Sonos Beam (Gen 2) Compact Smart Soundbar with Dolby Atmos Black
Quicklinx: GP67WS00 Mfr#: BEAM2UK1BLK
Audio System Type: Soundbar
Surround system: [N/A]
Colours:
£374.17 ex VAT
£449.00 inc VAT
Beam: The Small But Smart TV Soundbar
Enrich all your entertainment with the latest generation of Sonos compact smart soundbar, now with Dolby Atmos.
Experience panoramic sound and crystal clear dialogue for shows, movies, and games. And when the TV is off, stream music and more from all your favorite services. Control is easy with the Sonos app, your voice, and Apple AirPlay 2. Add speakers to create a wireless surround sound system and enjoy multiroom listening. Everything connects over WiFi.
Exceptional sound all around
Dolby Atmos maps sounds in space for a 3D effect so you experience planes as if they're flying overhead, hear footsteps moving across the room, and feel the score surround you.
Crystal clear dialogue
Oscar-winning sound engineers helped fine-tune Beam to make sure you hear every word and can always follow the story. For even greater clarity when characters whisper or the action intensifies, turn on Speech Enhancement in the Sonos app.
High quality even at low volumes
Advanced audio processing ensures balanced sound from wall to wall at any volume level. When you want to watch TV but need to keep it down, turn on Night Sound in the app to reduce the intensity of loud effects and enhance quieter ones.
Made for music
Stream from all your favourite services with detailed stereo sound, and feel more dimensions of the song with support for the highest-resolution formats, including Dolby Atmos Music.
Breeze through setup
Go from unboxing to unbelievable sound in minutes with only two cables and step-by-step guidance from the Sonos app.
Tuned to perfection
Trueplay tuning technology adapts the sound for the unique acoustics of the room so your content always sounds just the way it should.
Freedom of control
Sonos app
Connect all your streaming services, discover new music on Sonos Radio, and personalise settings.
TV remote
The soundbar syncs with your existing remote for streamlined control and no extra clutter.
Touch
Tap or swipe the top of the soundbar to pause the music, adjust the volume, skip a track, and more.
Apple AirPlay 2
Send sound directly from your iPhone, iPad, or Mac, then ask Siri to turn it up from your device.
Hands-free help
Ask Amazon Alexa or Google Assistant to set timers, check the news, control your smart home devices, and more.
  • Smarter on the inside
    A 40% faster chip pushes the sonic limits for a soundbar this size, creating two new audio paths for a virtual surround sound experience.
  • More beautiful on the outside
    The new precisely perforated grille elevates the elegant design and blends seamlessly into your home, whether you place Beam on furniture or mount it.
  • Exceptional sound all around
  • Crystal clear dialogue
  • Made for music
    Stream music, radio, audiobooks and podcasts from all your favorite services with detailed stereo sound that fills the room.
  • Breeze through setup
  • Tuned to perfection
  • Sonos app
    Connect all your streaming services, discover new music on Sonos Radio, and personalize settings.
  • TV Remote
  • Touch
  • Apple AirPlay 2
Sonos Beam (Gen 2) - sound bar - wireless
Sound bar
Enclosure Design
Passive radiator
Speaker Type
Active
Amplifier Output Power
D
Amplifier
Integrated
Ethernet, Fast Ethernet, IEEE 802.11b/g/n/ac
Intelligent Assistant
Alexa built-in - direct
AirPlay
Audio Formats
PCM
Built-in Decoders
Dolby Digital, Dolby Atmos, Dolby Digital Plus, Dolby TrueHD
AC 100-240 V (50 - 60 Hz)
65.1 cm x 10 cm x 6.9 cm
2.8 kg
Sound bar
Microphone
5 far field microphones
Enclosure Colour
Enclosure Design
Passive radiator
Design Features
Touch control, matte finish
Speaker System
Speaker Type
Active
Amplifier
Integrated
Amplifier Class
D
Audio Return Channel (ARC) Capability
IEEE 802.3 (Ethernet), IEEE 802.3u (Fast Ethernet), IEEE 802.11b/g/n/ac
AirPlay
Recommended Placing
On-wall mounted, desktop
Built-in Decoders
Audio Formats
PCM
Controls
Volume, play/pause, next track, previous track, mute microphone
App-Controlled
Internet of Things (IoT)
Communications Technology
Wi-Fi
Alexa built-in
Voice Control
Direct
Speaker System Details
Driver Details
Sound bar: tweeter driver , Sound bar: 4 x mid/woofer driver , Sound bar: 3 x Passive Radiator
Connector Type
HDMI (19 pin HDMI Type A) , LAN (RJ-45)
HDMI cable, audio (optical) adapter
Power Source
Integrated power supply
65.1 cm
10 cm
6.9 cm
2.8 kg
Brand: Sonos
