Sonos Era 100 - Black
Quicklinx: H8XWWS00 Mfr#: E10G1UK1BLK
Featuring next-gen acoustics and new levels of connectivity, Era 100 transforms any room with the finely tuned stereo sound and rich bass your music deserves.
  • Superb sonic power
    Next-gen acoustics bring your music to life with detailed stereo separation and deep bass at any volume.
  • Minor scale for major versatility
    Place this speaker anywhere and everywhere you want to listen. The compact design fits beautifully on your bookshelf, kitchen counter, desk, or nightstand.
  • Breeze through setup
    Go from unboxing to unbelievable sound in just a few minutes. Simply plug in the power cable, connect your phone or tablet to Wi-Fi, and open the Sonos app.
  • Tunes itself for you
    With a tap in the Sonos app, Trueplay tuning technology analyzes the unique acoustics of your space and optimizes the speaker's EQ. So all your content sounds just the way it should.
Sonos Era 100 - speaker - wireless
Speaker
2GB RAM
Integrated Memory
Flash - 8 GB
Speaker Type
Active
Amplifier Output Power
D
Amplifier
Integrated
Bluetooth, Wi-Fi 6
Intelligent Assistant
Google Assistant, Alexa, Sonos - direct
AirPlay
AC 100-240 V (50/60 Hz)
12 cm x 13.05 cm x 18.25 cm
2.02 kg
Speaker
2GB RAM, stereo pairing, Trueplay, Quad Core A53 1.4 GHz
Integrated Memory
Flash - 8 GB
Light
LED lights
Microphone
Far field microphone array
Sensors
Touch control
Enclosure Colour
Design Features
Matte finish
Speaker System
Speaker Type
Active
Amplifier
Integrated
Amplifier Class
D
Bluetooth 5.0, IEEE 802.11a/b/g/n/ac/ax
AirPlay
Recommended Placing
Wall/stand mountable
Controls
Volume, play/pause, activate Bluetooth, mute microphone, repeat, skip
App-Controlled
Internet of Things (IoT)
Voice Control
Direct
Speaker System Details
Driver Details
Speaker: 2 x tweeter driver , Speaker: mid/woofer driver
Connector Type
USB (USB Type-C)
Power cable (2 m), Apple Music (3 months subscription)
Power Source
Integrated power supply
12 cm
13.05 cm
18.25 cm
2.02 kg
