A fast connection to your business, school, remote office or retail site is only half the story; you also need to be able to securely manage it. The TZ600 gives you enterprise-grade protection to stop cyberattacks as you expand and control your network.
Full-featured, advanced security
Deliver full-featured security that combines intrusion prevention, gateway anti-virus, anti-spyware, content filtering and anti-spam services, with intuitive, easy-to-use SonicWall TZ Series firewalls. -
Broad, flexible remote access
Provide mobile users with native VPN remote access clients for Apple iOS, Google Android, Windows, Mac OS and Linux, via your small business firewall. This unique client also supports SonicWall Clean VPN, which enables the firewall to decontaminate threats from VPN traffic. -
Easy to deploy, all-in-one solution
Enjoy the convenience and affordability of deploying your TZ Series appliance as a SonicWall TotalSecure solution. This combines the hardware and all the services needed for comprehensive network protection from viruses, spyware, worms, Trojans, key loggers and more - before they enter your network - and without the complexity of building your own security package. -
Secure wireless connectivity
Encrypt wireless traffic with secure Internet access over high-speed 802.11n wireless to ensure integrity while, providing secure, password-protected Internet access. The TZ Series also Provies 3G wireless WAN and analog modem connectivity as primary or secondary connections.
- SonicWall TZ600 - Advanced Edition - security appliance - Secure Upgrade Plus
- Security appliance
- Form Factor
- External
- Data Link Protocol
- Performance
- Firewall throughput: 1.9 Gbps , Application throughput: 1.8 Gbps , IPS throughput: 1.2 Gbps , Anti-malware throughput: 800 Mbps , TLS/SSL inspection and decryption throughput: 300 Mbps , VPN throughput (IPSec): 1.1 Gbps , Connection rate: 12000 connections per second , Threat prevention throughput: 800 Mbps
- Capacity
- Virtual interfaces (VLANs): 50 , SSL VPN licences: 2 (maximum 200) , VPN tunnels (site-to-site): 50 , IPSec VPN clients: 2 (maximum 25) , SPI connections: 150000 , DPI connections: 125000 , Authenticated users (internal database): 250 , Single Sign-On (SSO) users: 500 , Manageable access points: 24 , DPI SSL connections: 25000
- VoIP Protocols
- SIP, H.323 v3, H.323 v4, H.323 v1, H.323 v2, H.323 v5
- Power
- AC 100-240 V (50 - 60 Hz)
- Pricing Type
- SonicWALL Secure Upgrade Plus Program (3 years option)
- 28 cm x 18 cm x 3.5 cm
- 1.47 kg
- 28 cm
- 18 cm
- 3.5 cm
- 1.47 kg
- Form Factor
- External
- Connectivity Technology
- Wired
- TCP/IP, PPTP, UDP/IP, L2TP, ICMP/IP, IPSec, PPPoE, DHCP
- Routing Protocol
- OSPF, RIP-1, RIP-2, BGP, static IP routing, policy-based routing (PBR)
- Remote Management Protocol
- SNMP 2, SNMP 3, HTTP, HTTPS, CLI
- Performance
- Capacity
- Firewall protection, VPN support, PAT support, VLAN support, Stateful Packet Inspection (SPI), DoS attack prevention, content filtering, port mirroring, IPv6 support, Intrusion Prevention System (IPS), URL filtering, deep inspection, DDos attack prevention, Wi-Fi Multimedia (WMM) support, anti-spam protection, anti-malware protection, Quality of Service (QoS), Dead Peer Detection (DPD), IPSec NAT-Traversal (NAT-T), DHCP server, bandwidth control, Common Access Card (CAC) reader support, anti-spyware protection, DHCP relay, 3G/4G USB Dongle Support, NetFlow, proxy firewall, DiffServ Code Point (DSCP) support, Single Sign-On (SSO) support, anti-virus protection, keyword filtering
- Encryption Algorithm
- DES, Triple DES, MD5, SHA-1, 128-bit AES, 192-bit AES, 256-bit AES
- Authentication Method
- RADIUS, LDAP, internal user database, Active Directory, XAUTH authentication
IP Telephony
- VoIP Protocols
- Expansion Slots
- 1 (total) / 1 (free) x expansion slot
- 9 x 1000Base-T - RJ-45 , 1 x 1000Base-T - RJ-45 (WAN) , 2 x USB 3.0 - Type A , 1 x console - RJ-45
- MTBF
- 18.4 years
- FCC Class A certified, UL, TUV GS, C-Tick, ICSA Firewall certified, cUL, ICSA Antivirus, CB, FIPS 140-2 Level 2, EMC, RoHS, KCC, WEEE, REACH, ICES Class A, VPNC certified, LVD, IPv6 Ready, VCCI Class A, MSIP, CoC, UC APL
- Pricing Type
- Power Device
- External power adapter
- Voltage Required
- 16.1 Watt
- Power Provided
- 60 Watt
- OS Provided
- SonicOS 6.2.x
- 0 °C
- 40 °C
- 5 - 95% (non-condensing)
