)
- Included Accessories
- Power cable (2 m), Apple Music (3 months subscription)
- Power Source
- Integrated power supply
- Voltage Required
- 12 cm
- 13.05 cm
- 18.25 cm
- 2.02 kg
