Dell SonicWALL Secure Remote Access (SRA) series solutions are simple to deploy and even easier to use for a fraction of the price of most other products.
Remote access has never been so simple to deploy and use. Mobile employees only require a standard browser to log into a customizable portal that provides access to email, files, Web applications and internal Web sites. For even more powerful capabilities such as secure access to any resource on the corporate network including servers and local applications, the appliances transparently push a downloadable thin client (NetExtender) to the user's desktop or laptop.
Seamless integration behind virtually any firewall
Seamless integration behind virtually any firewall enables organizations to leverage the existing network infrastructure. -
Clientless connectivity
Clientless connectivity removes the need for a pre-installed VPN client, thus freeing administrators from a tedious and costly task. -
NetExtender technology
NetExtender technology enables network level access to resources, services and applications. -
A personalized Web portal
A personalized Web portal displays only those resources that are available to the user based on company policy. -
Remote support using SonicWall Virtual Assist
Remote support using SonicWall Virtual Assist enables technicians to provide secure on-demand assistance to customers while leveraging the existing infrastructure. -
Unified policy
Unified policy displays granular bookmarks and policies in one centralized page, streamlining configuration, troubleshooting and administrative overhead.
- SonicWall SRA 4600 - VPN gateway
- VPN gateway
- Form Factor
- External
- RAM
- 2 GB
- Flash Memory
- 1 GB
- Ports Qty
- 4
- Data Link Protocol
- Capacity
- Concurrent users: 25 , Maximum number of users: 500
- Power
- AC 100/230 V (50/60 Hz)
- 43.8 cm x 25.73 cm x 4.45 cm
- 4.3 kg
- VPN gateway
- 43.8 cm
- 25.73 cm
- 4.45 cm
- 4.3 kg
Processor / Memory / Storage
- RAM
- 2 GB
- Flash Memory
- 1 GB
- Form Factor
- External
- Ports Qty
- 4
- Remote Management Protocol
- Telnet, HTTP, HTTPS, SSH
- Capacity
- Hardware encryption, VPN support, Syslog support, IPv6 support, High Availability
- Encryption Algorithm
- Triple DES, RSA, MDC2, ARCFOUR, SHA-1, TLS 1.0, SSL 3.0, 256-bit AES
- Authentication Method
- RADIUS, LDAP, Active Directory, VASCO token authentication
- 4 x 1000Base-T - RJ-45 , 1 x management - RJ-45 , 2 x USB - Type A
- MTBF
- 17.8 years
- FCC Class A certified, UL, TUV GS, C-Tick, BSMI, cUL, NOM, VCCI Class A ITE, CB, KCC, ANATEL, ICES Class A
- Power Device
- Internal power supply
- Voltage Required
- 50 Watt
- 0 °C
- 40 °C
- 5 - 95% (non-condensing)
C2G 2m USB 2.0 A/B Cable - Black | In Stock | £4.20 |
C2G 5m USB 2.0 A/B Cable - Black | In Stock | £4.31 |
