SonicWALL NSA 2400 High Availability (HA) Unit
Quicklinx: 8W18WS00 Mfr#: 01-SSC-7052
The Dell SonicWALL NSA 2400 is a next-generation Unified Threat Management platform, utilizing a breakthrough multi-core hardware design with 2 cores and 6 Gigabit Ethernet interfaces to deliver real-time network protection without compromising performance. Ideal for small-to-midsize corporate and branch office environments, the NSA 2400 offers best-in-class threat prevention, rapid deployment and lowered TCO. The NSA 2400 combines high-speed intrusion prevention, file and content inspection and powerful application firewall capabilities with an extensive array of advanced network and configuration flexibility features in an accessible, affordable platform that is easy to deploy and manage in a wide variety of environments.
  • Next-generation firewall security
    A suite of tools, including intrusion prevention, gateway anti-virus, and anti-spyware plus application intelligence and control, offer granular control through application blocking, bandwidth management and more. Additional security and connectivity capabilities such as IPSec VPN, SSL VPN, content filtering, anti-spam and enforced client anti-virus make the NSA series a comprehensive and powerful all-in-one security solution.
  • Multi-core architecture
    Single-core and ASIC processors may have been sufficient for the design of traditional stateful firewalls. But NSA series appliances go above and beyond, with a multi-core design to help ensure that the deep packet inspection provided by the SonicWall Next-Generation Firewall can scale with your expanding organization. As many as eight cores spread the network load evenly and protect against extreme performance degradation often present in other technologies when exposed to heavy traffic conditions and malicious content.
  • Deep packet inspection technology
    Proprietary SonicWall RFDPI technology offers extremely high scalability and performance suitable for even the most demanding environments. RFDPI scans traffic on every port, on every protocol and in any direction to provide ultimate visibility and control. The unique design of the RFDPI engine allows it to inspect every byte of a connection - and up to hundreds of thousands of simultaneous connections - in order to categorize application traffic and protect against internal and external threats at both the application and network layer.
  • Lowered complexity and cost
    Along with superior power efficiency, SonicWall NSA series appliances lower the total cost of ownership by reducing complexity and the time necessary to configure, deploy and maintain security solutions. An intuitive GUI and powerful set-up wizards make it easy to quickly set up and fine-tune network policies, application rules, VPN connections and more.
SonicWall NSa 2400 - security appliance - High Availability
Security appliance
External - 1U
RAM
256 MB
Ports Qty
6
Performance
Firewall throughput: 450 Mbps , VPN throughput (3DES/AES): 300 Mbps , Intrusion prevention throughput: 50 Mbps , Gateway anti-virus throughput: 100 Mbps , Firewall throughput (IMIX): 225 Mbps , Connection rate: 3000 connections per second
VPN client licences: 10 , VPN tunnels (site-to-site): 75 , Nodes: unlimited , Connection / user qty: 48000 , Authenticated users (internal database): 250
VoIP Protocols
SIP, H.323 v3, H.323 v4, H.323 v1, H.323 v2
512 MB CompactFlash Card
Microsoft Windows 2000, Microsoft Windows Vista / XP
43.2 cm x 26 cm x 4.4 cm
3.7 kg
Security appliance
Height (Rack Units)
1U
43.2 cm
26 cm
4.4 cm
3.7 kg
Processor / Memory / Storage
RAM
256 MB
External
Ports Qty
6
Wired
Data Transfer Rate
1 Gbps
Network / Transport Protocol
TCP/IP, PPTP, UDP/IP, L2TP, ICMP/IP, IPSec, PPPoE, DHCP
Routing Protocol
OSPF, RIP-1, RIP-2, static IP routing
Remote Management Protocol
SNMP 2, HTTP, HTTPS
Performance
Firewall protection, DHCP support, load balancing, Syslog support, Stateful Packet Inspection (SPI), DoS attack prevention, content filtering, dynamic DNS server, antivirus analysis, High Availability, Intrusion Prevention System (IPS), Deep Packet Inspection (DPI), Stateful Failover, DDos attack prevention, anti-spam protection, Quality of Service (QoS), Dead Peer Detection (DPD), IPSec NAT-Traversal (NAT-T)
Encryption Algorithm
DES, Triple DES, MD5, IKE, SHA-1, PKI, 128-bit AES, 192-bit AES, 256-bit AES
Authentication Method
Secure Shell (SSH), RADIUS, X.509 certificates, LDAP, internal user database, Active Directory
IEEE 802.1Q, X.509
IP Telephony
VoIP Protocols
Communications
Supported Flash Memory Cards
CompactFlash Card
6 x 1000Base-T - RJ-45 , 1 x management , 2 x USB
Internal power supply
Installed Qty
1
42 Watt
Power Provided
180 Watt
OS Provided
SonicOS Enhanced
Software Included
SonicWALL ViewPoint
5 °C
10 - 90%
