SonicWALL TZ500 Secure Upgrade Plus - Advanced Edition 2yr
Quicklinx: DJSRWS00 Mfr#: 01-SSC-1736
A fast connection to your business, school, remote office or retail site is only half the story; you also need to be able to securely manage it. The TZ600 gives you enterprise-grade protection to stop cyberattacks as you expand and control your network.
Get comprehensive protection and lightning-fast performance in an entry level next-generation firewall with the SonicWall TZ Series. Designed for small networks including remote and branch offices, the TZ Series offers five different models that can be tuned to meet your specific needs. Advanced unified threat management (UTM) security, networking and management features plus optional 802.11ac Wi-Fi ensure your network and data are protected from the latest threats over wired and wireless connections.
For emerging enterprises, retail and branch offices looking for security performance at a value price, the SonicWall TZ600 next-generation firewall secures networks with enterprise-class features and uncompromising performance.
Move Forward Confidently
  • Parented Reassembly-Free Deep Packet Inspection (RFDPI) technology
  • Consolidated threat prevention: Cloud-based multi-engine sandboxing, anti-malware, intrusion prevention, web filtering and more
  • Feature-rich SonicOS operating system with intuitive user interface
  • Gigabit Ethernet ports
  • SSL, TLS and SSH decryption and inspection
  • Native SSL VPN secure remote access
  • Integrated 802.11ac wireless (optional)
  • Full-featured, advanced security
    Deliver full-featured security that combines intrusion prevention, gateway anti-virus, anti-spyware, content filtering and anti-spam services, with intuitive, easy-to-use SonicWall TZ Series firewalls.
  • Broad, flexible remote access
    Provide mobile users with native VPN remote access clients for Apple iOS, Google Android, Windows, Mac OS and Linux, via your small business firewall. This unique client also supports SonicWall Clean VPN, which enables the firewall to decontaminate threats from VPN traffic.
  • Easy to deploy, all-in-one solution
    Enjoy the convenience and affordability of deploying your TZ Series appliance as a SonicWall TotalSecure solution. This combines the hardware and all the services needed for comprehensive network protection from viruses, spyware, worms, Trojans, key loggers and more - before they enter your network - and without the complexity of building your own security package.
  • Secure wireless connectivity
    Encrypt wireless traffic with secure Internet access over high-speed 802.11n wireless to ensure integrity while, providing secure, password-protected Internet access. The TZ Series also Provies 3G wireless WAN and analog modem connectivity as primary or secondary connections.
SonicWall TZ600 - Advanced Edition - security appliance - Secure Upgrade Plus
Security appliance
External
Performance
Firewall throughput: 1.9 Gbps , Application throughput: 1.8 Gbps , IPS throughput: 1.2 Gbps , Anti-malware throughput: 800 Mbps , TLS/SSL inspection and decryption throughput: 300 Mbps , VPN throughput (IPSec): 1.1 Gbps , Connection rate: 12000 connections per second , Threat prevention throughput: 800 Mbps
Virtual interfaces (VLANs): 50 , SSL VPN licences: 2 (maximum 200) , VPN tunnels (site-to-site): 50 , IPSec VPN clients: 2 (maximum 25) , SPI connections: 150000 , DPI connections: 125000 , Authenticated users (internal database): 250 , Single Sign-On (SSO) users: 500 , Manageable access points: 24 , DPI SSL connections: 25000
VoIP Protocols
SIP, H.323 v3, H.323 v4, H.323 v1, H.323 v2, H.323 v5
AC 100-240 V (50 - 60 Hz)
Pricing Type
SonicWALL Secure Upgrade Plus Program (2 years option)
28 cm x 18 cm x 3.5 cm
1.47 kg
Security appliance
28 cm
18 cm
3.5 cm
1.47 kg
External
Wired
Network / Transport Protocol
TCP/IP, PPTP, UDP/IP, L2TP, ICMP/IP, IPSec, PPPoE, DHCP
Routing Protocol
OSPF, RIP-1, RIP-2, BGP, static IP routing, policy-based routing (PBR)
Remote Management Protocol
SNMP 2, SNMP 3, HTTP, HTTPS, CLI
Performance
Firewall protection, VPN support, PAT support, VLAN support, Stateful Packet Inspection (SPI), DoS attack prevention, content filtering, port mirroring, IPv6 support, Intrusion Prevention System (IPS), URL filtering, Deep Packet Inspection (DPI), DDos attack prevention, Wi-Fi Multimedia (WMM) support, anti-spam protection, anti-malware protection, Quality of Service (QoS), Dead Peer Detection (DPD), IPSec NAT-Traversal (NAT-T), DHCP server, bandwidth control, Common Access Card (CAC) reader support, anti-spyware protection, DHCP relay, 3G/4G USB Dongle Support, NetFlow, proxy firewall, DiffServ Code Point (DSCP) support, Single Sign-On (SSO) support, anti-virus protection, keyword filtering
Encryption Algorithm
DES, Triple DES, MD5, SHA-1, 128-bit AES, 192-bit AES, 256-bit AES
Authentication Method
RADIUS, LDAP, internal user database, Active Directory, XAUTH authentication
IP Telephony
VoIP Protocols
Expansion Slots
1 (total) / 1 (free) x expansion slot
9 x 1000Base-T - RJ-45 , 1 x 1000Base-T - RJ-45 (WAN) , 2 x USB 3.0 - Type A , 1 x console - RJ-45
MTBF
18.4 years
FCC Class A certified, UL, TUV GS, C-Tick, ICSA Firewall certified, cUL, ICSA Antivirus, CB, FIPS 140-2 Level 2, EMC, RoHS, KCC, WEEE, REACH, ICES Class A, VPNC certified, LVD, IPv6 Ready, VCCI Class A, MSIP, CoC, UC APL
Pricing Type
External power adapter
16.1 Watt
Power Provided
60 Watt
OS Provided
SonicOS 6.2.x
5 - 95% (non-condensing)
